35mm f/2.4 Summarit-M ASPH.
- Leica Order No. - 11671-black - 11679-silver - red indicates change from 35mm f/2.5 Summarit-M
- Production era - 2014-Current
- Lens mount - Leica M quick-change bayonet with 6 bit lens identification bar code for digital M models
- Number of lenses /groups - 6 /4
- Focusing range - 0.8 m / 2.6 ft < ∞
- Aperture - f/2.4 - f/16 - Setting/Function Preset, with click-stops, half values available; 9-blade
- Smallest object field /Largest reproduction ratio - For 35 mm, approx. 490 x 735 mm /1:20.4 = for LEICA M8, approx. 367 x 551 mm /1:20.4
- Angle of view (diagonal, horizontal, vertical) - For 35 mm (24 x 36 mm) : 63 deg, 54 deg, 38 deg, - for LEICA M8 (18 x 27 mm) : 50 deg, 42 deg, 29 deg, corresponds to a focal length of approx. 47 mm with 35 mm-format
- Position of entrance pupil - (related to the first lens surface in light direction) 9.3 mm
- Filter mount/Lens hood - Non-rotating, internal thread for screw-on filters size E39, external thread with stop for lens hood, protection ring for external thread included in delivery
- Accessories - Replacement hood 12439-black, 12440-silver
- Materials - Anodized aluminum, brass and optical glass
- Length to bayonet flange - approx. 34 mm
- Largest diameter - approx. 52 mm / 2.05 in
- Weight - approx. 197 g / 6.95 oz
- Inscription - 43XXXXX LEICA E 46 SUMMARIT-M 1:2.4 /35 ASPH.
- Leica Tech Data - 35mm f/2.5 Summarit-M.pdf - not revised for f/2.4 series
Leica 35mm f/2.4 ASPH. Summarit-M Serial Numbers
Serial numbers compiled from known lenses| SN Start | SN End | Product | Year | Total |
| -unknown | 4302424- | 35mm f/2.4 ASPH. Summarit-M (black) | 2014 | unknown |
| -4302427 | unknown- | 35mm f/2.4 ASPH. Summarit-M (silver) | 2014 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2014- | unknown |
