F
Revision as of 19:58, 15 September 2009 by Admin (talk | contribs)
FARBA ELW Afgacolor filter 301 for "taking" lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 1934-1935 -
FARLY FARUX Scale ring for Elmar 13.5 cm or Hektor f= 7.3 cm 1:1.9 ca.1933 -
FAROS FARUX Scale ring for Elmar (I) f= 5 cm 1:3.5 ca.1933
FARPU ELW Afgacolor filter 351 for projection lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 1934-1935 -
FARUX Panoramic tripod head 1933-1936 -
FASKI FARUX Scale ring for Elmar f= 10.5 cm 1:6.3 ca.1933
FAVOO No. 2 medium yellow filter; screw-on type H ca.1935 -
FAWAG FARUX Scale ring for Hektor f= 7.3 cm 1:1.9 ca.1933
FAXIS FARUX Scale ring for Elmar (I) f= 9 cm 1:4 ca.1933
FAZOY No. 3 dense yellow filter; screw-on type H; superseded by OBOOE in 1939 ca.1933-1938 NY item
FBOOK UVa filter; screw-on type H ca.1935 -
FBXOO Panchromatic green no. 1 filter; screw-on type H ca.1935 -
FCKOO Single film holder for Ic, IIc, IIf, IIIc, IIIf to sn. 590681 1951-1960 -
FCOOI No. 2 medium infra-red filter; screw-on type H ca.1935 -
FCZOO No. 1 light infra-red filter; screw-on type F ca.1931 -
FDOOH No. 3 dark infra-red filter; screw-on type G ca.1935 -
FEARM Copy arm used with FESSA base and FEHUN column 1931-19?? -
FEDOO No. 1 light infra-red filter; slip-on type A36 ca.1931-1950 13040
FEFFU Copy base and column, used with FILUM arm and STALI lighting = FEPRO 1931-19?? -
FEHUN Column support used with FESSA base and FEARM 1931-19?? -
FEOOG No. 3 dark infra-red filter; slip-on type A36 ca.1935 13050
FEPRO Copy stand with FEFFU base, column, FILUM arm and STALI lighting 1931-19?? used with front lenses 2 & 3, WICAP and WINKO
FESSA Copy base used with FEHUN column and FEARM 1931-19?? -
FESTO Copy stand with FESSA or FEHUN column and FEARM with STALLI lighting 1931-19?? used with front lenses 1, 2 or 3, WICAP and WINKO
FGHOO Replacement hood for Hektor f= 7.3 cm 1:1.9 1936-1946 -
FGOOE No. 1 light infra-red filter; screw-on type I ca.1933 -
FHKOO Single film holder for I, II, III, IIIa, IIIb1 1935-1960 -
FHOOD No. 3 dark infra-red filter; screw-on type I ca.1935 -
FIAKU Small ball and socket tripod head; nickel plated until 1936; earliest had dished camera support plate 1926-19?? -
FIALT Holder for film handling during the development process 1930's -
FIAMA Panoramic tripod head for 5 cm lens 1926-19xx -
FIARO Stereoly slide bar 75 mm long 1926-1926 -
FIATE Stereoly slide bar 150 mm long; early version had center tripod bush; later versions with off-center tripod bush 1926-1940 -
FIAVI Angle bracket to support camera on panorama head 1929-19?? -
FIBLA Small canister spirit level for camera top shoe or on FIAVI for vertical pictures; replaced by DOOLU in 1936 1929-1935 -
FIBOB No. 2 medium infra-red filter; screw-on type G ca.1933 -
FIBOS Leather neck strap with metal snap hooks for cameras with side lugs 1936-ca.1950 -
FICAT No. 1 light yellow filter; screw-on type F ca.1930 -
FICFA Kodachrome type A filter; ADFIK 34 mm mount ca.1949- -
FICHR Kodachrome flash filter; slip-on type A36 ca.1949- -
FICOM No. 2 medium yellow filter; screw-on type F ca.1930 -
FICOR Panchromatic green no. 2 filter; slip-on type A36 ca.1945 NY item
FICUR No. 3 dense yellow filter; screw-on type F; ca.1930 -
FIDAY Kodachrome type F filter; screw-on type L ca.1959- -
FIDAYMI Kodachrome type A filter; screw-on type E39 ca.1949- NY item
FIDRI Shutter release cable, 10 feet long 1931-19?? -
FIEKT Polarising filter; swing-out, slip-on type C with clamping screw ca.1939 NY item
FIFLO Kodachrome photo-flood filter; screw-on type L ca.1949- NY item
FIFLOMI Kodachrome photo-flood filter; screw-on type E39 ca.1949- NY item
FIGAM No. 2 medium yellow filter; slip-on type A36 ca.1931-1950 -
FIGDA Panchromatic green no. 2 filter; ADFIK 34 mm mount ca.1945 NY item
FIGIL Graduated Yellow filter; slip-on type C ca.1931 -
FIGON Adaptor for FISUM polarising filter on Contax 1949-19?? NY item
FIGRO No. 1 light yellow filter; slip-on type A36 ca.1931-1950 13005
FIGUN No. 1 light yellow filter; ADFIK 34 mm mount ca.1945 NY item
FIHAZ Kodachrome haze filter; screw-on type L ca.1949- NY item
FIHEL No. 0 very light yellow filter; slip-on type A36 ca.1933 13000
FIIRL No. 1 light infra-red filter; ADFIK 34 mm mount ca.1949- NY item
FIKAT Kodachrome type A filter; slip-on type A36 ca.1949- NY item
FIKHA Kodachrome type A filter; ADFIK 34 mm mount ca.1949- NY item
FIKLO Kodachrome photo-flood filter; slip-on type A36 ca.1949- NY item
FIKOZ Kodachrome haze filter; slip-on type A36 ca.1949- NY item
FIKUS Extendable hood for 4 focal lengths: 3.5-13.5; early black & nickel; later black & chrome; NY all chrome version 1933-1965 12530
FIKYB No. 2 medium infra-red filter; slip-on type A36 ca.1933-1950 -
FILBY No. 1 light yellow filter; slip-on type A ca.1926 -
FILCA Film cassette originally for Leica I (model A) only; center spool with locking device introduced in 1939; postwar with shiny brown finish 1925-1954 -
FILES Enlarger used with FILUM arm, FEFFU base and column with lenses 2 & 3 1931-19?? -
FILGE No. 2 medium yellow filter; slip-on type A ca.1925 -
FILOY Enlarger used with FILUM arm, FEFFU base and column with front lenses 2 & 3 1931-19?? -
FILPO Polarising filter; swing-out, slip-on type A36 with clamping screw ca.1939 NY item
FILSO No. 1 light yellow filter; slip-on type C ca.1933 -
FILTU No. 3 dense yellow filter; slip-on type A ca.1925-1926 -
FILUM Copy arm (camera bracket) used with FEFFU base and column and STALI lighting = FEPRO 1931-19?? -
FILXA No. 3 dense yellow filter; screw-on type I ca.1933 -
FILYT Enlarger or copying device used with FEARM arm, FESSA or FEHUN base and column with front lenses 2 & 3 1931-19?? -
FIMOO No. 0 very light yellow filter; screw-on type H ca.1935 -
FINON Polarising filter; swing-out, screw-on type E41 with clamping screw ca.1939 NY item
FINOT Shutter release cable, 10 inches long 1931-19?? -
FINOW Shutter release cable, 10 inches long; metal sheathed 1939-19?? NY item
FINUS No. 3 dense yellow filter; screw-on type G ca.1931 NY item
FIOKO UVa filter; screw-on type F ca.1931 -
FIOLA UVa filter; slip-on type A36 ca.1931 13055
FIOMU No. 2 medium infra-red filter; slip-on type C ca.1933 -
FIONA Orange filter; ADFIK 34 mm mount ca.1945-1950 NY item
FIOOC No. 1 light yellow filter; screw-on type H ca.1935 -
FIOPY No. 0 very light yellow filter; slip-on type C ca.1933 -
FIORE UVa filter; screw-on type G ca.1931 -
FIOSI UVa filter; slip-on type C ca.1933 -
FIOUX FSEOO Orange filter; slip-on type A36 ca.1939 NY item
FIPAN ? 19xx-19xx -
FIPHO Kodachrome photo flood filter; ADFIK 34 mm mount ca.1949- NY item
FIPLO No. 2 medium infra-red filter; screw-on type I ca.1933 -
FIPOS Panchromatic green no. 1 filter; slip-on type A36 ca.1933-1950 13015
FIPPA No. 2 medium yellow filter; slip-on type C ca.1933 -
FIQUX Orange filter; slip-on type A36 ca.1939-1950 NY item
FIRAD Graduated Yellow filter; slip-on type A36 ca.1931 -
FIRCO Intermediate collar for using a slip-on filter for Compur Leica (model B) 1931-19?? -
FIREG No. 1 light yellow filter; screw-on type I ca.1933 -
FIRGI Intermediate collar for using a slip-on filter in conjunction with supplementary lenses 1931-19?? -
FIRHE No. 1 light yellow filter; screw-on type G ca.1931 13001
FIRHU Rear dust cover for screw lenses 1939-ca.1954 -
FIRMY No. 2 medium yellow filter; screw-on type G ca.1931 -
FIROL Adaptor for FILPO polarising filter on Rolleiflex or Rolleicord 1949-19?? NY item
FIRYX Panchromatic green no. 1 filter; screw-on type I ca.1933 -
FISAP Panchromatic green no. 1 filter; slip-on type C ca.1933 -
FISEX Shutter release cable, 20 feet long 1931-19?? -
FISKF Kodachrome skylight filter; slip-on A36 mount ca.1954- NY item
FISON Hood for 5 cm ELMAR 1925-1963; black cylinder with rectangular aperture until 1933 when changed to round aperture; last version was chrome with set screw 12510
FISUM Polarising filter; swing-out, screw-on type L with clamping screw ca.1939 NY item
FISUMMI Polarising filter; swing-out, screw-on type E39 with clamping screw ca.1939 NY item
FITAF Kodachrome type A filter; ADFIK 34 mm mount ca.1949- NY item
FITWO No. 2 yellow filter; ADFIK 34 mm mount ca.1945 NY item
FIUNS No. 0 very light yellow filter; slip-on type A ca.1933 -
FIVPL Complete unit for surgical operation photography with cast iron base and rack and pinion movement 1939-19??
FIWAS No. 0 very light yellow filter; screw-on type I ca.1933 -
FIWET UVa filter; screw-on type I ca.1933 -
FIWIG No. 2 medium yellow filter; screw-on type I ca.1933 -
FIXIO Panchromatic green no. 1 filter; screw-on type G ca.1933 -
FIXTA No. 0 very light yellow filter; screw-on type G ca.1933 -
FKDELM Kodachrome type F filter; slip-on type A36 ca.1959- -
FKDSAX Kodachrome type F filter; screw-on type E58 ca.1959- -
FKDSMI Kodachrome type F filter; screw-on type E39 ca.1959- -
FKDSMT Kodachrome type F filter; screw-on type E41 ca.1959- -
FKDTEL Kodachrome type F filter; screw-on type E48 ca.1959- -
FLASH Horizontal mounted flash unit (like SYNCO) for Leica Standard (model E) ca.1938 -
FLECT Dull surfaced flash reflector for portraits ca.1938 -
FLOOA UV light copying device with ELMAR 1939-19xx -
FLOTH Plumbbob for copy stand use with U-shaped or angular harness for ELMAR; FLOTH + STARE = STAOT copy stand 1931-19?? -
FLQOO Hood for 35 mm Elmar; black or chrome; superseded by FOOKH 1936-1950 also NY version
FMOOZ No. 1 light infra-red filter; slip-on type C ca.1933 -
FMSOO No. 3 dark infra-red filter; slip-on type C ca.1935 -
FNOOY No. 1 light infra-red filter; screw-on type H ca.1935 -
FNUOO No. 3 dark infra-red filter; screw-on type H ca.1935 -
FOCOMAT Enlarging device used with Visoflex II & III 1963-19?? -
FODIS Longbase rangefinder with leather case to measure distance from film plane to object; metric and international versions 1925-1929 2.15 cm wheel
FODUA Longbase rangefinder (without leather case) to measure distance from film plane to object; metric and international versions 1925-1929 2.15 cm wheel
FOFER Longbase rangefinder with leather case to measure distance from film plane to object; metric and international versions with fixing clip; Nagel version has N on the wheel 1925-1929 3.5 cm wheel
FOKAL Hinged bracket for attaching FOKIN to camera 19xx-19xx -
FOKIN Longbase rangefinder for cine cameras 1926-1940 3.5 cm wheel
FOKOS Short black & nickel or black & chrome ro all chrome rangefinder with 7.5 cm base 1933-1945 -
FOKOS Short chrome rangefinder with 6.2 cm base 1949-1966 -
FOKUX Ball and socket joint for longbase rangefinder 19??-1940 -
FONOR Longbase rangefinder for 6x9 to 10x15 cm; metric and international versions 19??-1940 -
FONOT Shutter release cable, 10 inches long with set screw 1955-19?? 14067
FOOBD Graduated Green filter; slip-on type A36 ca.1938 -
FOOCR Graduated Green filter; slip-on type C ca.1938 -
FOOKH Hood for 3.5 cm Summaron & Elmar 1951-1966 12505
FOOMI Short, chrome ball and socket tripod head 1938-1960 14104 (3/8") and 14105
FOONW FARUX Scale ring for Hektor 2.8 cm ca.1936
FOOQL FARUX Scale ring for Telyt 20 cm ca.1936
FOOVA ? 19xx-19xx -
FOOXB Filter holder; slip-on type A36 ca.1951 13365
FOOXC Filter holder; screw-on type L ca.1951 -
FOOXD Filter holder; screw-on type E41 ca.1951 13375
FOOXE Filter holder; screw-on type E58 ca.1951 13380
FOOXF Filter holder; screw-on type E48 ca.1951 13385
FOOXH Filter holder; screw-on type E39 ca.1955 13371
FOOXK Filter holder; screw-on type E43 ca.1959 13384
FOSAR Angular bracket for holding ground glass housing VEHIG ca.1933 -
FPKELM Kodachrome type FP filter; slip-on type A36 ca.1959- -
FPKSAX Kodachrome type FP filter; screw-on type E58 ca.1959- -
FPKSMI Kodachrome type FP filter; screw-on type E39 ca.1959- -
FPKSMT Kodachrome type FP filter; screw-on type E41 ca.1959- -
FPLTEL Kodachrome type FP filter; screw-on type E48 ca.1959- -
FPOOW Orange filter; screw-on type G ca.1939 -
FQOOV Orange filter; screw-on type H ca.1939 -
FRCOO Orange filter; screw-on type I ca.1939 -
FSEOO Orange filter; slip-on type C ca.1939-1950 -
FTGOO Orange filter; slip-on type A36 ca.1939 13025
FUECD ? 19xx-19xx -
FUFIF ? 19xx-19xx -
FUFOR ? 19xx-19xx -
FULDY Sliding focusing stage using Leica screw thread to hold camera (also know as "Focoslide") in 4 versions; superseded by FULEC 1930-1951 -
