Summarit-S 70mm f/2.5 ASPH
Revision as of 16:07, 13 August 2015 by Tdavis (talk | contribs) (→Summarit-S 70mm f/2.5 ASPH Serial Numbers)
- Order numbers - 11055 - 11051 (CS version with Central Shutter)
- Production era - 2009- (CS Oct 2012 - 100 yr 2014)
- Lenses/groups - 8/6 + 1 protective filter (1 aspherical surface)
- Optical design - Floating element focusing*
- Image angle (diagonal, horizontal, vertical) - approx. 42°, 35,5°, 24°, approx. corresponds to 56 mm in 35 mm-format
- Aperture range - 2.5 to 22
- Shortest distance - 0.5 m
- Largest image scale - 1:4.7
- Filter thread size - 82 mm
- Dimensions (diameter/length) - 90 mm/93 mm
- Weight: 740 g (CS: 890 g)
- Inscriptions
- LEICA - SUMMARIT-S 1:2.5/70 ASPH. - E82 - 4XXXXXXX
- LEICA - SUMMARIT-S 1:2.5/70 ASPH. CS - E82 - 4XXXXXXX
- Accessories included - Lens Hood : 12401 - Rear lens cover : 16020 - Lens cover S : 16019
- Leica Tech Data - Summarit-S 70mm f/2.5 ASPH.pdf - courtesy Summilux.net
Serial numbers compiled from known Summarit-S 70mm f/2.5 ASPH lenses| SN Start | SN End | Product | Year | Total |
| -4073803 | 4073853- | Summarit-S 70mm f/2.5 ASPH | 2009 | 51+ |
| -4090382 | 4094470- | Summarit-S 70mm f/2.5 ASPH | 2010 | 4,089+ |
| -4095883 | 4106254- | Summarit-S 70mm f/2.5 ASPH | 2011 | 10,372+ |
| -4120905 | 4122213- | Summarit-S 70mm f/2.5 ASPH (CS) | 2011 | 1,299+ |
| -unknown | 4248210- | Summarit-S 70mm f/2.5 ASPH (CS-100) | 2014 | unknown |
| -4752103 | unknown- | Summarit-S 70mm f/2.5 ASPH (CS) | 2012 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2009-Current | unknown |
