KL
Revision as of 15:31, 13 September 2009 by Admin (talk | contribs)
KGOON Large ball and socket head; pre-war version had short body; later models have cross bar for connection leverage with combined 1/4 - 3/8" screw threads; 1959 version has a smooth wingnut; replaced by part #14121 1936-1964 14115
KINOR Cine model viewfinder for 15, 25, 50, 75 & 100 mm ca.1983 -
KINSU Cine model viewfinder for 15-150 mm; like VIDOM with rubber eyecup and bracket for cine camera mounting 1934-1982 -
KOOAS Dark slide for OLEYO/OLIGO single exposure housing 1934-1982 -
KOOBF Film cassette for Leica 250 (models DD, FF & GG) 1933-1937 -
KOOBG Film cassette for Leica 250 (models DD, FF & GG) 1938-1953 -
KOOCT M1 1959-1964 10125
KOOHE M2 1957-1968 -
KOVIR Large transparency printer 1933-1956 -
KOVIS Large transparency printer 1957-1957 -
KOVIZ Large transparency printer 1958-1959 -
LEDYD Early exposure meter known as "Leicascope" for the NY market; a separate, small, adjustable lens group not intended for camera mounting ca.1934 -
LEDZH Early exposure meter known as "Weston Model 627" for the NY market (superseded by the improved "Weston Model 617" and the smaller "Model 650" of 1936) ca.1934 -
LEANEKALB Leica I (model A) with calfskin cover and Elmar (I) f= 5 cm 1:3.5 lens 1925-1936 -
LECOM Compur Leica (model B) with ETROS carrying case ca.1931 from 1931 Leica catalog
LECUR Compur Leica (model B) body 1926-1941 -
LEICA Leica I (model A) with Anastigmat or Elmax lens 1925 -
LELUX Leica I (model A) gold plated, lizard skin cover with ELMAR Anastigmat lens 1930 -
LEMAX Standard Leica (model E) body 1932-1933 later named ALVOO
LENEU Leica I (model C) body 1930-1933 -
LFVOO Large field 5x bayonet magnifier for focusing stage; postwar version was conical and later black ca.1938-1948 -
LGCOO Simple 5x bayonet magnifier for focusing stage ca.1938 -
LKIOO Large field angular 5x bayonet magnifier for focusing stage ca.1938-1944 -
LKOOM Leica 72 (18 x 24 mm) 1957-1963 -
LOOEL Leica IIf with ELMAR lens 1951-1956 from 1955-58 catalog
LOOMY Leica 250 (models DD, FF & GG) body 1933-1953 -
LOOCG Simple 5x slip-on magnifier for focusing stage ca.1936 -
LOOFV 5x slip-on magnifier for focusing stage ca.1936 -
LOOGI 5x right-angle slide-in magnifier for focusing stage ca.1936 -
LOOHW Leica IIIc postwar body 1946-1951 -
LOOHW 30x slip-on magnifier for focusing stage ca.1936 -
LOOIT Leica IIIf with SOOIC lens 1951-1956 from 1955-58 catalog
LOOSE Leica IIf body 1951-1956 from 1955-58 catalog
LOOTP Leica IIId body 1939-1947 -
LOOYE Leica 250 (models DD, FF & GG) with Elmar (I) f= 5 cm 1:3.5 1933-1953 -
LSZOO Two light-excluding rings for connecting a microscope to a rotating focusing stage ca.1936 -
LUFAS Object stage for photographing small objects ca.1939 -
LUOON Leica IIf with SOOIC lens 1951-1956 from 1955-58 catalog
LVFOO Visoflex 5x vertical eyepiece 1951-1962 16486
LWHOO 30x bayonet magnifier for focusing stage ca.1938 -
LYCAN Leica II (model D) early body, black 1932-1934 -
LYKEH Leica II (model D) with Hektor f= 5 cm 1:2.5, black 1932-1934 -
LYKUP Leica II (model D) with Elmar (I) f= 5 cm 1:3.5, black 1932-1933 ABOOT 1934-1948
LYDRO Leica III (model F) black body ca.1933 from the 1933 Leica catalog
