Epson SureColor P600
- Printer name & order no. - SureColor P600; C11CE21201
- Production era - 2015-current
- Technology
- Printing Method - Epson Micro Piezo print head
- Nozzle Configuration - 180 Nozzles Black, 180 Nozzles per Color
- Minimum Droplet Size - 2 pl, With Variable-Sized Droplet Technology
- Ink Technology - UltraChrome HD
- Printing Resolution - 5,760 x 1,440 DPI
- Category - Consumer
- Print
- Printing Speed - 44 Seconds per 10 x 15 cm photo (Epson Premium Glossy Photo Paper)
- 6 Pages /min Color - (plain paper 75 g/m2)
- 6 Pages /min Monochrome - (plain paper 75 g/m2)
- Colors - Vivid Light Magenta, Vivid Magenta, Yellow, Light Cyan, Cyan, Matte Black, Photo Black, Light Light Black, Light Black
- Paper / Media Handling
- Number of paper trays - 3
- Paper Formats - A3+, A3, A4, A5, Letter, Letter Legal, Postcard, 9 x 13 cm, 10 x 15 cm, 13 x 18 cm, 13 x 20 cm, 20 x 25 cm, 100 x 148 mm, User defined
- Duplex - Manual
- Print Margin - 0 mm top, 0 mm right, 0 mm bottom, 0 mm left (Wherever margin is defined. Otherwise 3mm top, left, right, bottom.)
- Automatic Document Feeder - Standard (built-in)
- Compatible Paper Thickness - 0.08 mm - 1.3 mm
- Media Handling - Auto Sheet Feeder, Borderless print, CD/DVD print, Fine Art Paper Path, Roll Paper, Thick Media Support
- General
- Energy Use - 0.3 Watt (Power off), 1.4 Watt (sleep mode), 20 Watt (printing)
- Supply Voltage - AC 220 V - 240 V,50 Hz - 60 Hz
- Product dimensions - 616 x 369 x 228 mm (Width x Depth x Height)
- Product weight - 15 kg
- Noise Level - 48.2 B (A) according to ISO 7779 pattern with Epson Premium Glossy Photo Paper / Photo RPM mode
- Compatible Operating Systems - Mac OS X 10.6.8 or later, Microsoft Windows Vista (32/64 bit), Microsoft Windows XP (Home Edition / Prof / Prof X64 / Vista), Windows 7, Windows 7 x64, Windows 8 (32/64 bit), Windows 8.1, Windows 8.1 x64 Edition
- Included Software - Epson Easy Photo Print, Epson Print CD, EpsonNet Config, EpsonNet Print, EpsonNet setup
- Interfaces - WiFi, Ethernet, USB
- WLAN Security - WEP 64 Bit, WEP 128 Bit, WPA PSK (TKIP), WPA PSK (AES)
- Mobile and Cloud printing services - Epson Connect (iPrint), Apple AirPrint, Google Cloud Print
- What's in the box - Driver and utilities (CD), Individual Ink Cartridges, Main unit, Power cable, Quick Setup Guide, Warranty Documents, WiFi/network setup guide
- Other Features
- LCD screen - Type: Color, Touch-panel, Diagonal: 6.8 cm
- Warranty - 12 months Carry in
