SF 20
Revision as of 14:30, 1 November 2012 by Admin (talk | contribs)
  • Production era - 2003-2008
  • Code number - 14414
  • Manufacturer - Metz (similar to Metz 34CS-2)
  • Type - Shoe mount flash unit allows TTL-flash exposure control with the R8 or R9 as well as the MP, M6 or M7 TTL-models plus automatic flash exposure control with all other LEICA M and R cameras with central X hot-shoe contact.
  • Guide No. - 65' (19.8 m)
  • Angle of Coverage - 63° (35mm lens in 35mm format)
    84° (24mm) with wideangle diffuser
  • Auto Distance Range - 23' (7.0 m), 11' (3.4 m) , 5.7' (1.7 m)
  • Auto f/Stops - f/2.8, 5.6 & 11
  • Flash compensation - +/- 3 EV
  • Variable Power - 1/2, 1/4th & 1/8th
  • TTL Dedication - Yes (if used on R8 & M6 TTL)
  • Recycle Time - 5 Seconds (based on fresh batteries & full power)
  • Accessories - SFILL difusser
  • Power Source - Two 3-Volt CR123A lithium batteries
  • Dimensions - 2.6 x 4.3 x 1.6" (66 x 109 x 41mm) W x H x D
  • Weight - 0.38 lb (170 g)
