35mm f/1.4 ASPH.fle Summilux-M
				Revision as of 20:47, 16 February 2015 by Tdavis (talk | contribs) (→35mm f/1.4 ASPH.fle Summilux-M  Serial Numbers)
- Leica Order No. - 11663-black - 11675-silver (Oct 2014)
 - Production era - 2010-Current
 - Known as - FLE (floating element)
 - Angle of view (diagonal, horizontal, vertical) - For 35 mm format (24 x 36 mm): 63°, 54°, 37°, for M8 & M8.2 (18 x 27 mm): 49°, 42°, 28°, equivalent to approx. 47 mm for 35 mm format
 - Optical design
- Number of lenses/groups - 9 /5
 - Focal length - 35.6 mm
 - Aspherical surfaces - 1
 - Position of entrance pupil - 16.6 mm from the apex of the first lens element
 - Distance settings
- Focusing range - 0.7 m to ∞
 - Smallest object field/ Largest reproduction ratio - For 35 mm format: approx. 418 × 626 mm /1:17.4 (for M8 approx. 313 × 470 mm /1:17.4)
 - Aperture
- Setting/function - f/1.4-16 with click-stops, half values available / 9-blade
 - Mount - Leica M quick-change bayonet with 6-bit bar-coding for digital M-models
 - Filter - Inner threading for E46 screw-in filters, non-rotating front element
 - Accessories - Hood: 12465 Full-metal, rectangular, screw-mount hood (supplied with the lens)
 - Materials - Black and clear anodized aluminum
 - Dimensions and weight
- Length to bayonet flange - Approx. 46 /58 mm (with /without lens hood)
 - Largest diameter - Approx. 56 mm
 - Weight - Approx. 320 g
 - Data from - May 17, 2010 Leica press release
 - Leica Tech Data - 35mm f/1.4 ASPH.fle Summilux-M.pdf - courtesy Summilux.net
- On the street - €EU 3,580-3,890 in 2015
- From Erwin Puts Blog "I am asked quite often what three or four lenses I would select that best represent the Leica philosophy. For this moment in time I would propose the following set:
- Super-Elmar-M 3.4/21mm ASPH
 - Summilux-M 1.4/35 mm ASPH (latest version)
 - Summicron-M 2/75 ASPH
 - Here are the arguments: . . ."
Serial numbers compiled from known lenses~ stolen lens, please report if found on sale
| -4006688 | 4099313- | Summilux-M 35mm f/1.4 ASPH. | 2010 | 92,696+ ~4074699 |
| -4101380 | 4139941- | Summilux-M 35mm f/1.4 ASPH. | 2011 | 38,562+ |
| -4152171 | 4194109- | Summilux-M 35mm f/1.4 ASPH. | 2012 | 41,939+ |
| -4226759 | 4236795- | Summilux-M 35mm f/1.4 ASPH. | 2013 | 10,037+ |
| -4300338 | 4307852- | Summilux-M 35mm f/1.4 ASPH. | 2013 | 7,515+ |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2010- | unknown |
