Elmar (II) f= 9 cm 1:4
Revision as of 16:13, 28 March 2012 by Admin (talk | contribs) (→Elmar (II) f= 9 cm 1:4 Serial Numbers)
- Leica Order No. - ELANG LLC -
- Production era - 1933-1953 < 107,480 lenses
- Variants - Black, all chrome (1946-1953), opthalmology (OPT) and Wehrmacht Heer (WH) versions, later versions have black Vulcanite on the ring nearest the camera (covering the screw, a black dot takes the place of the arrow indicator) the cutaway lens is this type
- F stop range - f/4-f/36
- Smallest object field -
- Diaphragm setting /type - 15-blade
- Filter type - A36
- Accessories - Viewfinder: SOOUT, SGVOO - Case: ETINI
- Materials -
- Weight - 250 g /0.55 lb
- Inscription - Elmar f=9cm 1:4 No6xxxxx Ernst Leitz Wetzler
- On the street - $US 90 (black) - 1,400 (chrome) in 2010
Serial numbers compiled from Puts Pocket Pod.* Lens 969262 is Elmar 3.5/5cm (Westlicht Lot 68/03)
.** Lens 1010059 is M-collapsible
^ Lens 566204 & 566318 are Elmar 4 /9 cm
^^ Lens 450068* is a Elmar 4 / 9 cm (from the Fontenelle Archive)
-94181 | unknown- | Elmar 90 mm 1:40 (black.nickel) | -1932 | unknown |
-135236 | 135864- | Elmar 90 mm 1:40 (black) | 1933 | 627+ |
165001 | 166000 | Elmar 90 mm 1:40 (black) | 1933 | 1000 |
177001 | 178000 | Elmar 90 mm 1:4 (black) | 1933 | 1000 |
220101 | 222000 | Elmar 90 mm 1:40 (black) | 1934 | 1900 |
260001 | 261000 | Elmar 90 mm 1:4 (black) | 1935 | 1000 |
283551 | 284500 | Elmar 90 mm 1:4 (black) | 1935 | 950 |
295001 | 297000 | Elmar 90 mm 1:4 (black) | 1936 | 2000 |
320001 | 322000 | Elmar 90 mm 1:40 (black) | 1936 | 2000 |
355001 | 356000 | Elmar 90 mm 1:4 (black) | 1937 | 1000 |
372001 | 375000 | Elmar 90 mm 1:40 (black) | 1937 | 3000 |
411001 | 415000 | Elmar 90 mm 1:40 (black) | 1937 | 4000 |
450001^^ | 450500 | Elmar ^^95 mm 1:50^^ | 1938 | [500] |
453001 | 460000 | Elmar 90 mm 1:40 (black) | 1938 | 7000 |
516001 | 520000 | Elmar 90 mm 1:40 (black) | 1939 | 4000 |
556001 | 557000 | Elmar 90 mm 1:40 (black-WH) | 1940 | 1000 |
565001 | 566000 | Elmar 90 mm 1:40 (black) | 1941 | 1000 |
566001 | ^ 566500 | ^ Hektor 7.3 cm 1:1.9 | 1941 | [500] |
575001 | 575200 | Elmar 90 mm 1:40 | 1941 | 200 |
576201 | 577000 | Elmar 90 mm 1:40 (black) | 1941 | 800 |
583501 | 583682 | Elmar 90 mm 1:40 | 1942 | 182 |
590001 | 590200 | Elmar 90 mm 1:40 | 1942 | 200 |
592001 | 593000 | Elmar 90 mm 1:40 (black) | 1942 | 1000 |
596001 | 597000 | Elmar 90 mm 1:40 | 1945 | 1000 |
606001 | 607000 | Elmar 90 mm 1:40 | 1946 | 1000 |
615001 | 616000 | Elmar 90 mm 1:40 | 1946 | 1000 |
633001 | 633100 | Elmar 90 mm 1:40 | 1947 | 100 |
635001 | 637000 | Elmar 90 mm 1:40 | 1947 | 2000 |
645001 | 647000 | Elmar 90 mm 1:40 (black+chrom) | 1947 | 2000 |
657001 | 677000 | Elmar 90 mm 1:40 (chrom) | 1948 | 20000 |
696001 | 699000 | Elmar 90 mm 1:40 | 1949 | 3000 |
718001 | 721000 | Elmar 90 mm 1:40 | 1949 | 3000 |
756001 | 760000 | Elmar 90 mm 1:40 | 1950 | 4000 |
807001 | 810000 | Elmar 90 mm 1:40 | 1950 | 3000 |
836001 | 840000 | Elmar 90 mm 1:40 (chrom) | 1950 | 4000 |
872001 | 880000 | Elmar 90 mm 1:40 (chrom.OPT) | 1951 | 8000 |
958001 | 959000 | Elmar 90 mm 1:40 | 1952 | 1000 |
960001 | 965000 | Elmar 90 mm 1:40 (chrom) | 1952 | 5000 |
967001* | 972000 | Elmar 90 mm 1:40 | 1952 | 5000 |
1010001** | 1010200 | Elmar 90 mm 1:40 (chrom) | 1952 | 200 |
1035001 | 1040000 | Elmar 90 mm 1:40 (chrom) | 1952 | 5000 |
1080001 | 1083000 | Elmar 90 mm 1:40 (chrom+OPT) | 1953 | 3000 |
1111001 | 1113385 | Elmar 90 mm 1:40 (chrom+OPT) | 1953 | 2385 |
1113438 | 1114000 | Elmar 90 mm 1:40 | 1953 | 563 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1933-1953 | 107,480 |
