75mm–200mm f/4.5 Vario-Elmar-R
- Leica Order No. - 11 226 LLC -
- Production era - 1978-1984 < 27,100 lenses
- Manufacturer - Minolta
- Variants -
- Number of lenses /groups - 15 / 11
- F stop range - f/4.5-f/22
- Closest focusing distance - 1.2 m / 3.94 ft
- Smallest object field - 270 x 405, 107 x 160 mm
- Diaphragm setting /type -
- Angle of view diagonal - 32 / 12.5 degrees
- Filter type - E55
- Accessories -
- Dimensions length x diameter - 157 x 70 mm / 6.18 x 2.76 in
- Weight - 725 g /1.6 lb
- Inscription - VARIO-ELMAR-R 1:4.5/75-200 LEITZ WETZLAR 29XXXXX
75mm–200mm f/4.5 Vario-Elmar-R Serial Numbers
Serial numbers compiled from Puts Pocket Pod^ Lens 3273906 is 70mm–210mm f/4
| 2895401 | 2897400 | 75mm–200mm f/4.5 Vario-Elmar-R | 1978 | 2000 |
| 2937701 | 2939700 | 75mm–200mm f/4.5 Vario-Elmar-R | 1978 | 2000 |
| 2981001 | 2982000 | 75mm–200mm f/4.5 Vario-Elmar-R | 1979 | 1000 |
| 2991201 | 2991700 | 75mm–200mm f/4.5 Vario-Elmar-R (3-cam) | 1979 | 500 |
| 3004851 | 3006850 | 75mm–200mm f/4.5 Vario-Elmar-R | 1979 | 2000 |
| 3035401 | 3037400 | 75mm–200mm f/4.5 Vario-Elmar-R | 1980 | 2000 |
| 3042601 | 3044100 | 75mm–200mm f/4.5 Vario-Elmar-R | 1980 | 1500 |
| 3053601 | 3054000 | 75mm–200mm f/4.5 Vario-Elmar-R | 1980 | 400 |
| 3058601 | 3059600 | 75mm–200mm f/4.5 Vario-Elmar-R (3-cam) | 1980 | 1000 |
| 3078801 | 3081000 | 75mm–200mm f/4.5 Vario-Elmar-R (3-cam) | 1980 | 2200 |
| 3102501 | 3104000 | 75mm–200mm f/4.5 Vario-Elmar-R | 1981 | 1500 |
| 3136801 | 3138800 | 75mm–200mm f/4.5 Vario-Elmar-R | 1981 | 2000 |
| 3187701 | 3189700 | 75mm–200mm f/4.5 Vario-Elmar-R | 1982 | 2000 |
| 3218001 | 3220000 | 75mm–200mm f/4.5 Vario-Elmar-R | 1982 | 2000 |
| 3225301 | 3227300 | 75mm–200mm f/4.5 Vario-Elmar-R | 1982 | 2000 |
| 3273401^ | 3276400 | 75mm–200mm f/4.5^ Vario-Elmar-R | 1983 | 3000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1978-1983 | 27,100 |
