I
Revision as of 14:38, 18 October 2014 by Tdavis (talk | contribs)
IASUU Stereo polarizing spectacles in a plastic frame 19??-19?? -
IBSOR Single exposure shutter used with OLEYO and OLIGO housings Forum discussion 1939-19?? NY item
IDCOO M3 leather ready case 1954-1968 -
IFLEX Scientific version of Visoflex I with rotating clear or diffused focusing screen in screw and bayonet versions Fontenelle archive 1953-19?? -
IFSTA Adjustable filter stand copy accessory 1939-19?? -
IGEMO M3 body only 1954-1968 10150
ILNOO Elmar (II) f= 9 cm 1:4 collapsible 19??-19?? -
ILNOO-M 90mm f/4 Elmar collapsible M-mount 1954-1968 -
ILLUM Copy stand 2 pair lamp attachment for 2" diameter column 19??-19?? NY item
ILNUU Stereo projection attachment for twin 85 mm Hektor lenses used with PRADO projectors 19??-19?? -
IMARO M3 (IGEMO) + Elmar (III) f= 5 cm 1:3.5 (ELMAR-M or ELMAM) 1954-1968 -
IMFIN Universal viewfinder knon as "Imarect" ca.1942-19xx NY item
IMOOP MP and MP2 body only 1956-1959 -
IMPUU Stereo projection attachment for twin 50 mm Elmar lenses used with PRADO projectors ca.1956 see Westlicht 22/249
IMPUU
-IZOUU
Stereo projection attachment for twin 50 mm Elmar lenses used with PRADO 250 and 500 projectors 19??-19?? -
INVOO Forum discussion 19??-19?? 00001
IROOA Hood for 35 & 50 mm lenses with E39 mount; black with wide chrome band; earliest engraved "Summicron-" without code word; later versions had "IROOA"; last with catalog number JCB's a little...IIIg - JCB's a little...M3 1959-19?? 12571
IROOW Cap for 28mm f/2.8 Elmarit I and 21mm f3.4 Super-Angulon [1] 1964-1976 14042
IRZOO M-mount adapter for using 35 & 50 mm Leica screw-thread on M-cameras Forum discussion [2] 1956-19?? 14097
see
IRZUU Stereo projection attachment for twin 100 mm Hektor lenses used with PRADO projectors 19??-19?? -
ISAIO M3 (IGEMO) with Summarit f= 5 cm 1:1.5 1954-1968 -
ISBOO M-mount adapter for using 90 mm Leica screw-thread on M-cameras Forum discussion [3] 1956-19?? 14098
see
ISBUU Stereo projection attachment for twin 120 mm Hektor lenses used with PRADO projectors 19??-19?? -
ISOOZ M-mount adapter for using 135 mm Leica screw-thread on M-cameras Forum discussion 1956-19?? 14099
see
ISUMO M3 (IGEMO) with F = 5 cm 1:2 Summicron II 1954-1968 -
ISUMO-N M3 (IGEMO) with F = 5 cm 1:2 Summicron II-DR near focusing range 1954-1968 -
ISUMO-S M3 (IGEMO) with F = 5 cm 1:2 Summicron II-Rigid 1954-1968 -
ITDOO Hood for 3.5 cm Summaron and 5 cm Summicron with narrow chrome band and velvet lining for reverse positioning 1956-1960 Forum discussion
ITOOY Hood for 3 cm Elmar with E39 front flange; early version engraved "Elmar-"; late version with wide chrome band JCB's a little...Ig 1956-19?? 12580
IUFOO Hood for 9 cm Elmar and 135 Hektor; black with narrow chrome band at lens; wider chrome band; all black last version 1956-19?? 12575
IVZOO Cap that screws into M-mount body 19??-19?? 14056
IWKOO Hood for Super-Angulon f= 2.1 cm 1:4 with double trigger fastening Forum discussion 1960-19?? 12502
IXMOO Reloadable metal cassette with chrome tab; new version 1966-19?? 14006
IZQOO Rear dust cover for M-thread lens 19??-19?? 14051
