EIZO
- Model - ColorEdge CG246
- Panel Type - IPS
- Size - 24.1" / 61 cm (611 mm diagonal)
- Native Resolution DisplayPort, DVI - 1920 x 1200 (16:10 aspect ratio)
- HDMI - 1920 x 1080 (16:9 aspect ratio)
- Display Size (H x V) - 518.4 x 324 mm
- Pixel Pitch - 0.270 x 0.270 mm
- Grayscale Tones DisplayPort - 1024 tones (a palette of 65281 tones)
- DVI, HDMI - 256 tones (a palette of 65281 tones)
- Display Colors DisplayPort - 1.07 billion from a palette of 278 trillion
- DVI, HDMI - 16.77 million from a palette of 278 trillion
- Viewing Angles (H / V, typical) - 178°, 178°
- Brightness (typical) - 300 cd /m2
- Recommended Brightness for Calibration - 120 cd /m2 or less
- Contrast Ratio (typical) - 1000 : 1
- Response Time (typical) - 7.7 ms (Gray-to-gray)
- Wide Gamut Coverage (typical) - Adobe RGB: 97%
- Video Signals
- Input Terminals - DVI-I 29 pin (with HDCP), DisplayPort (with HDCP), HDMI (with HDCP)
- Digital Scanning Frequency (H / V) - DisplayPort, DVI: 26 - 78 kHz, 23.75 - 63 Hz (VGA Text: 69 - 71 Hz)
- HDMI - 15 - 68 kHz, 23.75 - 61 Hz
- Analog Scanning Frequency (H / V) - 26 - 78 kHz, 47.5 - 61 Hz
- USB Function - 2 ports for monitor control
- - 2-port USB hub
- - Standard USB 2.0
- Power
- Power Requirements - AC 100 - 120 V / 200 - 240 V, 50 / 60 Hz
- Maximum Power Consumption - 98 W
- Typical Power Consumption - 41 W
- Power Save Mode - Less than 0.5 W
- Standby Mode - Less than 0.5 W
- Power Management - Power Save (VESA DPM, DisplayPort Version 1.1a, and DVI DMPM)
- Self-Calibration - Yes
- Features & Functions
- Brightness Stabilization - Yes
- Digital Uniformity Equalizer - Yes
- Preset Modes - Color Mode (Custom, Adobe RGB, sRGB, Rec709, EBU, SMPTE-C, DCI, Calibration)
- OSD Languages - English, German, French, Italian, Japanese, Simplified Chinese, Spanish, Swedish, Traditional Chinese
- Others - Screen Adjustment (Clock, Phase, Position, Resolution, Range (Auto)), Screen Size (full screen, enlarge, normal), Color Adjustment (Brightness, Contrast, Black Level, Independent 6-Color Control, Gamma, Temperature, Saturation, Hue, Gain, Enhancer, Reset), HDMI Settings (Noise Reduction, Film Detection, Safe Area Marker, Safe Area Size, Border Color), Range Extension, Signal Switching, OSD Menu Settings, Overdrive, Mode Preset, USB Selection, Signal Info, Monitor Info, DUE Priority, Key Lock, Signal Bandwidth, Power Indicator, All Reset
- Physical Specifications
- Dimensions (Landscape, W x H x D) - 575 x 417 - 545 x 245.5 mm
- Dimensions (Portrait, W x H x D) - 398 x 594.5 - 642.5 x 245.5 mm
- Dimensions (Without Stand, W x H x D) - 575 x 398 x 75 mm
- Net Weight - 9.9 kg / 21.8 lbs
- Dimensions (Landscape with Hood, W x H x D) - 582.5 x 425 - 553 x 369 mm
- Dimensions (Portrait with Hood, W x H x D) - 406 x 602.5 - 650.5 x 369 mm
- Net Weight (Without Stand) - 7.2 kg / 15.9 lbs
- Net Weight (With Hood) - 10.7 kg / 23.6 lbs
- Height Adjustment Range - 128 mm
- Tilt - 30° Up, 0° Down
- Swivel - 344°
- Pivot - 90°
- Hole Spacing (VESA Standard) - 100 x 100 mm
- Environmental Requirements
- Operating Temperature - 0 - 35 °C
- Operating Humidity (R.H., non condensing) - 20 - 80 %
- Certifications & Standards (Please contact the EIZO group company or distributor in your country for the latest information.) CUDO certified mark, TUV/S, TUV/Ergonomics (including ISO 9241-307 [Pixel fault class I]), TUV/GS, cTUVus, CE, c-Tick, CB, VCCI-B, FCC-B, Canadian ICES-003-B, RoHS, WEEE, GOST-R
- Supplied Accessories - AC power cord, signal cables (DVI-D - DVI-D, Mini DisplayPort - DisplayPort), USB cable, setup guide, EIZO LCD Utility Disk (ColorNavigator software, PDF user's manual), adjustment certificate, ScreenCleaner, monitor hood, quick reference, warranty card
- Optional accessories
- Monitor Hood - CH7 (as shown)
- Wall Mount - LA-011-W (35° up tilt and 180° swivel wide adjustment range)
- Wall Mount Arm - LA-030-W (Position the monitor almost anywhere with forward/backward and side-to-side movement)
- Warranty - Five Years
