SCA Adapter Set
Revision as of 13:46, 20 July 2014 by Tdavis (talk | contribs)
  • Order no. - 14498
  • Production era - 2014-Current
  • Manufacturer's description - The SCA adapter set M is primarily designed for use on the multifunction hand grip M and the Leica M (type 240). The SCA socket on this hand grip enables TTL control of a compatible flash unit remotely of the camera (if its not or cannot be used directly on the camera e.g because a viewfinder is fitted to the accessory shoe on the camera.
  • Use - The SCA adapter attaches to the bottom of the Leica M-Multi-Functional Handgrip and plugs into the grip’s SCA port, giving you full TTL compatibility with the Leica SF-58 or Leica SF 24D flashes. The Leica SCA-Adapter Set consists of a flash support bar for mounting the flash on the grip, and the external hot shoe mount which can be used without the support bar for off-camera flash.
  • On the street - €EU 330, $US 385 in 2014
