Super-Elmar-S 24mm f/3.5 ASPH.
Revision as of 14:49, 28 September 2012 by Admin (talk | contribs)
  • Order number - 11054
  • Production era - 2012-
  • Optical design
    • Lenses /groups - 12 /10
    • Image angle (diagonal, horizontal, vertical) - 96.6°, 86.5°, 63.9°, corresponds to approx. 19 mm focal length in 35 mm format
    • Position of entrance pupil - 83.4 mm from apex of 1st lens element
  • Setting /function - Electronically controlled diaphragm, set using dial on camera, including half values
    • Aperture range - 3.5 to 22
    • Focusing range - 0.4 m to infinity
  • Distance setting
    • Smallest object field - 349 mm × 533 mm
    • Largest reproduction ratio - 1 : 11.3
  • Size
    • Filter mount - Internal thread for E95 filter, filter mount does not rotate
    • Dimensions (diameter /length) - 101 mm /112 mm
    • Weight: 1260 g
  • Accessories included - Lens Hood : 12404 - Rear lens cover : 16020 - Lens cover S 16027
  • Serial nos. - -4152535-
