90mm f/2.8 Tele-Elmarit-M
Revision as of 13:59, 24 June 2014 by Tdavis (talk | contribs)
  • Leica Order No. - 11800 also known as "thin" Tele-Elmarit LLC - 172
  • Production era - 1974-1990 < 27,950 lenses
  • Variants - 6 bit encoded or uncoded, Canadian (until 1986), German, and 1913-1983 versions
  • Number of lenses /groups - 4 /4
  • F stop range - f/2.8-f/16 with half-stop clicks
  • Closest focusing distance - 1 m /3.28 ft
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type - 10-blade
  • Angle of view diagonal - 27 degrees
  • Filter type - E39
  • Accessories - Hood: IUFOO 12575, 11250, 12585
  • Materials - Black anodized aluminum, chromed brass
  • Dimensions length x diameter - 67 x 53 mm / 2.64 x 2.09 in
  • Weight - 225 g / 7.94 oz
  • Inscription - TELE-ELMARIT-M 1:2.8/90 LEITZ LENS MADE IN CANADA (or GERMANY)
  • Designer - Garry Edwards, Walter Mandler and Erich Wagner - July 30, 1970
90mm f/2.8 Tele-Elmarit-M Serial Numbers
.* Lens 2728702, 3430058 & 3430489 are Tele-Elmarit-M 2.8 / 90 (ELC.black)
.** Lens 2728702 is Tele-Elmarit-M 2.8 / 90 (ELC.13-83)
2585501 2588500 90mm f/2.8 Tele-Elmarit (ELC) 1973 3000
2656951 2659450 90mm f/2.8 Tele-Elmarit (ELC) 1973 2500
2695501 2697500 90mm f/2.8 Tele-Elmarit-M 1974 2000
2726921 **2728920 **135mm f/2.8 Tele-Elmarit (ELC) 1976 [2000]
2792651 2794650 90mm f/2.8 Tele-Elmarit-M (ELC) 1976 2000
2831351 2832350 90mm f/2.8 Tele-Elmarit-M 1977 1000
2871601 2872600 90mm f/2.8 Tele-Elmarit-M 1977 1000
2940701 2941700 90mm f/2.8 Tele-Elmarit-M 1978 1000
2967251 2969250 90mm f/2.8 Tele-Elmarit-M (ELC) 1979 2000
3003101 3004100 90mm f/2.8 Tele-Elmarit-M (ELC) 1979 1000
3065801 3066800 90mm f/2.8 Tele-Elmarit-M (ELC) 1980 1000
3068301 3069300 90mm f/2.8 Tele-Elmarit-M 1980 1000
3095501 3096500 90mm f/2.8 Tele-Elmarit-M 1981 1000
3141001 3142000 90mm f/2.8 Tele-Elmarit-M 1981 1000
3200701 3201800 90mm f/2.8 Tele-Elmarit-M (ELC.13-83) 1982 1100
3215801 3216800 90mm f/2.8 Tele-Elmarit-M (ELC.13-83) 1982 1000
3292401 3293400 90mm f/2.8 **Elmarit-M (ELC.13-83) 1983 1000
3309701 3310700 90mm f/2.8 Tele-Elmarit-M 1984 1000
3316701 3317700 90mm f/2.8 Tele-Elmarit-M (ELW) 1984 1000
3378001 3379000 90mm f/2.8 Tele-Elmarit-M (ELC+ELW) 1985 1000
3383201 3384200 90mm f/2.8 Tele-Elmarit-M (ELW) 1986 1000
3429691 3429890 90mm f/2.8 Tele-Elmarit-M 1987 200
3429891* 3433000 *Elmarit-R 28mm f/2.8 1987 [3110]
3451921 3453070 90mm f/2.8 Tele-Elmarit-M (ELW+ELC) 1987 1150
TOTAL ASSIGNED SERIAL NUMBERS 1974-1987 27,950
