DIGITAL-M POWER SUPPLY
- 14463 - Standard Charger - 14470 Compact Charger (Yes, the Compact Charger is larger than the Standard Charger :-)
- Production era - Standard charger 2006-2008 - Compact charger 2008-Current
- Manufacturer's discription - The compact charger unit is designed to take up a minimum of space in the photograper's bag and is equipped with a quick-charger function for charging the battery. The LED flashes yellow after about two hours when 80 percent of the charging capacity has been reached. This is already sufficient for about 400 exposures, so if the full capacity of about 500 exposures is not required, the camera can always be recharged in a very short time.
- For cameras - M8 - M8.2 - M9 - M9-P - M Monochrom - M-E
- 14464 Battery - Rechargeable Lithium-ion BP-DP20, 3.7 V 1600-1900 mAh, BLI-312
- Accessories - EU and USA power cords as well as car charging cable for 12-24 Volts are included. UK and AUS power cords (100-240 V) are supplied as separate accessories.
- 14494 Charger-M - BC-SCL2
- Production era - 2013-
- For camera - Leica M
- 14499 Battery - Rechargeable Lithium-ion BP-SCL2, 7.4 V, 1800 mAh
