Leica Tripods and Heads
Revision as of 13:59, 1 November 2014 by Tdavis (talk | contribs)
Name
Order
number
Production era Type Materials Manufacturer's description Exchange plate Pan
and tilt
movement
Weight Height Max. load capacity Accessories included Optional accessories MSRP
DH 1
(Gitzo
G2180)
2009-2012
Review
Compact, low-profile, pan-tilt fluid head with a built-in counter- balance system Light-weight polymer body . . . fine-tuned for use with medium sized spotting scopes, but is also ideal for DSLRs with long lenses and or compact DV camcorders. with 1 /4 in connector 360 degrees
+ 90 to - 90 degrees
570 g
1.3 lb
8.5 cm
3.3 in
approx. 4 kg
8.8 lb
draw-string cloth bag aluminum balance plate for digiscoping
42225
DH 1 sold with Trima or Trica legs (see below)
Ball Head 24
14113
2013-Current 24 mm
0.94 in
pan-lock quick-release ball head
Light-weight polymer body As soon as the right position is found, gentle tightening of two locking screws fixes the ball head precisely in the vertical and horizontal plane. with
1 /4 in connector
3 /8 in bottom thread
360 degrees
227 g
0.5 lbs
8.1 cm
3.2 in
approx. 12 kg
26.5 lbs
draw-string cloth bag 3x set quick release plates
14115
$US 285 at Oct 2013 announcement
Ball Head 38
14114
2013-Current 38 mm
1.5 in
Light-weight polymer body As soon as the right position is found, gentle tightening of two locking screws fixes the ball head precisely in the vertical and horizontal plane. with 1 /4 in connector
360 degrees
436 g
~1.0 lb
9.0 cm
3.5 in
approx. 24 kg
53 lbs
14115
Video Head VH1
42230
2014-Current Swing-arm video head Light-weight polymer body . . . Despite its small size, it guarantees shake-free observation and unique insights into the natural world. with quick-release
1 /4 + 3 /8 in connector plate
360 degrees
draw-string cloth bag $US 249 at Oct 2014 announcement
Video Head VH2
42231
2014-Current Light-weight polymer body . . . provides a stable and secure platform for digiscoping and photography with larger lenses. with quick-release 1 /4 + 3 /8 in connector plate 360 degrees + 90 to - 90 degrees draw-string cloth bag $US 299 at Oct 2014 announcement
  • See TOOUG for other Leica Ball Heads
Name
Order
number
Production era Type Construction Manufacturer's description Max. tripod height Min. tripod height Carrying length Weight Max. load capacity Accessories included Optional accessories MSRP
Trima 1
42224
2009-2012
Review
3-section legs magnesium with foam padded upper leg segments 160 cm
63 in
37 cm
14.6 in
69 cm
27.2 in
1.92 kg
4.2 lbs
DH 1 head (see above)
zip-up padded case
£BP 385 in 2010
$US 534 in 2012
Trica 1
42223
2009-2014
Review
3-section legs carbon fiber with foam padded upper leg segments A stable tripod is essential for a calm and steady view. . . Erecting and folding up is quick and effortless. 175 cm
68.9 in
38 cm
15.0 in
70 cm
27.6 in
2.1 kg
4.6 lbs
zip-up padded case
£BP 539 in 2010
$US 699 in 2014
Traveller Tripod
14101
2013-Current
Forum discussion [1]
3-section legs with removable center column 8-layer carbon fiber legs with spike feet
(not carry-on approved)
The Leica Traveller [sic] Tripod is as light as a feather. . . When collapsed, it's especially small and handy. 151 cm
59.4 in
10 cm
3.9 in
52 cm
20.5 in
1.2 kg
2.65 lbs
10 kg
22 lbs
Limited 2-Year Warranty Cordura zip-up padded case with removable strap
14116
$US 525 at Oct 2013 announcement
C-170 Tripod
42229
2014-Current 3-section legs with 32 cm center column carbon fiber legs with magnesium fittings + foam padded upper leg segments . . . ideal in combination with Leica spotting scopes, binoculars and Leica cameras and are optimized for outdoor use. 195 cm
74.8 in
? cm
? in
63 cm
24.8 in
1.4 kg
3.1 lbs
? kg
? lbs
zip-up padded case with removable strap $US 549 at Oct 2014 announcement
