R
Revision as of 15:05, 5 May 2012 by Admin (talk | contribs)
RAMET Mask used with RASUK for 10.5 & 13.5 cm lenses 1933-19??
Rapido N.Y. rapid winder - see Westlicht Auction 21/Lot 22 1936 -
RASAL RAMET + RASUK; for 10.5 & 13.5 cm lenses; black or chrome 1933-19?? -
RASUK Folding viewfinder for 3.5, 5, 7.3 and 9 cm lenses; black or chrome 1933-19?? -
RDQOO Reprovit II diaphragm operating lever and guide for lens on ROOXU 1951-19?? 16775
REDIG-BEEUL Resistor for 110 volt DC 19??-19?? -
REDUK-BEEUL Resistor for 220 volt DC 19??-19?? -
REDYX Regulating transformer for BEECH microscope light 1934-19?? -
REEOD Universal Copying Device consisting of VAFOO, RESOO, STUOO, GROOW, ZWOOC, UNOOB, TBKOO, LOOCG, LOOFV, LOOGI, LOOHW and LSZOO 1936-19?? -
Reprovit Copy stand with (II, IIa) or without (I) lights - Models I (ROOSE 1951), II (ROOXU 1951) & IIa (16788 1963) Forum discussion 1951-1963 Glennview
RESOO Carrying arm with OORES rotating upper stage 1936-19?? -
RFUOO Regulating transformer for RIOOZ to control light 1936-19?? -
RGWOO Object stage to flatten books for copying 1951-19?? 16786
RIFLE Rifle stock for use with Telyt lenses with long, right-angle eyepiece and double cable release; rare 1938-1939 -
RIOOX Reprovit II base and column with arm, tape measure and switches 19??-19?? -
RIOOZ Ring illuminator for Universal Copying Device 1936-19?? -
RKCOO Reprovit 4-lamp unit 1951-19?? 16785
ROOAI Reprovit II focusing stage with bellows, see JCB Accessories 1951-19?? 16770
ROOAM Reprovit II focusing stage with bellows with bayonet-mount 1960-19?? -
ROOFU Reprovit I and Focoslide carrying arm to fit 1 5/8 inch column 1951-19?? -68-61-63-69-78
ROOKA Large copying device with VELTU base and column, ROOMB arm, STAFO lighting, VEHIG and STAMA 1936-19?? -
ROOMB Arm for ROOKA large copying device used with VELTU base and arm 1936-19?? -
ROONP Copy arm to fit 1 1/4 inch column for Focoslide 1951-19?? -
ROOSE Reprovit I Universal Copying Device consisting of OVAFO, ROOFU, OOZAB, OUTSO, ZOOXY and VALOO 1951-19?? -
ROOXU Reprovit II Universal Copying Device consisting of RIOOX, ROOAI, RDQOO, OUTSO, DOOCO and RKCOO 1951-19?? 16795, 16794-3/8" bush
ROOYH 1 in /26 mm repro extension tube used with ZOOXY 1951-1978 LEICA CAMERAS HISTORICA
ROSOL Folding frame, open, chrome viewfinder for 50, 90, 135 mm lenses; early version also included 85 mm lenses; some have feet and meter calibrations for parallax correction 1951-19?? 12040
ROXUM Reprovit II for bayonet-mount Leica 1960-19?? 16796, 16793-3/8" bush
RPNOO Reprovit micro-addaptor for focusing stage with shutter, eyepiece, correction lens and double cable release 1951-19?? -
RPOOT Reprovit micro-addaptor for focusing stage without shutter, eyepiece or cable release 1956-19?? -
RQPOO Blue filter; screw-on type L for Summitar f= 5 cm 1:2 ca.1949 -
RSTOO Reprovit micro-addaptor for focusing stage with shutter, eyepiece, 1/2x correction lens and double cable release 1951-19??
RTSOO Reprovit micro-addaptor for focusing stage with 1/2x correction lens but without shutter, eyepiece or cable release 1956-19?? -
RWBOO Deerskin pouch for RASAL Fontenelle archive 1933-19?? -
