75mm f/1.4 Summilux-M
  • Leica Order No. - 11 814 - 11 815 - 11 810 LLC - 165
  • Production era - 1980-2007 < 14,752 lenses
  • Variants - Black, titanium, ELC, ELW, 1913-1983 anniversary edition; after 1982 built-in hood version 11 815
  • F stop range - f/1.4-f/16
  • Closest focusing distance - 0.75 m /2.46 ft
  • Smallest object field - 192 mm x 288 mm /1:8
  • Diaphragm setting /type - with clickstops from serial No. 2048701 onwards including half values / 10-blade
  • Angle of view diagonal, horizontal, vertical - 32°, 27°, 18°
  • Filter type - E60
  • Accessories - Hood for 1st version: 12539
  • Materials -
  • Dimensions (length x diameter) - 80 x 69 mm /3.15 x 2.72 in
  • Weight - 560 g /19.75
  • Inscription - LEICA LENS MADE IN CANADA 1:1.4/75 E60 SUMMILUX-M XXXXXXX
LEITZ SUMMILUX-M 1:1.4/75 E60 325XXXX
LEICA SUMMILUX-M 1:1.4/75 E60 395XXXX
75mm f/1.4 Summilux-M Serial Numbers
3063301 3064300 75mm f/1.4 Summilux-M 1980 1000
3150501 3151500 75mm f/1.4 Summilux-M 1981 1000
11 814 ABOVE BUILT-IN HOOD BELOW TYPE 11 815
3223301 3225300 75mm f/1.4 Summilux-M (13-83) 1982 2000
3258101 3260100 75mm f/1.4 Summilux-M 1983 2000
3439501 3440000 75mm f/1.4 Summilux-M 1987 500
3457871 3458370 75mm f/1.4 Summilux-M 1988 500
3484901 3485400 75mm f/1.4 Summilux-M 1989 500
3508996 3509295 75mm f/1.4 Summilux-M 1990 300
3525296 3525795 75mm f/1.4 Summilux-M 1990 500
3574134 3574633 75mm f/1.4 Summilux-M 1991 500
3607320 3607619 75mm f/1.4 Summilux-M 1993 300
3614480 3614979 75mm f/1.4 Summilux-M 1993 500
3617900 3617901 75mm f/1.4 Summilux-M 1993 2
3641576 3641825 75mm f/1.4 Summilux-M 1993 250
3685731 3686230 75mm f/1.4 Summilux-M 1995 500
3719103 3719602 75mm f/1.4 Summilux-M (11 810) 1995 500
3797510 3797709 75mm f/1.4 Summilux-M (11 810) 1997 200
3820125 3820624 75mm f/1.4 Summilux-M 1998 500
3837375 3837974 75mm f/1.4 Summilux-M 1998 600
3865967 3866166 75mm f/1.4 Summilux-M 1999 200
3869617 3869916 75mm f/1.4 Summilux-M 1999 300
3884907 3885206 75mm f/1.4 Summilux-M 2000 300
3904826 3905125 75mm f/1.4 Summilux-M 2000 300
3915523 3916022 75mm f/1.4 Summilux-M (11 810) 2001 500
3953001 3953500 75mm f/1.4 Summilux-M (ELW) 2002 500
3977589 3977888 75mm f/1.4 Summilux-M 2004 300
3988519 3988718 75mm f/1.4 Summilux-M 2005 200
unknown unknown 75mm f/1.4 Summilux-M 2006-2007 unknown
TOTAL ASSIGNED SERIAL NUMBERS 1980-2005 14,752
