SF 24D
Revision as of 17:18, 22 February 2009 by Admin (talk | contribs)
  • Flash unit for the LEICA R6 R8 R9 TTL/M7 CM Digilux 2 with flash foot with central - and signal contacts.
Leica order number - 14 444 silver or black
Guide Number - 24 dBi / 65 at ISO 100
Angle of flash coverage - 28 degrees (85mm) with tele diffuser/ 63 degrees35mm lens in 35mm format/ 84 degrees (24mm) with wideangle diffuser.
Color temperature -
Flash compensation - +/- 3 EV
Number of flashes per set of batteries - approx. 280 (with alkali-manganese batteries).
Flash recharging time - 5 Seconds with fresh batteries.
Operating modes - Auto Settings: f/2.0, 2.8, 4.0, 5.6 8.0 & 11 ; Auto Distance 23'/7.0 m/11' 3.4 m/5.7'/1.7 m ; Zoom Range Diffusers for Tele 85mm and wide angle 24-85
Operating voltage - 3-V ; Power supply Two CR123A lithium batteries.
Dimensions - (W x H x D) 66 x 109 x 41mm / 2.6 x 4.3 x 1.6 in
Weight 180 g / 6.3 oz.
