24mm f/2.8 Elmarit-R
Revision as of 16:42, 4 February 2015 by Tdavis (talk | contribs) (→‎Comment)
  • Order nos. - 11221 without ROM, 11257 ROM possible cam-3 only, 11331 with ROM
  • Production era - 1974-2006 < 20,200 lenses
  • Manufacturer - Minolta
  • Variants - 1974-1990 without ROM, 1990-1996 ROM possible, 1996-2006 with ROM
  • Number of lenses /groups - 9 / 7
  • F stop range - f/2.8 - f/22
  • Closest focusing distance - 30 cm / 11.81 in
  • Smallest object field - 374 x 250 mm
  • Diaphragm setting /type - automatic, pre-set
  • Angle of view diagonal - 84 degrees
  • Filter type - Series 8
  • Accessories - Hood: 12506 or 12523; Front cap: 14184 or 14290
  • Materials -
  • Dimension length x diameter - 48.5 x 67 mm / 1.91 x 2.64 in
  • Weight - 420 g /0.93 lb
  • Inscription - ELMARIT-R 1:2.8/24 LEITZ WETZLAR 3XXXXXX
    ELMARIT-R 1:2.8/24 E60 3XXXXXX LEICA
  • On the street - €EU 2,600 in 2006 - $US 350 (2, 3-cam) - 475 (3-cam) - 700 (ROM) in 2010
  • Reviews
    • Puts-R courtesy of Mario Mazziol
  • Forum discussion
24mm f/2.8 Elmarit-R Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf
* Lens 2719257 is 24mm f/2.8 Elmarit-R
2718151 2718650 24mm f/2.8 Elmarit-R 1974 500
2718651* 2721000 *40mm f/2 Summicron-C* 1974 [2350]
2766501 2768000 24mm f/2.8 Elmarit-R 1976 1500
2832351 2834350 24mm f/2.8 Elmarit-R (11 257+221) 1977 2000
2904801 2906800 24mm f/2.8 Elmarit-R (11 221) 1978 2000
3007151 3009150 24mm f/2.8 Elmarit-R (11 221+331) 1979 2000
3071801 3072800 24mm f/2.8 Elmarit-R 1980 1000
3101501 3102500 24mm f/2.8 Elmarit-R 1981 1000
3152501 3153500 24mm f/2.8 Elmarit-R (11 221) 1981 1000
3208801 3209800 24mm f/2.8 Elmarit-R (11 221) 1982 1000
3328201 3329200 24mm f/2.8 Elmarit-R (11 221) 1984 1000
3370001 3371000 24mm f/2.8 Elmarit-R 1985 1000
3404001 3405000 24mm f/2.8 Elmarit-R 1986 1000
3428691 3429690 24mm f/2.8 Elmarit-R 1987 1000
3500201 3501200 24mm f/2.8 Elmarit-R (11 331) 1989 1000
3635401 3635600 24mm f/2.8 Elmarit-R 1993 200
3657831 3658330 24mm f/2.8 Elmarit-R 1994 500
3754126 3754625 24mm f/2.8 Elmarit-R 1996 500
3783830 3784329 24mm f/2.8 Elmarit-R (11 331) 1997 500
3836875 3837374 24mm f/2.8 Elmarit-R 1998 500
3883247 3883746 24mm f/2.8 Elmarit-R 2000 500
3949534 3950033 24mm f/2.8 Elmarit-R 2002 500
unknown unknown 24mm f/2.8 Elmarit-R 2006 unknown
TOTAL ASSIGNED SERIAL NUMBERS 1974-2005 20,200
