S2
- Production era - 2009-
- Order nos. - 10 801 - S2-P 10 802
- Camera type - Digital single-lens reflex camera for use with Leica S lenses.
- Image sensor - low-noise Kodak CCD sensor, resolution: 37.5 megapixels (7,500 x 5,000), size: 45 x 30mm, pixel spacing: 6μm. aspect ratio: 3:2, dynamic range: 12 stops, color depth: 16 bits per pixel, low-pass filter: none (Moiré detection and suppression using digital signal processing).
- Sensitivity range - ISO 80 to 1250 (manual or automatic control).
- Data storage - Format: DNG (approx. 75 MB per image), JPEG (basic or fine), memory cards: CompactFlash (up to 64 GB), SD (HC).
- Maximum frame rate - 1.5 images/s, buffer memory: 1 GB (for a minimum sequence of 8 images in DNG format).
- Control monitor - 3-inch TFT with 460,000 pixels, 16 million colors, cover glass: highly abrasion and scratch resistant sapphire glass (only with the LEICA S2-P).
- Connections - High-speed USB 2.0 (robust connection with strain-relief, cable included), HDMI, remote release, X sync, SCA3002.
- Exposure metering - Multi-field metering (5 fields), center-weighted integral metering, spot metering (3.5%).
- Exposure control - Program mode (with Shift function), shutter priority, aperture priority, manual metering.
- Shutter - Metal focal-plane shutter integrated in body: 1/4000 s to 32 s (B to 120 s), flash sync time: 1/125 s, optional leaf shutter in selected lenses: 1/500 s to 8 s, flash synch time: 1/500 s.
- Flash operation - Metering method: TTL (multi-field, selective, center-weighted), TTL-HSS rapid synchronization up to 1/4000 s with shutter, Compatibility: fully compatible with LEICA SF 58 and devices with SCA3002 adapters.
- Auto Focus - central crosshair sensor, focusing drive in lens, operating modes: AF continuous, AF single, MF, MF override, AF memory with AF lock button.
- Viewfinder - High eye-point pentaprism viewfinder, magnification: 0.86x, viewfinder field: 96%, diopter compensation -3 to +1, focusing screen: matte with cross-hairs (interchangeable).
- Power supply - Li-Ion Akku (7.4 V, 2150 mAh)
- Housing - Die-cast magnesium, size (without lens): 160 x 120 x 80 mm/6.29 x 4.72 x 3.15 in, weight: 1410 g/49.73 oz (including battery), resistant to dust and dripping/splashing water.
- Scope of supply - Software: Adobe Lightroom, Leica Image Shuttle, battery, charging unit, USB cable, carrying strap.
- Accessories
- 16003 - Multifunctional grip S
- 16004 - Neoprene hand strap
- 16011 - Professional charger S - 14429 Battery
- SF-58 Flash Unit
- 16012 S-Camera Remote Release Cable
- Lens adapters (introduced August 2011)
- S-Adapter V - Hasselblad V System lenses
- S-Adapter P67 - Pentax 67 system lenses
- S-Adapter M645 - Mamiya 645 system lenses
- S-ADAPTER H - Hasselblad H System lenses (introduced July 2012)
- 16002 - Grid screen, showing the “golden ratio” for precise image composition
- Other - "High-quality filters can be obtained . . . from traditional manufacturers like B+W and Heliopan."
- S2 Lenses
- S2 Firmware Updates
- Version 1.0.2.0 - December 19, 2011
- Version 1.0.3.3 - May 16, 2012
- On the street - $US 22,995 - SP-2 27,995 in 2012 & 2010
Leica S2 Serial Numbers
Serial numbers compiled from known S2 camerasSN Start | SN End | Product | Year | Total |
-3032249 | 3799028- | Leica S2 | 2009 | unknown |
-3800217 | 3800971- | Leica S2 | 2010 | 755+ |
-3832051 | 3833130- | Leica S2 | 2011 | 1080+ |
-3905541 | 3905638- | Leica S2 | 2011 | 98+ |
TOTAL | ASSIGNED | SERIAL NUMBERS | 2009-Current | unknown |
