90mm f/4 Macro-Elmar-M
Revision as of 21:15, 27 May 2014 by Tdavis (talk | contribs) (→90mm f/4 Macro-Elmar-M Serial Numbers)
- Leica Order No. - 11 633-black - 11 634-silver - 11 629-black set MACRO-ADAPTER-M
- Production era - 2004-Current - 3,880+ lenses
- Variants - Black and chrome versions
- Compatibility - Unlike other collapsible lenses, 90mm f/4 Macro-Elmar-M can be used on M8 or M9 cameras without restriction, as the extension tube does not extend into the camera.
- Number of lenses/groups - 4 /4
- Focusing range - 0.77 m / 2.5 ft < ∞ (with Leica MACRO-ADAPTER-M: 0.5 < 0.76 m / 1.6 < 2.5 ft)
- Aperture - f/4-f/22 - with click-stops, half values available
- Smallest object field/Largest reproduction ratio - 161 mm x 241 mm (with LEICA MACRO-ADAPTER-M: 72 x 108 mm)/1:6.7 (with LEICA MACRO-ADAPTER-M: 1:3)
- Angle of view (diagonal, horizontal, vertical) - 27°, 23°, 15°
- Position of entrance pupil - 32.3 mm / 1.27 in (related to the first lens surface in light direction)
- Filter mount - Non-rotating, internal thread for screw-on filters size E39
- Accessories - Hood: IUFOO, can be attached in reverse for storage and also 12575 - MACRO-ADAPTER-M 14 409 - ANGLEFINDER-M - Leica M Viewfinder Magnifiers 1.25x & 1.4x, Cap: 14321 silver chrome 14285 black chrome
- Materials - Anodized aluminum and optical glass / Chrome-plated brass and optical glass
- Focal length - 90.0 mm / 3.54 in
- Length to bayonet flange - 41 < 59 mm / 1.61 < 2.32 in
- Largest diameter - 52 mm / 2.05 in
- Weight - 240 g - 8.47 oz black anodized aluminum / 320 g - 11.29 oz chrome plated brass
- Inscription - LEICA MACRO-ELMAR-M 1:4/90 E39 3XXXXXX
- Manufacturer's technical data
- On the street - $US 3,995 in 2012 - $US 1,400 in 2010 - $US 1,995 - £BP 1008 in 2008
| 3968791 | 3969170 | 90mm f/4 Macro-Elmar-M | 2003 | 380 |
| 3969171 | 3970170 | 90mm f/4 Macro-Elmar-M (black+silver) | 2003 | 1000 |
| 3971486 | 3972485 | 90mm f/4 Macro-Elmar-M (silver) | 2003 | 1000 |
| 3975089 | 3976588 | 90mm f/4 Macro-Elmar-M (black) | 2003 | 1500 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2003-2005 | 3,880 |
