Leica Ic
Ic with a Summicron (I) f= 5 cm 1:2 lens
- Code names - OEGIO* (body only) - 1950 Catalog . OCEGO* - 1958 Catalog (body only)
- OEINO = OEGIO + ELMAR (Elmar (I) f= 5 cm 1:3.5) - 1950 Catalog
- OESFO = OEGIO + SOORE (Summitar f= 5 cm 1:2 ) - 1950 Catalog
- OGILO = OCEGO + SBOOI (Viewfinder) - 1958 Catalog
- OADGO = OCEGO + ELMOO (Elmar f= 5 cm 1:2.8) - 1958 Catalog
* Note: OEGIO is the code name for the Leica If body as well as Ic depending on the date of the catalog: Leica Ic < 1951 > Leica If
- Production era - 1949-1952; 12,013 cameras
- Variants - Vulcanite and Sharkskin (SH) versions
- Evolution - Leica IIIc body without rangefinder or viewfinder intended for technical use like mounted in microscope or Visoflex; the Ic has two accessory shoes on the top
- Body - aluminum with chrome plated brass top plate, base plate and knobs
- Size L x W x H - 136 x 39 x 65 mm / 5.35 x 1.54 x 2.60 in
Leica Ic Serial Numbers
Serial numbers compiled from Puts Pocket Pod^ Camera 59478 is Leica Ic (black lacquer)
| SN Start | SN End | Product | Year | Batch |
| 455001 | 460000 | Leica Ic (SH) | 1949-1950 | 5000 |
| 520001 | 524000 | Leica Ic | 1950-1951 | 4000 |
| 560001 | 562800 | Leica Ic | 1951 | 2800 |
| 580001 ^ | 610000 | Leica IIIf ^ | 1951-1952 | [30000] |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1949-1951 | 11,800 |
