Elmar f= 5 cm 1:2.8
- Leica Order No. - ELMOO 11 112 - ELMOM 11 612 /LLC - 114
- Production era - 1957-1962 screw lenses; 1958-1966 bayonet < 74,000 lenses
- Variants - Metric, foot, 3-crown (on bottom ring) for Swedish army versions
- F stop range - f/2.8-f/16
- Smallest object field - 410 x 620 mm
- Diaphragm setting /type - 15 blade
- Filter type - E39 - A42
- Accessories - Hood: 12585, 12549, ITOOY, VTOOX aperture setting ring
- Dimensions (collapsed flange length x diameter) - 20.94 mm / 0.6 in x 50.96 mm/ 2.0 in
- Weight - 220 g /7.76 oz
- Inscriptions - Elmar f=5cm 1:2.8 Nr1XXXXXX Ernst Leitz GmbH Wetzlar
ELMAR 1:2.8 F=5cm 1XXXXXX LEITZ WETZLAR - Designer - Max Berek
- On the street - $US 250 (S) - 300 (M) in 2010
Elmar f= 5 cm 1:2.8 Serial Numbers
| 1402001 | 1402100 | Elmar 5 cm 1:28 | 1956 | 100 |
| 1438001 | 1440000 | Elmar 5 cm 1:28 (S) | 1956 | 2000 |
| 1450001 | 1455000 | Elmar 5 cm 1:28 (S) | 1956 | 5000 |
| 1494001 | 1497000 | Elmar 5 cm 1:28 (S) | 1957 | 3000 |
| 1537501 | 1541000 | Elmar 5 cm 1:28 (S) | 1957 | 3500 |
| 1549001 | 1552000 | Elmar 5 cm 1:28 (M+S) | 1958 | 3000 |
| 1574001 | 1578000 | Elmar 5 cm 1:28 (M+S) | 1958 | 4000 |
| 1589001 | 1592000 | Elmar 5 cm 1:28 (M) | 1958 | 3000 |
| 1600001 | 1603000 | Elmar 5 cm 1:28 (M) | 1958 | 3000 |
| 1617001 | 1621000 | Elmar 5 cm 1:28 (M+S+S3crown) | 1958 | 4000 |
| 1624001 | 1627000 | Elmar 5 cm 1:28 (M) | 1958 | 3000 |
| 1632501 | 1638500 | Elmar 5 cm 1:28 (S+S3crown) | 1958 | 6000 |
| 1668001 | 1671000 | Elmar 5 cm 1:28 (M) | 1959 | 3000 |
| 1697751 | 1700000 | Elmar 5 cm 1:28 | 1959 | 2250 |
| 1721501 | 1725000 | Elmar 5 cm 1:28 (M) | 1960 | 3500 |
| 1727001 | 1730000 | Elmar 5 cm 1:28 (M) | 1960 | 3000 |
| 1819001 | 1822000 | Elmar 5 cm 1:28 (M) | 1960 | 3000 |
| 1838001 | 1840000 | Elmar 5 cm 1:28 | 1961 | 2000 |
| 1909001 | 1912000 | Elmar 5 cm 1:28 | 1961 | 3000 |
| 1912000 | 1936000 | Elmar 5 cm 1:28 (M) | 1962 | 3300 |
| 1989001 | 1991000 | Elmar 5 cm 1:28 (M) | 1963 | 2000 |
| 2073501 | 2074500 | Elmar 5 cm 1:28 (M) | 1964 | 1000 |
| 2119151 | 2121150 | Elmar 5 cm 1:28 (M) | 1965 | 2000 |
| 2161501 | 2162500 | Elmar 5 cm 1:28 | 1966 | 1000 |
| 2186901 | 2188900 | Elmar 5 cm 1:28 (M) | 1966 | 2000 |
| 2237001 | 2238000 | Elmar 5 cm 1:28 (M) | 1967 | 1000 |
| 2326301 | 2327800 | Elmar 5 cm 1:28 | 1969 | 1500 |
| 2472501 | 2473250 | Elmar 5 cm 1:28 (M) | 1971 | 750 |
| 2503001 | 2503100 | Elmar 5 cm 1:28 | 1971 | 100 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1956-1971 | 74,000 |
