35mm–70mm f/2.8 Vario-Elmarit-R ASPH
Revision as of 17:03, 30 September 2014 by Tdavis (talk | contribs)
  • Leica Order No. - 11275
  • Production era - 1998-2002 < 1,775 lenses (Overgaard, Westlicht & Schouten all say only 300 lenses produced (Rahn lists 155) - surprising with 1,775 assigned)
  • Number of lenses /groups - 11 / 9
  • F stop range - f/2.8-f/22
  • Closest focusing distance - 70 cm / 2.30 ft
  • Smallest object field - Macro setting 67 x 101 mm /1:2.8
  • Diaphragm setting /type - 8-blade
  • Angle of view diagonal - 64 - 34 degrees
  • Filter type - E77
  • Dimensions (length x diameter) - 133 x 88 mm /5.24 x 3.46 in
  • Weight - 1050 g /2.31 lb
  • Inscription - LEICA VARIO-ELMARIT-R 1:2.8/35-70 ASPH. E77 3XXXXXX
  • Leica Tech Data - 35mm–70mm f/2.8 Vario-Elmarit-R ASPH.pdf - courtesy Summilux.net
35mm–70mm f/2.8 Vario-Elmarit-R ASPH Serial Numbers
3654696 3654715 35mm–70mm f/2.8 Vario-Elmarit-R 1994 20
3812110 3812124 35mm–70mm f/2.8 Vario-Elmar-R 1997 15
3839000 3839999 35mm–70mm f/2.8 Vario-Elmar-R 1998 1000
3890957 3890996 35mm–70mm f/2.8 Vario-Elmar-R 2000 40
3894351 3895050 35mm–70mm f/2.8 Vario-Elmar-R 2000 700
TOTAL ASSIGNED SERIAL NUMBERS 1994-2000 1,775
