35mm f/2.5 Summarit-M
Revision as of 20:45, 9 April 2012 by Admin (talk | contribs) (→35mm f/2.5 Summarit-M Serial Numbers)
- Leica Order No. - 11 643
- Production era 2007-Current
- Lens mount - Leica M quick-change bayonet with 6 bit lens identification bar code for digital M models
- Number of lenses/groups - 6 /4
- Focusing range - 0.8 m / 2.62 ft < ∞
- Aperture - f/2.5-f/16 - Setting/Function Preset, with click-stops, half values available; 9-blade
- Smallest object field/Largest reproduction ratio - For 35 mm, approx. 490 x 735 mm /1:20.4 = for LEICA M8, approx. 367 x 551 mm /1:20.4
- Angle of view (diagonal, horizontal, vertical) - For 35 mm (24 x 36 mm) : 63 deg, 54 deg, 38 deg, - for LEICA M8 (18 x 27 mm) : 50 deg, 42 deg, 29 deg, corresponds to a focal length of approx. 47 mm with 35 mm-format
- Position of entrance pupil - (related to the first lens surface in light direction) 9.3 mm
- Filter mount/Lens hood - Non-rotating, internal thread for screw-on filters size E39, external thread with stop for lens hood, protection ring for external thread included in delivery
- Accessories - Hood: 12459
- Materials - Anodized aluminum, brass and optical glass
- Focal length -
- Length to bayonet flange - approx. 33.9 mm
- Largest diameter - approx. 51.4 mm / 2.02 in
- Weight - approx. 220 g / 7.76 oz
- Inscription - LEICA SUMMARIT-M 1:2.5/35 E 39 (serial no.)
Serial numbers compiled from known lensesSN Start | SN End | Product | Year | Total |
-4049243 | 4063533- | 35mm f/2.5 Summarit-M | 2007 | 14,291+ |
-4102152 | 4125785- | 35mm f/2.5 Summarit-M | 2009 | 23,634+ |
TOTAL | ASSIGNED | SERIAL NUMBERS | 2007- | unknown |
