Summaron f= 3.5 cm 1:3.5
Revision as of 20:30, 10 October 2014 by Tdavis (talk | contribs) (→Summaron f= 3.5 cm 1:3.5 Serial Numbers)
- Leica Order No. - SOONC, SOONC-M 11105 (1954), SOONC-MW 11107 (1956), SOONC-MT 11305 (1958), SOMWO LLC - 151
- Production era - 1949-1960 Screw-thread; 1956-1960 E39 and M-bayonet; < 122,021
- Variants - A36 and E39; feet or metric scales; M3 versions with or without goggles
- Number of lenses /groups - 6 /4
- F stop range - f/3.5 - 4 - 5.6 - 8 - 11 - 16 - 22
- Closest focusing distance - 1 meter
- Smallest object field - 35 mm
- Angle of view diagonal - 64 degrees
- Filter type - A36 and E39 /A42 versions
- Accessories - Viewfinder: SBLOO 12010; Hood: IROOA 12571, FOOKH 12505; Lens with finder: SOONC-MW for M3; Lens with finder: SOONC-MT for M2; leather case ETILA
- Materials - chrome plated
- Weight - 195 g /6.88 oz
- Inscription - Summaron f = 3.5 1:3.5 Nr. 1xxxxxx Ernst Leitz [GmbH] Wetzlar
- On the street - $US 200 (S) - 575 (M2) - 500 (M3) in 2010
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf* Lens 1290589 is Summarit f= 5 cm 1:1.5 (ELC.S)
** Lens 1176510 is Summaron 3.5 cm 1:3.5 (M)
^ Lens 1148775 & 1148271 are Summaron 3.5 cm 1:3.5 (M)
706001 | 707000 | Summaron 3.5 cm 1:3.5 | 1949 | 1000 |
712001 | 715000 | Summaron 3.5 cm 1:3.5 (S) | 1949 | 3000 |
750001 | 753000 | Summaron 3.5 cm 1:3.5 (S) | 1949 | 3000 |
765001 | 768000 | Summaron 3.5 cm 1:3.5 | 1950 | 3000 |
775001 | 782000 | Summaron 3.5 cm 1:3.5 (S) | 1950 | 7000 |
840001 | 845000 | Summaron 3.5 cm 1:3.5 (S+M3-w/o-specs) | 1951 | 5000 |
880001 | 890000 | Summaron 3.5 cm 1:3.5 (S) | 1951 | 10000 |
956501 | 957500 | Summaron 3.5 cm 1:3.5 | 1952 | 1000 |
972001 | 977000 | Summaron 3.5 cm 1:3.5 (S) | 1952 | 5000 |
1004001 | 1008000 | Summaron 3.5 cm 1:3.5 (S) | 1952 | 4000 |
1015001 | 1020000 | Summaron 3.5 cm 1:3.5 (S) | 1952 | 5000 |
1058001 | 1063000 | Summaron 3.5 cm 1:3.5 (S) | 1953 | 5000 |
1106001 | 1110000 | Summaron 3.5 cm 1:3.5 (S) | 1953 | 4000 |
1148001 | 1148221 | Summaron 3.5 cm 1:3.5 | 1954 | 221 |
1148222^ | 1149100 | ^Elmar 5 cm 1:3.5 | 1954 | [879] |
1149101 | 1151000 | Summaron 3.5 cm 1:3.5 (M3-w/o-specs) | 1954 | 1900 |
1157001 | 1160500 | Summaron 3.5 cm 1:3.5 (S) | 1954 | 3500 |
1175501 | **1178000 | **Summicron 5 cm 1:2 (M) | 1954 | [2500] |
1178501 | 1182000 | Summaron 3.5 cm 1:3.5 (M) | 1954 | 3500 |
1220001 | 1223000 | Summaron 3.5 cm 1:3.5 (S) | 1954 | 3000 |
1224201 | 1228000 | Summaron 3.5 cm 1:3.5 (M+S) | 1954 | 3800 |
1257001 | 1260000 | Summaron 3.5 cm 1:3.5 | 1955 | 3000 |
1272001 | 1275000 | Summaron 3.5 cm 1:3.5 (M3+M) | 1955 | 3000 |
1282001 | 1285000 | Summaron 3.5 cm 1:3.5 (M3) | 1955 | 3000 |
1288001 | *1291000 | Summaron 3.5 cm 1:3.5 (M3+M) | 1955 | 3000 |
1300001 | 1300700 | Summaron 3.5 cm 1:3.5 | 1955 | 700 |
1305501 | 1309000 | Summaron 3.5 cm 1:3.5 (S-chrom) | 1955 | 3500 |
1360001 | 1363000 | Summaron 3.5 cm 1:3.5 (M3.11107.chrom+black-specs) | 1956 | 3000 |
1423001 | 1426000 | Summaron 3.5 cm 1:3.5 | 1956 | 3000 |
1435001 | 1438000 | Summaron 3.5 cm 1:3.5 (M3-chrom) | 1956 | 3000 |
1483701 | 1486000 | Summaron 3.5 cm 1:3.5 (M3+S-chrom) | 1957 | 2300 |
1486701 | 1490000 | Summaron 3.5 cm 1:3.5 (M3-chrom) | 1957 | 3300 |
1518001 | 1521000 | Summaron 3.5 cm 1:3.5 (M3+S-chrom) | 1957 | 3000 |
1552001 | 1557000 | Summaron 3.5 cm 1:3.5 (S+M+M3-chrom+specs) | 1958 | 5000 |
1562001 | 1566000 | Summaron 3.5 cm 1:3.5 (M+M3-chrom.11105) | 1958 | 4000 |
1594001 | 1597000 | Summaron 3.5 cm 1:3.5 (S) | 1958 | 3000 |
1613001 | 1615000 | Summaron 3.5 cm 1:3.5 (S+M-chrom) | 1958 | 2000 |
1638501 | 1640500 | Summaron 3.5 cm 1:3.5 (S+M-chrom) | 1958 | 2000 |
1690501 | 1690800 | Summaron 3.5 cm 1:3.5 | 1959 | 300 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1949-1959 | 122,021 |
