28mm f/2.8 Elmarit-R I
Revision as of 16:21, 13 October 2014 by Tdavis (talk | contribs)
  • Order nos. - 11204 - 11247 - 11206-Safari . LLC - 148
  • Production era - 1970-1992 < 50,510 lenses
  • Variants - 2-cam, 3-cam and R-only; black and olive green "SAFARI" version
  • Number of lenses /groups - 8 / 8
  • F stop range - f/2.8 - f/22
  • Closest focusing distance - 30 cm / 11.81 in
  • Smallest object field - 168 x 282
  • Diaphragm setting /type - 8-blade
  • Angle of view diagonal - 76 degrees
  • Filter type - Series 7 filter held in place with hood
  • Accessories - Hood: 12509, Front cap: 14172
  • Dimensions length x diameter - 40 x 63 mm / 1.57 x 2.48 in
  • Weight - 275 g /9.7 oz
  • Inscription - ELMARIT-R 1:2.8/28 LEITZ WETZLAR 2XXXXXX
  • Designer - Rudolf Ruehl - 1970
28mm f/2.8 Elmarit-R I Serial Numbers
^ Lens no. 3491907 is 28mm f/2.8 Elmarit-R I
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf
2411001 2411020 28mm f/2.8 Elmarit-R 1970 20
2440001 2442000 28mm f/2.8 Elmarit-R 1970 2000
2478701 2480700 28mm f/2.8 Elmarit-R 1971 2000
2509601 2511600 28mm f/2.8 Elmarit-R (3-cam) 1972 2000
2531601 2533850 28mm f/2.8 Elmarit-R (2-cam) 1972 2250
2543501 2544500 28mm f/2.8 Elmarit-R 1973 1000
2669451 2671450 28mm f/2.8 Elmarit-R 1974 2000
2724921 2726920 28mm f/2.8 Elmarit-R 1974 2000
2783651 2785650 28mm f/2.8 Elmarit-R 1976 2000
2803401 2805400 28mm f/2.8 Elmarit-R 1976 2000
2827351 2829350 28mm f/2.8 Elmarit-R 1977 2000
2874201 2876200 28mm f/2.8 Elmarit-R (Safari) 1977 2000
2919901 2921900 28mm f/2.8 Elmarit-R (Safari) 1978 2000
2961501 2963500 28mm f/2.8 Elmarit-R (Safari) 1978 2000
2977551 2978550 28mm f/2.8 Elmarit-R 1979 1000
2994701 2996700 28mm f/2.8 Elmarit-R (11 204) 1979 2000
3015651 3017650 28mm f/2.8 Elmarit-R 1980 2000
3038401 3040000 28mm f/2.8 Elmarit-R (11 204) 1980 1600
3084951 3087000 28mm f/2.8 Elmarit-R 1980 2050
3093001 3094500 28mm f/2.8 Elmarit-R 1981 1500
3183701 3185700 28mm f/2.8 Elmarit-R (11 204) 1982 2000
3229301 3231300 28mm f/2.8 Elmarit-R 1982 2000
3269401 3271400 28mm f/2.8 Elmarit-R 1983 2000
3312701 3314700 28mm f/2.8 Elmarit-R 1984 2000
3367051 3370000 28mm f/2.8 Elmarit-R (3-cam) 1985 2950
3429891 3433000 28mm f/2.8 Elmarit-R (11 247) 1987 3110
3491401 ^ 3492000 28mm f/2.8 PC-Super-Angulon-R ^ 1987 [600]
3573134 3574133 28mm f/2.8 Elmarit-R 1991 1000
3583831 3583860 28mm f/2.8 Elmarit-R 1992 30
TOTAL ASSIGNED SERIAL NUMBERS 1970-1992 50,510
Lens superseded by 28mm f/2.8 Elmarit-R II
