21mm f3.4 Super-Angulon
Revision as of 17:52, 2 November 2012 by Admin (talk | contribs) (→‎Comment)
  • Leica Order No. - 11 103 LLC - 138
  • Production era - 1963-1976 < 5,970 lenses
  • Manufacturer - Schneider-Kreuznach
  • Variants - Chrome until 1967 then all black; cutout version to fit M5 and CL from SN 2473251.
  • Lens mount - Leica Screw-thread & M-bayonet
  • Compatibility - Can be used on M8 or M9 cameras (without exposure metering).
  • Number of lenses /groups - 8 /4
  • F stop range - f/3.4-f/22
  • Closest focusing distance - 0.7 m - 1 m (M3)
  • Smallest object field - 380 x 570 mm / 15 x 23 in
  • Diaphragm setting /type - Click stop 4-blade
  • Angle of view diagonal - 92 degrees
  • Filter type - Series VII, E48 - A52.5
  • Accessories - Hood: 12501 - Viewfinders: SBKOO - 12012 - 12002
  • Materials -
  • Dimensions length x diameter - 51 x 52.5 mm / 2.01 x 2.07 in
  • Weight - 301 g /10.62 oz
  • Inscription - LEITZ WETZLAR SUPER-ANGULON 1:3.4/21 2XXXXXX
  • Designer - Werner Wagner of Schneider-Kreuznach - 14 Aug 1963
21mm f/3.4 Super-Angulon Serial Numbers
.* Note: JCB has 1967101 as the first batch f= 2.1 cm 1:3.4 lens - see Forum discussion [1] above - Puts has this batch with the 1:4 lens
^ Lenses 1967952, 2027728, 2035381, 2054276, 29171​00, 2917150, are 1:3.4 not 1:4 as listed
^^ Lens 2783716 is 21mm f/3.4 Super-Angulon
1967101* 1968100 Super-Angulon f= 2.1 cm 1:4* (M-chrom) 1962 1000
2027501^ 2028000 Super-Angulon f= 2.1 cm 1:4^ (M+S-chrom) 1964 500
2035001^ 2036000 Super-Angulon f= 2.1 cm 1:4^ (M+S-chrom) 1964 1000
2054001^ 2056000 Super-Angulon f= 2.1 cm 1:4^ (M+S-chrom+M-black) 1964 2000
2247151 2247650 21mm f/3.4 Super-Angulon (M+S-black) 1967 500
2292051 2292800 21mm f/3.4 Super-Angulon (M+S-black) 1968 750
2327801 2328300 21mm f/3.4 Super-Angulon (M-black) 1969 500
2372301 2372800 21mm f/3.4 Super-Angulon (M+S-black) 1969 500
2417201 2417700 21mm f/3.4 Super-Angulon (M-black) 1970 500
LENSES BELOW HAVE CUTOUT FOR USE WITH M5 + CL
2473251 2473750 21mm f/3.4 Super-Angulon (M-black) 1971 500
2522501 2522800 21mm f/3.4 Super-Angulon (M-black) 1972 300
2583001 2583500 21mm f/3.4 Super-Angulon (M-black) 1973 500
2672701 2673200 21mm f/3.4 Super-Angulon (black) 1974 500
2750631 2750750 21mm f/3.4 Super-Angulon . 1975 120
2783351 2783650 21mm f/3.4 Super-Angulon . 1976 300
2783651^^ 2785650 ^^ Elmarit-R 28mm f/2.8 ^^ 1976 [2000]
2917001 ^ 2917150 21mm f/4 ^ Super-Angulon-R ^ 1978 [150]
TOTAL ASSIGNED SERIAL NUMBERS 1967-1975 5,970
