Elmarit-S 45mm f/2.8 ASPH.
- Order numbers - 11 077; 11 078 (CS version with Central Shutter)
- Production era - 2013-
- Lenses/groups - 12 /9 (1 aspherical surface)
- Optical design - Rear group focusing
- Image angle (diagonal, horizontal, vertical) - approx. 62°, 53°, 37°, approx. corresponds to 36 mm in 35 mm-format
- Aperture range - 2.8 to 22
- Shortest distance - 0.6 m
- Largest image scale - 1:10.1
- Flash sync speed - 1/125 s (CS: 1/1000 s)
- Filter thread size - 82 mm (non-rotating)
- Dimensions (diameter /length) - 88 mm /136 mm
- Dimensions w/ hood (diameter /length) - 132 mm /163 mm
- Weight: 1030 g (CS: 1110 g)
- Accessories included - Lens Hood 12400: - Rear lens cover 16020: - Lens cover S 16019
- Leica Tech Data - pdf
Elmarit-S 45mm f/2.8 ASPH. Serial Numbers
Serial numbers compiled from known Elmarit-S 45mm f/2.8 ASPH. lenses| SN Start | SN End | Product | Year | Total |
| -4119204 | 4215526- | Elmarit-S 45mm f/2.8 ASPH. | 2013 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2013-Current | unknown |
