Elmar 1:4 / 135mm
Revision as of 18:44, 31 January 2015 by Tdavis (talk | contribs) (→‎Comment)
  • Leica Order No. - 11750, 11850, 11951-head only LLC - 183
  • Production era - 1960-1965, 3282 screw and 20,396 bayonet < 25,900 lenses
  • Type - As camera lens + optical cell unscrews for use with focusing adapter 16464 on Visoflex
  • Number of lenses /groups - 4 /4
  • F stop range - f/4-f/22
  • Closest focusing distance - 1.5 m /4.82 ft
  • Smallest object field - 219 x 321 mm/ 8.75 x 13 in
  • Diaphragm setting /type - 12-blade
  • Angle of view diagonal - 18 degrees
  • Filter type - E39
  • Accessories - Hood: IUFOO 12575; for use with Visoflex see forum discussion [1] below
  • Materials - Clear anodized aluminum and leatheret
  • Dimensions (length to flange x diameter) - 122.7 x 53 mm /4.8 x 2.1 in
  • Weight - 440 g /0.97 lb
  • Inscription - ELMAR 1:4/135 LEITZ WETZLAR 1XXXXXX
  • Designer - Walter Mandler
Elmar 1:4 / 135mm Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf
^ Lens 1825158 is F = 20 cm 1:4 Telyt
1733001 1734000 Elmar 1:4 / 135mm (M+S) 1960 1000
1768001 1771000 Elmar 1:4 / 135mm (M) 1960 3000
1774001 1777000 Elmar 1:4 / 135mm 1960 3000
1801001 1804000 Elmar 1:4 / 135mm (M) 1960 3000
1824001 ^ 1827000 Elmar 1:4 / 135mm (M+S) 1960 1000
1880001 1883000 Elmar 1:4 / 135mm (M+S) 1961 3000
1884001 1884100 Elmar 1:4 / 135mm 1961 100
1890001 1894800 Elmar 1:4 / 135mm (M+S) 1961 4800
1901001 1903000 Elmar 1:4 / 135mm (M) 1961 2000
1906001 1909000 Elmar 1:4 / 135mm (M+S) 1961 3000
1964001 1965000 Elmar 1:4 / 135mm (M) 1962 1000
2007501 2008500 Elmar 1:4 / 135mm (M) 1963 1000
TOTAL ASSIGNED SERIAL NUMBERS 1960-1963 25,900
