90mm f/4 Elmar
- Leica Order No. - ILNOO 11 631 - 11 830 rigid, later 11 131 - 11 130 rigid LLC - 168
- Production era - 1954-1968 < 79,605 lenses
- Variants - Collapsible and rigid versions with or without "eyes"; Scalloped focusing knurl (SFK)
- Lens mount - Leica M-bayonet and screw-mount
- Compatibility - Never try to collapse on digital Leica-Ms. It will ruin the sensor with its long tube (per Forum discussion 8 #20 below).
- F stop range - f/4-f/32
- Smallest object field - 9.5 x 14.25 in / 8.75 x 13 in viso
- Diaphragm setting /type - Click full stop
- Filter type -
- Accessories - Hood for collapsible lens: IUFOO, Close focusing device OMIFO for rigid lens (shown) - Cap: 14321 silver chrome /14285 black chrome
- Materials - Clear anodized aluminum
- Weight - 9.5 & 12 oz (rigid)
- Inscription - Ernst Leitz GmbH Wetzlar Elmar f=9cm 1:4 Nr.1XXXXXX
- On the street - $US 350 (collapsible) - 1,400 (rigid) in 2010
90mm f/4 Elmar Serial Numbers
Serial numbers compiled from Puts Pocket PodNote: Rigid lens heads above serial 1572401 are suitable for Visoflex use without modification.
1137001 | 1140000 | Elmar 90 mm 1:40 (M-collapsible) | 1954 | 3000 |
1160501 | 1163000 | Elmar 90 mm 1:40 (S+M-rigid) | 1954 | 2500 |
1171001 | 1171500 | Elmar 90 mm 1:40 | 1954 | 500 |
1178001 | 1178500 | Elmar 90 mm 1:40 | 1954 | 500 |
1182001 | 1183500 | Elmar 90 mm 1:40 (S-rigid) | 1954 | 1500 |
1188001 | 1190000 | Elmar 90 mm 1:40 (M+S-collapsible) | 1954 | 2000 |
1212001 | 1214000 | Elmar 90 mm 1:40 | 1954 | 2000 |
1224001 | 1224200 | Elmar 90 mm 1:40 | 1954 | 200 |
1236001 | 1238000 | Elmar 90 mm 1:40 (M-collapsible) | 1955 | 2000 |
1241001 | 1242000 | Elmar 90 mm 1:40 | 1955 | 1000 |
1247001 | 1250000 | Elmar 90 mm 1:40 (S-rigid) | 1955 | 3000 |
1260001 | 1263000 | Elmar 90 mm 1:40 (M-collapsible) | 1955 | 3000 |
1271001 | 1272000 | Elmar 90 mm 1:40 | 1955 | 1000 |
1291001 | 1293000 | Elmar 90 mm 1:40 (M-rigid) | 1955 | 2000 |
1309001 | 1311000 | Elmar 90 mm 1:40 (M-collapsible) | 1955 | 2000 |
1337001 | 1340000 | Elmar 90 mm 1:40 (S-rigid) | 1956 | 3000 |
1353001 | 1356000 | Elmar 90 mm 1:40 (M-rigid) | 1956 | 3000 |
1380001 | 1383000 | Elmar 90 mm 1:40 (S-rigid) | 1956 | 3000 |
1386001 | 1389000 | Elmar 90 mm 1:40 (M-collapsible) | 1956 | 3000 |
1409001 | 1412000 | Elmar 90 mm 1:40 | 1956 | 3000 |
1459001 | 1465000 | Elmar 90 mm 1:40 (M-collapsible.M+S-rigid) | 1957 | 6000 |
1481701 | 1483700 | Elmar 90 mm 1:40 | 1957 | 2000 |
1491001 | 1494000 | Elmar 90 mm 1:40 (M-collapsible) | 1957 | 3000 |
1497001 | 1499000 | Elmar 90 mm 1:40 (S-rigid) | 1957 | 2000 |
1503501 | 1506000 | Elmar 90 mm 1:40 (M-rigid) | 1957 | 2500 |
1521001 | 1524000 | Elmar 90 mm 1:40 (M-collapsible) | 1957 | 3000 |
1547001 | 1548000 | Elmar 90 mm 1:40 (M-rigid) | 1957 | 1000 |
1558001 | 1559000 | Elmar 90 mm 1:40 | 1958 | 1000 |
1572001 | 1574000 | Elmar 90 mm 1:40 (M-rigid) | 1958 | 2000 |
1585071 | 1585075 | Elmar 90 mm 1:40 | 1958 | 5 |
1603001 | 1604000 | Elmar 90 mm 1:40 | 1958 | 1000 |
1630001 | 1630500 | Elmar 90 mm 1:40 | 1958 | 500 |
1700001 | 1701000 | Elmar 90 mm 1:40 (S-rigid) | 1959 | 1000 |
1712001 | 1714000 | Elmar 90 mm 1:40 (M-rigid) | 1959 | 2000 |
1725001 | 1727000 | Elmar 90 mm 1:40 | 1960 | 2000 |
1766201 | 1768000 | Elmar 90 mm 1:40 (S-rigid) | 1960 | 1800 |
1822001 | 1823000 | Elmar 90 mm 1:40 | 1960 | 1000 |
1827001 | 1830000 | Elmar 90 mm 1:40 | 1961 | 3000 |
1920001 | 1921000 | Elmar 90 mm 1:40 (S-rigid.SFK) | 1962 | 1000 |
2088801 | 2090800 | Elmar 90 mm 1:40 (M-rigid-11 830) | 1965 | 2000 |
2097501 | 2097900 | Elmar 90 mm 1:40 (M-collapsible) | 1965 | 400 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1954-1965 | 79,605 |
