C 112
Revision as of 18:37, 11 September 2013 by Tdavis (talk | contribs)
  • Production era - 2013-Current
  • Leica C (Type 112) order nos.
    • Light-gold - 18 484 (E-version), 18 485 (U-version), 18 486 (TK-version), 18 487 (CN-version).
    • Dark-red - 18 488 (E-version), 18 489 (U-version), 18 490 (TK-version), 18 491 (CN-version).
  • Lens
    • DC Vario-Summicron f/2-5.9 (at maximum wideangle and telephoto settings)/6-42.8 mm ASPH. (35 mm camera equivalent: 28–200 mm).
  • Sensor
    • 1 /1.7" MOS sensor. Primary color filter.
    • Total pixel number - 12,800.000. Effective pixels: 12,100.000.
  • Minimum illuminance - Approx. 6 lx.
    • With camera models 18 484/-487/-488/-491: (when i-low light and 1/25 s shutter speed is used).
    • With camera models 18 485/-486/-489/-490: (when i-low light and 1/30 s shutter speed is used).
  • Focus range
P/A/S/M - 50 cm /20 in - 80 cm /31.5 in (at maximum wideangle /telephoto settings) to inf.
Macro/Snapshot modes/Video recording - 3 cm/1.2 in / 80 cm/31.5 in (at maximum wideangle /telephoto settings) to inf.
Scene modes - May differ from the ranges above.
  • Digital zoom - Max. 4 x.
  • Stabilization system - Optical.
  • Shutter system - Electronically and mechanically controlled.
  • Shutter speed - 250 s to 1 /4000 s.
(Starry Sky) Mode: 15 s, 30 s, 60 s.
  • Exposure modes - Program mode (P), Aperture priority (A), Shutter speed priority (S), Manual setting (M),
Exposure compensation - increments 1 /3 EV steps, setting range: ± 2 EV.
  • Metering modes - Multiple, Center-weighted, Spot.
  • Flash - Built-in.
    • Flash modes - Auto , Auto /Red eye reduction, Slow sync./Red eye reduction, ON, OFF.
    • Flash range - (with ISO auto )
Approx. - 0.6 – 7 m | 23 – 275 in (with maximum wide angle setting)
Approx. - 0.8 – 2.3 m | 31 – 90 in (with maximum telephoto setting).
  • Monitor - 3.0 in TFT-LCD with approx. 921,600 pixel.
    • Aspect ratio - 3:2. Shows approx 100 % of the captured frame.
  • Viewfinder - Color LCD with approx 200,000 pixel. Diopter correction facility: ± 4 diopters.
  • Microphone - Stereo.
  • Speaker - Monaural.
  • Recording media - Internal memory (approx. 87 MB).
    • Memory cards - SD, SDHC, SDXC.
  • Recording file format
    • Still pictures - RAW/JPEG (based on Exif 2.3 standard)/DPOF compatible/MPO.
    • Motion pictures (with audio) - AVCHD with Dolby® Digital (2ch)/MP4 with AAC (2ch).
  • Operating temperature /humidity - 0°–40°C - 32°–104°F / 10–80 % rh.
  • Digital interface - USB 2.0 (High Speed).
With camera models 18 484 /-488: Data from the PC cannot be written to the camera using the USB cable.
  • Analog interface - (video/audio)
With camera models 18 484 /-487 /-488 /-491 - NTSC/PAL Composite (switched by menu),
With camera models 18 485 /-486 /-489 /-490 - NTSC Composite, Audio line socket (monaural).
  • Terminals HDMI - For HDMI micro cable (type D).
  • AV OUT/DIGITAL - Dedicated jack (8 pin).
  • Wi-Fi Compliance standard - IEEE 802.11b/g/n (standard wireless LAN protocol).
    • Used frequency range - 241 – 2462 MHz (1 – 11 ch).
    • Encryption method - Wi-Fi compatible WPA™ /WPA2™.
    • Access method - Infrastructure mode.
  • NFC Compliance standard - ISO /IEC 18092 NFC-F (passive mode).
  • Battery - (lithium-ion) BP-DC14 E/U.
    • Voltage/capacity - 3.7 V /950m Ah.
    • Battery charger - ACA-DC11-A/B/C/E/U/K.
    • Input - AC 110–240 V 50/60 Hz, 0.2 A.
    • Output - DC 5 V 800 mA.
  • Dimensions (W x H x D) - Approx. 103 x 63 x 28 mm / 4.06 x 2.48 x 1.10 in (lens retracted).
  • Weight Approx. - 173 /195 g - 6.1 /6.9 oz (without /with card and battery).
  • Scope of delivery - Camera body, battery charger /AC adapter (Leica ACA-DC11), rechargeable battery (Leica BP-DC14), wrist strap, AV cable, USB cable, CD with long instructions (PDF), short instructions, Guarantee Card.
Software - Adobe® Photoshop® Lightroom® 5.
  • Accessories
    • Additional battery - 18536 (U)
    • C-Twist - wrap-around case, light-gold 18784, dark-red 18785
    • C-Snap - protection case, light-gold 18786, dark-red 18787 (Dec)
    • C-Clutch - compartmented bag, light-gold 18788, dark-red 18789
    • C-Case - black leather case 18790
    • C-Pouch - black lambskin pouch, 18791
    • C-Hand Strap - light-gold 18792, dark-red 18793
  • Designer (Body /accessories) - Audi Design
Manufacturer's data as of September 2013
  • On the street - £GB 550, $US 699 in 2013
  • Forum discussion
