28mm f/2.8 PC-Super-Angulon-R
Revision as of 15:27, 30 September 2014 by Tdavis (talk | contribs)
  • Leica Order No. - 11 812 LLC - 149
  • Production era - 1988-2009, 6,225+ lenses
  • Lens mount - LEICA R-bayonet for LEICA R3 to LEICA R9 with mechanical exposure control and stop-down metering - lens can be shifted from the optical axis by up to 11 mm and rotation in 45° steps to permit perspective corrections in vertical and horizontal formats (62 mm image circle diameter).
  • Manufacturer - Schneider-Kreuznach
  • Number of lenses/groups - 12 / 10
  • Focusing range - 0.3 m / 11.8 in < ∞
  • Aperture - f/2.8-f/22 - Preset diaphragm with clickstops (including half values), Manual diaphragm
  • Smallest object field/Largest reproduction ratio - 146 mm x 219 mm / 1:6
  • Angle of view diagonal - 73°, 93°
  • Displacement - 0 < 11 mm (9.5 mm diagonally) for correction of converging verticals in architectural photography by twisting a knurled adjustment screw.
  • Position of entrance pupil - 25.6 mm / 1 in (related to the first lens surface in light direction)
  • Filter mount/Lens hood - Internal thread for screw-in type filters EW 67, unset glass filters 74 mm (for special wide-angle filter mounting in lens hood, as well as special polarizing filter 67 EW ) / Separate, screw-in type 12540, also serves as holder for special 67 EW filters
  • Accessories - Hood: 12540
  • Viewfinder - Camera viewfinder
  • Materials - Anodized aluminum and optical glass
  • Focal length - 29.2 mm / 1.15 in
  • Length to bayonet flange - 84 mm / 3.3 in
  • Largest diameter - 97 mm / 3.8 in
  • Weight - 600 g / 21.1 oz
  • Inscription - PC-SUPER-AUGULON-R 1:2.8/28 LENS MADE IN GERMANY
  • Leica Tech Data - pdf - courtesy Summilux.net
28mm f/2.8 PC-Super-Angulon-R Serial Numbers
3470571 3470820 28mm f/2.8 PC-Super-Angulon-R 1988 250
3478651 3478900 28mm f/2.8 PC-Super-Angulon-R 1988 250
3487201 3487250 28mm f/2.8 PC-Super-Angulon-R 1989 50
3488551 3488650 28mm f/2.8 PC-Super-Angulon-R 1989 100
3489191 3489340 28mm f/2.8 PC-Super-Angulon-R 1989 150
3491401 3492000 28mm f/2.8 PC-Super-Angulon-R 1989 600
3534468 3534767 28mm f/2.8 PC-Super-Angulon-R 1990 300
3562468 3562872 28mm f/2.8 PC-Super-Angulon-R 1991 405
3579534 3579908 28mm f/2.8 PC-Super-Angulon-R 1991 375
3608930 3609179 28mm f/2.8 PC-Super-Angulon-R 1992 250
3651976 3652220 28mm f/2.8 PC-Super-Angulon-R 1994 245
3734301 3734450 28mm f/2.8 PC-Super-Angulon-R 1996 150
3769220 3769429 28mm f/2.8 PC-Super-Angulon-R 1996 210
3785330 3785359 28mm f/2.8 PC-Super-Angulon-R 1997 30
3837975 3838124 28mm f/2.8 PC-Super-Angulon-R 1998 150
3838625 3838667 28mm f/2.8 PC-Super-Angulon-R 1998 43
3858850 3859126 28mm f/2.8 PC-Super-Angulon-R 1999 277
3862377 3862416 28mm f/2.8 PC-Super-Angulon-R 1999 40
3830325 3831324 28mm f/2.8 PC-Super-Angulon-R 1998 1000
3853600 3854599 28mm f/2.8 PC-Super-Angulon-R 1998 1000
3929464 3929513 28mm f/2.8 Super-Angulon R 2001 50
3939514 3939613 28mm f/2.8 Super-Angulon R 2002 100
3983074 3983233 28mm f/2.8 Super-Angulon R 2004 160
unknown unknown 28mm f/2.8 PC-Super-Angulon-R 2006-2009 unknown
TOTAL ASSIGNED SERIAL NUMBERS 1986-2005 6,225
