Epson SureColor P600
Revision as of 20:23, 15 August 2015 by Tdavis (talk | contribs) (Created page with "500px *'''Technology''' **'''Printing Method''' - Epson Micro Piezo print head **'''Nozzle Configuration''' - 180 Nozzles Black, 180 Nozzles per Color **...")
  • Technology
    • Printing Method - Epson Micro Piezo print head
    • Nozzle Configuration - 180 Nozzles Black, 180 Nozzles per Color
    • Minimum Droplet Size - 2 pl, With Variable-Sized Droplet Technology
    • Ink Technology - UltraChrome HD
    • Printing Resolution - 5,760 x 1,440 DPI
    • Category - Consumer
  • Print
    • Printing Speed - 44 Seconds per 10 x 15 cm photo (Epson Premium Glossy Photo Paper)
    • 6 Pages /min Color - (plain paper 75 g/m2)
    • 6 Pages /min Monochrome - (plain paper 75 g/m2)
    • Colors - Vivid Light Magenta, Vivid Magenta, Yellow, Light Cyan, Cyan, Matte Black, Photo Black, Light Light Black, Light Black
  • Paper / Media Handling
    • Number of paper trays - 3
    • Paper Formats - A3+, A3, A4, A5, Letter, Letter Legal, Postcard, 9 x 13 cm, 10 x 15 cm, 13 x 18 cm, 13 x 20 cm, 20 x 25 cm, 100 x 148 mm, User defined
    • Duplex - Manual
    • Print Margin - 0 mm top, 0 mm right, 0 mm bottom, 0 mm left (Wherever margin is defined. Otherwise 3mm top, left, right, bottom.)
    • Automatic Document Feeder - Standard (built-in)
    • Compatible Paper Thickness - 0.08 mm - 1.3 mm
    • Media Handling - Auto Sheet Feeder, Borderless print, CD/DVD print, Fine Art Paper Path, Roll Paper, Thick Media Support
  • General
    • Energy Use - 0.3 Watt (Power off), 1.4 Watt (sleep mode), 20 Watt (printing)
    • Supply Voltage - AC 220 V - 240 V,50 Hz - 60 Hz
    • Product dimensions - 616 x 369 x 228 mm (Width x Depth x Height)
    • Product weight - 15 kg
    • Noise Level - 48.2 B (A) according to ISO 7779 pattern with Epson Premium Glossy Photo Paper / Photo RPM mode
    • Compatible Operating Systems - Mac OS X 10.6.8 or later, Microsoft Windows Vista (32/64 bit), Microsoft Windows XP (Home Edition / Prof / Prof X64 / Vista), Windows 7, Windows 7 x64, Windows 8 (32/64 bit), Windows 8.1, Windows 8.1 x64 Edition
    • Included Software - Epson Easy Photo Print, Epson Print CD, EpsonNet Config, EpsonNet Print, EpsonNet setup
    • Interfaces - WiFi, Ethernet, USB
    • WLAN Security - WEP 64 Bit, WEP 128 Bit, WPA PSK (TKIP), WPA PSK (AES)
    • Mobile and Cloud printing services - Epson Connect (iPrint), Apple AirPrint, Google Cloud Print
    • What's in the box - Driver and utilities (CD), Individual Ink Cartridges, Main unit, Power cable, Quick Setup Guide, Warranty Documents, WiFi/network setup guide
  • Other Features
    • LCD screen - Type: Colour, Touch-panel, Diagonal: 6.8 cm
    • Warranty - 12 months Carry in
