STUVWXYZ
SAIOO | "Sports" viewfinder for Hektor f= 7.3 cm 1:1.9 lens | ? | - |
SAMWO | F = 3.5 cm 1:2 Summicron I for M3 | 1958-1969 | 11 108 - 9,557 pieces |
SAWOM | 35mm f/2 Summicron II for M2 | 1958-1969 | 11 308 – 11,935 pieces |
SAWOO | Summicron (I) f= 3.5 cm 1:2 | 1958-1963 | 11 008 ~500 pieces |
SBLOO | Finder for SOONC-M Summaron f= 3.5 cm 1:3.5 | ca.1956-1960 | - |
SCNOO | Rapid winder for Leica IIIa (model G), Leica IIIb | ca.1937 | - |
SEROO | "Sports" viewfinder for 9 cm lens | ? | - |
SEOOF | Summicron (I) f= 9 cm 1:2 | 1959-1962 | |
SEOOF-M | Summicron (I) f= 9 cm 1:2 | made in Canada only | |
SEOOM | Summicron (II) f= 9 cm 1:2 | 1959-1979 | - |
SGVOO | 90mm viewfinder/bright finder (12025) | 1951-? | - |
SIMOM | Summaron f= 35 mm 1:2.8 for M3 | 1958-1974 | - |
SIMOO | Summaron f= 3.5 cm 1:3.5 | 1958-1963 | - |
SIMOW | Summaron f= 35 mm 1:2.8 for M2 | 1958-1974 | - |
SIUUB-Glas | Parvo 100 / Prado 100 projector with Hektor 2.5/8.5cm | 1949-1950 | - |
SLOOZ | Viewfinder, 28 mm, black or chrome | 1960-? | 12007 |
SMUUY | Parvo 100 / Prado 100 projector with condenser I (f. 7.3-10cm) | 1949/ 1950 | - |
SNOOX | Summaron f= 2.8 cm 1:5.6 | 1955-1963 | - |
SOMKY | Close focus accessory for collapsible version of the Summicron or Elmar 50mm lens, and with the front element of the fixed Summicron with the use of an adapter called UOORF | ? | also called SOOKY-M |
SOMNI | Summicron (II) f= 5 cm 1:2 | 1956-1968 | 11 818 |
SOOBK | Hood for Summaron f= 2.8 cm 1:5.6 | ? | - |
SOOCX | Summarex f= 8.5 cm 1:1.5 | 1948-1960 | - |
SOODL | Viewfinder, 50 mm | ca.1950 | - |
SOOHN | Hood for Hektor f= 2.8 cm 1:6.3 | ? | - |
SOOIA | Summarit f= 5 cm 1:1.5 | 1949-1960 | - |
SOOIA-M | F = 5 cm 1:1.5 Summarit | 1952-? | |
SOOIC | Summicron (I) f= 5 cm 1:2 | 1953-1960 | - |
SOOKY | Close focus accessory for rangefinder Elmar 5c lens with parallax | ? | - |
SOOKY-M | See SOMKY | ? | - |
SOOME | Summilux (I) f= 5 cm 1:1.4 | 1959-1961 | - |
SOONC | Summaron f= 3.5 cm 1:3.5 | 1948-1960 | - |
SOONC-M | Summaron f= 3.5 cm 1:3.5 | 1956-1960 | - |
SOONC-MW | Summaron f= 3.5 cm 1:3.5 with viewfinder for the M3 | 1956-1960 | - |
SOONC-MT | Summaron f= 3.5 cm 1:3.5 with viewfinder for the M2 | 1957-1960 | - |
SOORE | Summitar f= 5 cm 1:2 | 1939-1955 | - |
SOOZI | Summicron (I) f= 9 cm 1:2 | 1957-1959 | - |
SUMAR | Summar f= 5 cm 1:2 | 1933-1940 | - |
SUOON | Super-Angulon f= 2.1 cm 1:4 | 1958-1963 | - |
SUUHN | Parvo 100 / Prado 100 projector with condenser II (f. 5cm Summar/ Sumwithar) | 1949-1950 | - |
SUUAI | Parvo 100 / Prado 100 projector with condenser III (f. 5cm Elmar/ Summar) | 1949-1950 | - |
SUUZI | Film strip holder for projectors | 1952 | - |
SYEOO | "Sports" viewfinder for 13.5 cm lens | ? | - |
SYOOM | Rapid winder for Leica IIIf or Leica IIIg | ca.1953 | - |
TLCOO | F = 40 cm 1:5 Telyt II | 1956-1966 | - |
TELOO | F = 20 cm 1:4 Telyt | 1956-1966 | - |
TOODY | Thambar f= 9 cm 1:2.2 | 1935-1939 | - |
TUVOO | Attachment for VIOOH viewfinder for 2.8 cm lenses | ? | - |
UCEGU | Pradovit I with Dimaron 2.8/100mm | 1960 | - |
UCFKU | Pradovit I with Colorplan 2.5/90mm | 1960 | - |
UCNXU | Pradovit f with Dimaron 2.8/100mm | 1960 | - |
UCPLU | Pradovit f with Colorplan 2.5/90mm | 1960 | - |
UCWQU | 1960 | - | |
UDCBU | Pradovit f with Dimaron 2.8/150mm | 1960 | - |
UDLSU | 1960 | - | |
UMHDU | Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable | 1960 | - |
UMIQU | Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable | 1960 | - |
UMKHU | Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable | 1960 | - |
UMLKU | Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable | 1960 | - |
UMNOU | Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable | 1960 | - |
UCHRU | Protective metal hood for Pradovit I | 1960 | - |
UCSHU | Remote control cable 4m long | 1960 | - |
UGPXU | Remote control cable 10m long | 1960 | - |
UGQZU | Remote control cable 15m long | 1960 | - |
UGRBU | Remote control cable 20m long | 1960 | - |
UDGKU | Plywood case for projector plus accessories and 150mm lenses | 1960 | - |
UEOXU | Slide magazine for 30 slides | 1960 | - |
UFBXU | 5 magazine cassette | 1960 | - |
UDWPU | Transparent container for 2 slide magazines | 1960 | - |
UDXRU | Transparent containers with 2 magazines | 1960 | - |
UFTGU | 2 slide magazines for 50 slides incl. cardboard | 1960 | - |
UDKQU | Second heat protection filter, including 500-watt lamp | 1960 | - |
UKGDU | Synchronous circuit with tape | 1960 | - |
UHPWU | Multiple connector for tape device and cable | 1960 | - |
UOOND | Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW | ? | 16596 |
UOOPE | Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb | ? | - |
UOORE | Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M | ? | 16508 |
UOORF | Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY | 1960 | 16508 |
UOOST | UOOYW + UOOVH | ? | - |
UOOVH | Lens adapter ring for the head of Hector and Elmar 135mm | ? | 16580 |
UOOWV | Lens Adapter Ring for heads and the Elmarit 90mm Elmar | ? | 16585 |
UOOXI | Adapter Ring Lens fü the head of the 125mm Hektor | 1958 | 16572 |
UOOYW | Bellows connecting ring for I and II | ? | 16590 N |
UOOZK | Adapter ring for the head of the Summicron 90 mm | 1960 | 16598 |
UOSWU | Horizontal slider for Prado S and SM | ? | - |
UUOYW | Adapter ring and tube | ? | - |
UYOOQ | Fiber case with Visoflex I, bellows and accessories | ? | - |
VEZUK | Curved lateral holder to support the camera when used vertically | ca.1933 | - |
VIDEO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 10.5cm lenses | 1932-1933 | black |
VIDOM | Universal viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image | 1933-1939 | |
VIEFF | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
VIEME | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 13.5cm lenses | 1932-1933 | black |
VIFUR | Small, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1933-1936 | black or chrome |
VIGEH | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
VIHEU | Small, torpedo shaped finder for 3.5cm, 5cm lenses | 1932- | black |
VILLO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
VIKAN | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
VIOOH | Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm | 1940-1964 | reaches 2.8 cm with TUVOO add-on |
VISET | Torpedo shaped finder for 3.5cm, 5cm, 9cm, 13.5cm lenses | 1932-1933 | black |
VISAX | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1932-1933 | black |
VISET | Small, torpedo shaped finder for 3.5cm, 9cm, 13.5cm lenses | 1932-1933 | black |
VISOR | The first, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1931-1931 | black |
VISSI | Small, torpedo shaped finder for 3.5cm, 9cm lenses | 1932-1933 | black |
VITRE | Small, torpedo shaped finder for 3.5cm, 5cm, 10.5cm lenses | 1933-1936 | black or chrome |
VIUNA | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm lenses | 1933-1936 | black or chrome |
VIZWO | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1933-1936 | black or chrome |
WINKO | Angle viewfinder for Standard Leica (model E) early versions have a larger eyecup | 1929- | black or chrome |
WINTU | Angle viewfinder for Leica II, III & IIIa with swing-in prism for right angle focus | 1933- | black or chrome |
WOOLD | Angle viewfinder for Standard Leica (model E) with additional interior prism | 1938- | black or chrome |
WOOSU | Angle viewfinder for Leica II, III & IIIa with swing-in prism for right angle focus with additional interior prism | 1938- | black or chrome |
XEMOO | Xenon f= 5 cm 1:1.5 (Schneider) | 1936-1950 | - |
XOONS | Lens hood for Summarit 1:1.5 / 5 cm | ? | - |
YAROB | Magnifying lens | ? | - |
ZOOEP | Short, chrome focusing mount for the Summicron M 2/90 mm to Visoflex II / III | 16462 |
