Elmar (I) f= 5 cm 1:3.5
Revision as of 20:21, 4 August 2015 by Tdavis (talk | contribs)
  • Leica Code /No. – ELMAR, ELMAR CHROM LLC - 113
  • Production era - 1930-1950, 36,000+ lenses
  • Variants - Nickel, chrome, metric, foot, heavy cam 7 o'clock and 11 o'clock bell push (11-BP) versions
  • Lens mount - Screw-thread
  • Number of lenses /groups – 5 /3
  • Aperture range – f/3.5-f/18 & f/16
  • Focusing range – 1 m / 3.28 ft < ∞
  • Smallest object field -
  • Diaphragm setting /type - 10-blade
  • Angle of view (diagonal) - 45 degrees
  • Filter type - A36
  • Accessories – Hood: FISON
  • Weight – 125 g / 4.4 oz
  • Inscription - Leitz Elmar 1:3,5 F=50mm
  • Designer - Max Berek
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf
* Lens 812349 is Elmar 5 cm 1:3.5
-564 892- Elmar 5 cm 1:3.5 (KUP) 1930 unknown
-43114 53034- Elmar 5 cm 1:3.5 (KUP.11) 1930 unknown
-unknown 92939- Elmar 5 cm 1:3.5 (KUP.11) 1930 unknown
-93118 99900- Elmar 5 cm 1:3.5 (KUP.11) 1930 unknown
-122718 124870- Elmar 5 cm 1:3.5 (KUP.11-BP) 1931 unknown
-130248 133506- Elmar 5 cm 1:3.5 (KUP.11-BP+7) 1931 unknown
-144221 151035- Elmar 5 cm 1:3.5 (KUP.7+CHROM.7) 1932 unknown
156501 157000 Elmar 5 cm 1:3.5 1933 500
157001 160000 Elmar 5 cm 1:3.5 (KUP.7) 1933 3000
163101 165000 Elmar 5 cm 1:3.5 (KUP.7) 1933 1900
169001 171000 Elmar 5 cm 1:3.5 1933 2000
172501 176000 Elmar 5 cm 1:3.5 (KUP.7) 1933 3500
179001 182000 Elmar 5 cm 1:35 (KUP.7) 1933 3000
183101 186000 Elmar 5 cm 1:3.5 (CHROM.7) 1933 2900
187001 190000 Elmar 5 cm 1:3.5 1933 3000
200001 205000 Elmar 5 cm 1:35 1934 5000
211101 214000 Elmar 5 cm 1:3.5 1934 2900
222001 225000 Elmar 5 cm 1:3.5 1934 3000
230301 235000 Elmar 5 cm 1:35 1934 4700
242001 245000 Elmar 5 cm 1:3.5 (KUP.7) 1935 3000
253001 256000 Elmar 5 cm 1:3.5 1935 3000
261001 265000 Elmar 5 cm 1:3.5 1935 4000
275001 280000 Elmar 5 cm 1:3.5 (CHROM + KUP.7) 1936 5000
290001 295000 Elmar 5 cm 1:3.5 (KUP.7) 1936 5000
304001 310000 Elmar 5 cm 1:35 1934 6000
311501 315000 Elmar 5 cm 1:35 1934 3500
315101 320000 Elmar 5 cm 1:35 1936 4900
322001 325000 Elmar 5 cm 1:35 1936 3000
327001 332000 Elmar 5 cm 1:35 1936 5000
338001 345000 Elmar 5 cm 1:35 1936 7000
358001 365000 Elmar 5 cm 1:35 1937 7000
390001 400000 Elmar 5 cm 1:35 1937 10000
427001 437000 Elmar 5 cm 1:35 1938 10000
460301 465000 Elmar 5 cm 1:35 1938 4700
473001 480000 Elmar 5 cm 1:35 (CHROM.7) 1938 7000
498001 503000 Elmar 5 cm 1:35 1939 5000
510001 515000 Elmar 5 cm 1:35 1939 5000
533001 538000 Elmar 5 cm 1:35 1939 5500
542001 550000 Elmar 5 cm 1:35 (Luftwaffen) 1940 8000
567101 570000 Elmar 5 cm 1:35 1941 2900
571301 573000 Elmar 5 cm 1:35 (Luftwaffen) 1941 1700
573401 575000 Elmar 5 cm 1:35 1941 1600
582301 583500 Elmar 5 cm 1:35 1942 1200
583501 584500 Elmar 5 cm 1:35 (WH) 1942 1000
591001 592000 Elmar 5 cm 1:35 1942 1000
593501 594500 Elmar 5 cm 1:35 (WH) 1943 1000
595000 596000 Elmar 5 cm 1:35 1945 1001
597001 600000 Elmar 5 cm 1:35 1945 3000
601001 603000 Elmar 5 cm 1:35 1946 2000
609001 610000 Elmar 5 cm 1:35 1946 1000
612001 615000 Elmar 5 cm 1:35 1946 3000
630001 633000 Elmar 5 cm 1:35 1946 3000
633101 635000 Elmar 5 cm 1:35 1947 1900
638001 643000 Elmar 5 cm 1:35 1947 5000
647001 652000 Elmar 5 cm 1:35 1948 5000
670001 675000 Elmar 5 cm 1:35 1948 5000
688001 693000 Elmar 5 cm 1:35 1949 5000
707001 712000 Elmar 5 cm 1:35 1949 5000
727001 732000 Elmar 5 cm 1:35 1949 5000
741001 750000 Elmar 5 cm 1:35 1949 9000
769001 775000 Elmar 5 cm 1:35 1950 6000
790020 790036 Elmar 5 cm 1:35 1950 17
802001 807000 Elmar 5 cm 1:35 1950 5000
810001* 820000 *Summitar f= 5 cm 1:2 1950 [10000]
826001 836000 Elmar 5 cm 1:35 1950 10000
866001 872000 Elmar 5 cm 1:35 1951 6000
893001 898000 Elmar 5 cm 1:35 1951 5000
904001 910000 Elmar 5 cm 1:35 1951 6000
941001 950000 Elmar 5 cm 1:35 1951 9000
TOTAL ASSIGNED SERIAL NUMBERS 1933-1951 36,000
Lens superseded by Elmar (II) f= 5 cm 1:3.5
