M Monochrom
- Production era - 2012-current
- Camera type - Compact digital rangefinder system camera with a dedicated black-and -white image sensor
- Image sensor - Active area approx. 23.9 x 35.8 mm, 5212 x 3468 pixels (18 megapixels). Infrared blocking filter for invisible light with wavelengths longer than 700 nm, no low-pass filter
- Colour spaces - sRGB hardwired
- Exposure metering - Exposure metering through the lens (TTL), centre-weighted at working aperture - Centre-weighted TTL-metering for flash with system-compatible SCA-3000/2 standard flash units
Exposure modes: Aperture priority (A) / Manual(M)
- Flash exposure control
- Flash connection - Hot shoe with centre and control contacts.
- Flash metering - Control by centre-weighted, TTL pre-flash metering (with SCA-3501/3502 adapters or SCA-3000 standard
- Viewfinder
- Long-base rangefinder - Bright rectangular spot (RF spot) with coincident and superimposed fields in the centre of the *viewfinder image
- Read-out
- Displays on the back - 2.5″ monitor (colour TFT-LCD) with 230,000 pixels
- Shutter /shutter release
- Camera body
