TS-APO-Elmar-S 120mm f/5.6 ASPH.
Revision as of 16:49, 20 September 2012 by Admin (talk | contribs)
  • Order number - 11079
  • Production era - 2012-
  • Optical design
    • Lenses /groups - 6 /4
    • Image angle (diagonal, horizontal, vertical) - 23.6°, 20°, 13.6°, corresponds to approx. 96 mm focal length in 35 mm format
    • Position of entrance pupil - 65.6 mm
  • Setting /function - Electronically controlled diaphragm, set using dial on camera, including half values
    • Aperture range - 5.6 to 32
    • Focusing range - 0.95 m to infinity
  • Distance setting
    • Smallest object field - 159 mm × 239 mm
    • Largest reproduction ratio - 1 : 5.3
  • Size
    • Filter mount - Internal thread for E95 filter, filter mount does not rotate
    • Dimensions (diameter/length) - 108 mm /144 mm
    • Weight: 1110 g
  • Serial nos. -
