O
OAGNO | Medical copy stand using PLOOT | 1938-19?? | - |
OAPDO | Medical copy stand using PLOOT | 1939-19?? | Italian item |
OCEGO | Leica Ig body | 1957-1963 | - |
OCLOM | Visoflex II with 4x 90 magnifier, bayonet mount | 1962-19?? | - |
OCMOR | Visoflex lens 1:3.5 / 65 Elmar | 1960-1970 | 11062 |
ODULO | PROON reflex housing + PAMOO right-angle magnifier | 1940-19?? | - |
OEFGO | Leica If body | 1952-1957 | - |
OEGIO | Leica If with viewfinder for 50 mm lenses; Leica Ic in 1950 NY catalog | 1952-1957 | - |
OEINO | Leica If with viewfinder for 50 mm lenses and ELMAR | 1952-1957 | - |
OERDO | Summicron 90 short mount with preset diaphragm Forum discussion | 19??-19?? | 11126 |
OESBO | Summicron 90 short mount with standard diaphragm ring Forum discussion | 19??-19?? | 11124 |
OEUPO | Extension ring for Summicron (II) f= 9 cm 1:2 with !:4.5 reproduction ratio | 1959-19?? | 16474 |
OHEBO | Hektor f= 13.5 cm 1:4.5 in short focusing mount with iris diaphragm but without coupling (ZOOKE) | 1955-1958 | - |
OHIKO | Stereo unit Stereoly complete with Stemar lens OISBO, prism, and viewfinder for screw-mount cameras | 1954-1957 | - |
OHIKO-M | Stereo unit complete with Stemar lens OISBO, prism, and viewfinder for M-mount cameras | 1954-1957 | - |
OHTEO | OIPVO stereo viewer + OIFCO light unit | 1950's | - |
OHUGO | No. 1 light yellow filter; paired for Stemar mount | ca.1959 | NY item |
OHVIO | Orange filter; paired for Stemar mount | ca.1959 | NY item |
OHWLO | UVa filter; paired for Stemar mount | ca.1959 | NY item |
OIASO | Stemar stereo lens for M-camera | 1954-1957 | - |
OIDYO | Cylidrical chrome, half frame viewfinder used with Stemar stereo unit similar in shape to SBOOI | 1954-1957 | - |
OIFCO | Stereo light unit | 1950's | - |
OIGEO | Stereo lens hood for use on Stemar when prism is not attached | 1954-1957 | ELC |
OIMPO | Prism for front of Stemar for subject distances beyond 10 feet; hinged front cover added in 1955 | 1954-1957 | - |
OIPVO | Stereo viewer with independently focusing eye pieces; brittle plastic housing | 1950's | - |
OIRZO-M | Stereo unit complete with Stemar lens, OIGEO hood, prism, and viewfinder for M-mount cameras | 1954-1957 | - |
OIRZO-S | Stereo unit complete with Stemar lens, OIGEO hood, prism, and viewfinder for screw-mount cameras | 1940-1953 | - |
OISBO | Stemar stereo lens | 1954-1957 | - |
OIVHO | Rear cover for bayonet-mount Stemar | 1950's | - |
OIWKO | Lens cap with bayonet for Stemar | 1950's | - |
OIXMO | Rear cover for screw-mount Stemar | 1950's | - |
OIZQO | Rear cover for Stemar prism | 1950's | - |
OKARO | Orange filter to improve contrast between rangefinder images for FOKUS or Leica IIc, IIf, IIIb, IIIc and IIIf in chrome Forum discussion [1] [2] | 1939-1962 | 14058 |
OKBZO | Diopter correction lens for near-sightedness for Leica IIIg | 1960-19?? | 14064 |
OKLMO | Connecting piece to convert Focomat Ic enlarger to copy use with column VOOQF and arm OKYNO | 1956-19?? | 16744 |
OKVCO | Diopter correction lens for astigmatism for Leica IIIg | 1960-19?? | 14066 |
OKYNO | Arm for Focoslide Valloy II enlarger | 1956-19?? | 16748 |
OKZPO | Copy stand 25 1/2 inch column with guide rail | 19??-19?? | 16747 |
OLEYO | Single exposure camera with IBSOR shutter used with Elmar 3.5, 5, and 10.5 cm lenses JCB's a little...15 | 1934-1935 | LEICA CAMERAS HISTORICA |
OLIGO | Single exposure camera with Ibsor shutter used a variety of lenses JCB's a little...15 | 1934-1939 | LEICA CAMERAS HISTORICA |
OLLUX | Hood for 35mm f/1.4 Summilux I | 1961-19?? | - |
OLORA | Single exposure camera without shutter | 1936-19?? | NY item |
OMAPO | Close focus accessory with parallax for 50 mm 1:4 lens; per Lager: catalog item only, no known examples are known | 1939 | - |
OMEXO | Complete copy stand including OOZEG, OOZAB, ZOOXY, VALOO, LVFOO, KGOON, OPKOM, ROOYH and ONLIO Forum discussion | 1951-19?? | LEICA CAMERAS HISTORICA |
OMIFO | Close focus accessory with parallax for 90mm f/4 Elmar lens | 1949-1968 | - |
ONLIO | Canvas carrying bag portion of OMEXO for Focoslide | 1951-19?? | LEICA CAMERAS HISTORICA |
OOBAZ | Late version focusing stage known as Focoslide for Screw-thread cameras using N series helical focusing lenses and extension tubes | 1958-19?? | 16607 |
OOEUK | 16 x 14 1/2 inch light box with 4 lamps | 1951-19?? | 16763 |
OOEVM | 9 1/2 x 7 inch light box with 4 lamps Fontenelle archive | 1951-19?? | 16762 |
OOFRC | Remote shutter release and winder operated by two chords | 1936-19?? | - |
OOGAN | OOBAZ Focoslide + VXZOO + VTOOX for Elmar f= 5 cm 1:2.8 | 1958-19?? | 16632, 16603-3/8" bush |
OOGIT | OOBAZ Focoslide + VXOOT + VALOO for Elmar (III) f= 5 cm 1:3.5 | 1958-19?? | 16633, 16604-3/8" bush |
OOGUM | OOBAZ Focoslide + ZOGOO for Focotar | 1958-19?? | 16634, 16612-3/8" bush |
OOMAP | OOTGU Focoslide + ZOGOO for Focotar | 1956-19?? | 16682, 16674-3/8" bush |
OOMEX | OOTGU Focoslide + VXZOO + VTOOX for Elmar f= 5 cm 1:2.8 | 1958-19?? | 16633, 16604-3/8" bush |
OOMYL | OOTGU Focoslide + VSPOO + VTROO for Summicron | 1956-19?? | 16681, 16678-3/8" bush |
OORES | Rotating focusing mount with screen; early versions with single lens; 1937 double; slide-in and bayonet versions JCB's a little...17 | 1934-1950's | LEICA CAMERAS HISTORICA |
OORHY | Leica 250 (models DD, FF & GG) nº 353696 | 1943 | Fontenelle archive |
OOTGU | Late version focusing stage known as Focoslide for M-cameras using N series helical focusing lenses and extension tubes | 1957-19?? | 16680 |
OOZAB | Focusing stage known as Focoslide; early version had single bar on spring-loaded arm; later version with adjustable positioning bar; last version was H-shaped to clear flash bracket lug Fontenelle archive | 1938-1957 | LEICA CAMERAS HISTORICA |
OOZAB-G | Focusing stage known as Focoslide for accepting Leica IIIg camera | 1951-1957 | - |
OOZEG | Folding horse-shoe type copy stand portion of OMEXO for Focoslide | 1951-19?? | - |
OOZIS | Collapsible, horseshoe shaped copy stand | 1939-19?? | - |
OOZKU | Set of 5 extension rings for OOZIS copy stand | 1939-19?? | - |
OOZMY | Complete copy outfit including OOZAB, ZOOXY, ROOYH, VALOO, LVFOO and OPKOM release | 1952-19?? | - |
OPDUR | Medical copy stand using OPRAL and OPFAS | 19??-19?? | - |
OPFAS | Medical copy stand using frame with handle and chest support | 1932-19?? | - |
OPKOM | Cable release portion of OMEXO for Focoslide; 20 inches with lock | 1951-19?? | Fontenelle archive |
OPRTO | Diopter correction lens for near-sightedness for Leica IIc, IIf, IIIb, IIIc and IIIf | 1951-19?? | 14060 |
OPRYL | Medical copy stand using lower body strut with webbing sling | 19??-19?? | - |
OPSVO | Diopter correction lens for astigmatism for Leica IIc, IIf, IIIb, IIIc and IIIf | 1951-19?? | 14065 |
OQWCO | Lens cap Forum discussion | 19??-19?? | 14028 |
OQZIO | Diopter correction lens for near-sightedness for Viso magnifiers LVFOO and PEGOO | 1960-19?? | 14063 |
ORAKO | Orange filter to improve contrast between rangefinder images for FOKUS or Leica II, III and IIIa in black or chrome Forum discussion [3] [4] | 1936-1962 | 14057 |
ORBMO | Diopter correction lens for near-sightedness for Leica I-IIIa and Universal viewfinder | 1941-19?? | NY item |
ORESO | SPOOV copy stand + OORES rotating stage | 1936-19?? | - |
ORLEO | Diopter correction lens for astigmatism for Leica M-cameras to 1977 | 1956-1977 | 14062 |
ORMGO | Diopter correction lens for astigmatism for Leica I-IIIa and Universal viewfinder | 1941-19?? | NY item |
OROBA | Cap used with XOOIM hood (in reverse position) on a 50 mm Summilux Forum discussion | 19??-19?? | - |
OROLF | Lens turret for 3 lenses with handle; no more than 250 were made OROLF image | 1960 | [5] [6] [7] |
ORPDO | A42 slip-over, chromed plated brass with felt lining front cap for 21mm f/3.4 Super-Angulon-R | 1958-1963 | 14031 |
ORPNO | Front cap for f = 12.5 cm 1:2.5 Hektor - with rear cap HGOOI it became a container for the lens JCB's a little...If | 19??-19?? | - |
ORQPO | Hood for Summarex f= 8.5 cm 1:1.5; early version was black with clamping screw, later chrome for bayonet fitting | 1951-1960 | 12525 JCB's a little...IIIf |
ORTOX | Diopter correction lens for near-sightedness for Leica M-cameras to 1977 | 1951-1977 | - |
ORTUX | Diopter correction lens for near-sightedness for Leica I-IIIa and Universal viewfinder Forum discussion | 1933-19?? | 14061 |
ORTVO | Cap that screws into body lens opening | 19??-19?? | 14055 |
ORUXO | Diopter correction lens for astigmatism for Leica I-IIIa and Universal viewfinder | 1938-19?? | 14069 |
ORWYB | Diopter correction lens for near-sightedness for Leica IIIb | 1939-19?? | NY item |
ORYCE | Diopter correction lens for astigmatism for Leica IIIb | 1939-19?? | NY item |
ORYFO | Rear dust cap for screw lenses | 1951-19?? | 14050 |
OSBLO | Magnifying eye-piece for 5 or 9 cm screw lens; converts lens to small telescope - see Photography Accessories for Monoscopes | 1954-19?? | Cosmonet OSBLO |
OSERO | Diopter correction lens for astigmatism for Viso magnifiers LVFOO and PEGOO | 1960-19?? | 14069 |
OTDYM | Visoflex II without magnifier, bayonet mount Forum discussion | 1962-19?? | 16455 |
OTEMO | Stemar attachment for subject distance of 3 - 10 meters; only 20 of these were delivered Forum discussion | 1950's | - |
OTHEO | 5 x stereo viewer | 1950's | - |
OTPLO | F = 20 cm 1:4.5 Telyt for Visoflex with hood SUNGO and later TNGOO | 1935-1960 | JCB's a little...11 |
OTPRO | Visoflex extension tube for near focusing with universal focusing mount Forum discussion | 1959-19?? | 16471 |
OTQNO | Visoflex ring addapter for Elmar 9 cm | 1959-19?? | 16468 |
OTRPO | 1:1.25 magnification accessory for OTZFO focusing mount used with Visoflex II/ III | ? | 16471 |
OTSRO | Adapter for use of 13.5 cm Hector lens with OTZFO focusing mount used with Visoflex II/ III Forum discussion | 1959-19?? | 16472 |
OTVXO | 5x chimney eyepiece for Visoflex II Forum discussion | 1962-19?? | 16461 |
OTXBO | 4x 90 degree eyepiece for Visoflex II Forum discussion | 1962-19?? | 16499 |
OTYDO | Visoflex II without magnifier, screw mount Forum discussion | 1962-19?? | 16457 |
OTZFO | Universal focusing mount for Visoflex II/ III for use with 1:3.5 / 65 Elmar, 90mm Elmarit and 135mm Elmar lenses Forum discussion | ? | 16464 Forum discussion |
OUAGO | Visoflex addapter for using Elmar 9 cm Forum discussion | 1959-19?? | 16467 |
OUBIO | Visoflex II/ III adapter for Hektor 125 mm; Elmar and Hektor 135 mm in short mounts; TELYT Visoflex lenses Forum discussion [8] | 1959-19?? | 16466 Forum discussion |
OUCLO | Visoflex II with 4x 90 magnifier, screw mount | 1962-19?? | 16458 |
OUEPO | Close-focus adaptor to be used with either the Summicron (II) f= 9 cm 1:2 in ZOOEP/16463 or 16462 adaptor or the 2.8/135 in 16462 adaptor. This usage will yield a 1:4.5 reproduction scale. Forum discussion | 1959-19?? | 16474 |
OUFRO | Extension ring for 35/50mm M-bayonet lenses with 1:1 ratio | ? | 16469 |
OUFRO | Visoflex extension ring for 5 and 3.5 cm lenses | 1959-19?? | 16469 |
OUTSO | Projection head to fit ground glass screen of Focoslide or Reprovit | 1951-19?? | 16750 |
OVAFO | Base and 48 x 1 5/8" diameter column for Reprovit I | 1951-19?? | - |
OVURO | Valoy II copy stand with 32 inch column and UWOOS bracket for Focoslide | 1960-19?? | 16701 |
OZTFO | Connector ring for the 65mm Elmar and 90 mm Elmarit to R-body Forum discussion | 19??-19?? | - |
OZTNO | Cable release addaptor for using screw release on M-camera Forum discussion [9] | 1955-19?? | 14088 |
OZTOM | Double cable release for M-camera Forum discussion | 19??-19?? | 16491 |
OZUPO | Visoflex I housing - JCB's Visoflex I Collection Fontenelle archive | 1951-19?? | 16484 |
OZWTO | Double cable release for Visoflex I with time lock screw; early chrome and later black versions JCB's a little...11 Fontenelle archive | 1951-19?? | 16492 Fontenelle archive |
OZWTO-M | Double cable release for Visoflex M-camera with time lock screw; early chrome and later black versions Forum discussion | 1951-19?? | 16491 Fontenelle archive |
OZXOM | Visoflex I with 5x chimney eyepiece, bayonet mount | 19??-19?? | 16482 |
OZXVO | Cable release for Visoflex I for screw cameras only; pneumatic so called "sports release" | 1954-19?? | 16493 |
OZYXO | Visoflex I with 5x chimney eyepiece, screw mount | 1951-1954 | 16485 |
OZYXO-M | Visoflex with 5x chimney eyepiece, bayonet mount | 19??-19?? | 16482 |
