Summicron (II) f= 9 cm 1:2
- Leica Order No. - SEEOF, SEEOF-M or SEEOM, 11123-chrom, 11132-head only-ZOOEP, pre-set diaphram, 11133-head only LLC - 175
- Production era - 1963-1976 < 5,430 lenses
- Variants - Black and chrome, f/16, f/22, scalloped focusing knurl (SFK), and preset diaphragm head only (PHO) for use with Visoflex
- Lens mount - Leica Screw-thread, M-bayonet and preset diaphragm in short mount for use with Visoflex
- Number of lenses /groups -
- F stop range - f/2-f/16 or f/22 (early)
- Smallest object field - 24.1 x 36.8 cm / 9.5 x 14.5 in
- Diaphragm setting /type - Click half and full stops, 12-blade
- Filter type - E49
- Accessories - Visoflex adapter ZOOEP 16462; Bellows II adapter UOOZK 16598; Close focus ring OUEPO 16474
- Materials - Clear and black anodized aluminum
- Dimensions length - 112 mm / 4.4 in
- Weight - 685 g /1.51 lb
- Inscriptions - Ernst Leitz Canada Summicron f-9cm 1:2 Nr.158xxxx
LEITZ CANADA 2XXXXXX SUMMICRON 1:2 / 90 - Designer - Walter Mandler
- On the street - $US 600 (M) - 800 (S) in 2010
Summicron (II) f= 9 cm 1:2 Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf*Lens nos. 1745260 & 1745738 are 2/35 Summicron
^ Visoflex 9 cm 1:2 Summicron are in this batch
" Lens 2544666 in R-batch has M-bayonet
1983001 | 1983900 | Summicron f= 9 cm 1:2 (SFK-chrom) | 1963 | 900 |
2025001 | 2026000 | Summicron f= 9 cm 1:2 (SFK-chrom) | 1964 | 1000 |
2068501 | 2069500 | Summicron f= 9 cm 1:2 (SFK-chrom) | 1964 | 1000 |
2150551 | 2151550 | Summicron f= 9 cm 1:2 (SFK-black) | 1965 | 1000 |
2203101 | 2204100 | Summicron f= 9 cm 1:2 (SFK-black) | 1966 | 1000 |
2246051 | 2247150 | Summicron f= 9 cm 1:2 (SFK-black+chrom) | 1967 | 1100 |
2332801 | 2333800 | Summicron f= 9 cm 1:2 | 1969 | 1000 |
2370801 | 2371800 | Summicron f= 9 cm 1:2 (SFK-black) | 1969 | 1000 |
2413101 | 2413600 | Summicron f= 9 cm 1:2 (SFK-black) | 1970 | 500 |
2499651 | 2500650 | Summicron f= 9 cm 1:2 | 1971 | 1000 |
2544501" | 2545700 | Summicron-R" f= 9 cm 1:2 (black) | 1972 | [1200] |
2623601 | 2624600 | Summicron-M f= 9 cm 1:2 (SFK-black) | 1973 | 1000 |
2659451 | 2660450 | Summicron-M f= 9 cm 1:2 (black) | 1973 | 1000 |
2731921 | 2731921 | Summicron f= 9 cm 1:2 | 1974 | 1 |
2731922 | 2731950 | Summicron f= 9 cm 1:2 | 1975 | 29 |
2751051 | 2752050 | Summicron f= 9 cm 1:2 (black) | 1975 | 1000 |
2770201 | 2771200 | Summicron-M f= 9 cm 1:2 | 1976 | 1000 |
2791651 | 2792650 | Summicron-M f= 9 cm 1:2 (black) | 1976 | 1000 |
2813401 | 281800 | Summicron-M f= 9 cm 1:2 | 1976 | 400 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1963-1976 | 5,430 |
Lens superseded by 90mm f/2 Summicron-M III
