M
Revision as of 20:27, 25 May 2012 by Admin (talk | contribs)
MAALK Micro / macro stand, complete ? -
MAARP Leicameter-M, with a selenium booster cell ? -
MACCA Leicameter-M, with a selenium booster cell 19?? -
MACROTAR Early name of close-up attachment for R-Lenses, see ELPRO 1965 -
MADAX Leicameter-M, with a selenium cell for 9x12cm 1937 -
MADHA Micro / macro stand with holder for Leica with micro Visoflex, etc. . 19??-19?? -
MAKAM Leicameter-M, with a selenium cell (also microscope camera per WestLicht 17/lot 238) ca.1958 Forum discussion
MAKRO 94-400 mm - f8 /32 Lens for microscope use with RMS mount 19??-19?? -
MARDIX Binoculars 10 x 50 1932-1962 see also Sport Optics
MARDIXIT Binoculars 10 x 50 - CF 1932-1962 see also Sport Optics
MARDOCE Binoculars 12 x 60 ca.1939-1962 see also Sport Optics
MARDOCIT Binoculars 12 x 60 - CF ca.1939-1962 see also Sport Optics
MARINODOCE Binoculars 12 x 60 Marine version Porro-prism 1915 see also Sport Optics
MAROCTO Binoculars 8 x 60 1932-1962 see also Sport Optics
MAROCTIT Binoculars 8 x 60 - CF 1932-1962 see also Sport Optics
MARSEPT Binoculars 7 x 50 - IF Porro-prism 1932-1962 see also Sport Optics
MARSEPTIT Binoculars 7 x 50 - CF 1932-1962 see also Sport Optics
MBOOC Selenium cell for Leicameter-MC 1958-19?? JCB's a little...M3
MBOOW Selenium cell for Leicameter for METRA 1955-19?? JCB's a little...M3
MBOOW-C Selenium booster cell for Leicameter-MC 1951-19?? JCB's a little...M3
MBOOWT Selenium booster cell for Leicameter 2 1951-19?? -
MBROO Water-resistant aluminum case for all models up to Leica IIIf 1950-1961 -
METER Leicameter NY version, similar to Metrawatt MF/LC 60 1951 -
METNBC METWMT + MBOOWT 1954 NY item
METNBD METWMT + MBOOWT 1956-1957 NY item
METMBG METWMT + MBOOWT, with an expanded ASA-scale ? NY item
METRA First Leicameter-M (1955) then Leicameter-MC (1957 #14200) with a selenium booster cell Forum discussion 1955-1960s JCB's a little...M3
METRPC Carrying chain with bracket for METNBC and METWMT ? -
METTNC Metrawatt Leicameter Model 3, NY version 1956 -
METWMT Metrawatt Leicameter Model 2, NY version 1954 JCB's a little...IIf
MIBAC For MIKAS, ½ x reducer lens 1950 -
MIBAC-M For MIKAS, ½ x reducer lens with bayonet 1958-1959 -
MICCA Micro camera equipment with MACCA, 4.5 x 6 cm format 1923-1924 -
MICCO M3 sync connector for CHICO flash ? 15524
MICCS Like MICCO for external flash units with the same connection ? -
MICCX M3 sync connector for CHICO flash, longer version 1956 -
MICCZ M3 sync connector for CHICO flash, more stable version 1958 -
Micro-Isbo see MIKAS 1933-1960s -
MIDAP Conical adapter for MIKAS 1930's -
MIFCA Micro 1/3x attachment with shutter for connecting to microscope body MIFILMCA 1926-1933 -
MIFOANSA Back for MIFCA, CAFOT, etc. ? -
MIKAS Micro attachment with lateral focusing for connecting screw Leica to a microscope Forum discussion 1933-1950s Forum discussion
MIKAS-M Micro attachment with lateral focusing for connecting bayonet Leica to microscope 1959-1960s -
MILAR 20-100 mm f4.5 /4.8 Lens for microscopic camera use with Aristophot system or UXOOR, Bellows II with a special, circular adapter plate 19??-19?? -
MIOOP Camera Adapter for Microscope 1938 -
MIOOT Camera Adapter for Microscope 1951-1952 -
MKHOO Masking frame used on Focomator II has an automatic margin adjustment and a paper ejector Fontenelle archive late 1950s -
MONLA Microscope lamp 1933-19?? -
MONODAL 6 x 21 1908-1919 see also Sport Optics
MONOT 6 x 30 - IF 1912-ca.1926 see also Sport Optics
MOMON 8 x 24 1913 see also Sport Optics
MONOFOREST 6 x 42 1927-1939 see also Sport Optics
MONOFORSTA 8 x 42 1927-1939 see also Sport Optics
MONMAR 7 x 50 1932-1962 see also Sport Optics
MONDIX 10 x 50 1932-1962 see also Sport Optics
MONOCHT 8 x 60 1932-1962 see also Sport Optics
MONDUCE 12 x 60 ca.1939-1962 see also Sport Optics
MOOBG Microscope extension tube M-1:2, 16 mm 1936-19?? LEICA CAMERAS HISTORICA
MOODH Microscope extension tube M-1:1.5, 24.5mm 1936-19?? LEICA CAMERAS HISTORICA
MOOGW Microscope extension tube M1:1, 41mm 1936-19?? LEICA CAMERAS HISTORICA
MOOLY Spring driven "Leica-Motor" 1st version for Leica IIIa (model G) and Leica IIIb 1938 JCB's a little...IIIa
MOOLY-C Spring driven "Leica-Motor" 2nd version for Leica IIIc and Leica IIId 1940-1949 less than 200 manufactured
MOONZ M3 sync connector for CEYOO flash 1954-1960s 15521
MOOSP Close focus tube for Telyt 20 cm lenses; 15 x 45 mm diam.; chrome or black Forum discussion Just-a-little . . . 1935-1984 14020
MQUOO Mouth release Forum discussion 19??-19?? -
