A
Leitz "Binoculars" data courtesy of Peter Abrahams
| ABCOO | Nickel cutting blade for Leica 250 film | 1937 | -used with ANZOO template |
| ABFOO | Snap-shot Leica, never sold | 1935 | - |
| ABLON | Film trimming template | ? | - |
| ABOOT | Leica II (model D) = AIROO + Elmar (I) f= 5 cm 1:3.5 | 1934-1948 | before 1934 LYKUP = LYKAN + ELMAR |
| ACEDU | Micro Lens No. 2 for the micro-projection approach VIII projectors | - | |
| ACHOO | Leica III (model F) black lacquer with Summar f= 5 cm 1:2 | 1933-1939 | - see also ACOOS, AFOON |
| ACHOO CHROM | Leica III (model F) chrome with Summar f= 5 cm 1:2 | 1933-1935 | - see also ACOOS, AFOONCHROM |
| ACOOS | Leica III (model F) black lacquer with Elmar (I) f= 5 cm 1:3.5 | 1933-1939 | - see also ACHOO, AFOON |
| ACOOS CHROM | Leica III (model F) chrome with Elmar (I) f= 5 cm 1:3.5 | 1933-1935 | - see also ACHOO, AFOON CHROM |
| ACUBE | Wide band UV filter set for micro-projector VIII | - | |
| AFLUU | 18x24 sheet of glass with lower opening for AKTUU | - | |
| ADKOO | Leica IIIa (model G) with Summar 2.0/5 cm | 1935-1948 | LIOON in US Catalog |
| ADOOR | Leica IIIa (model G) with Elmar (II) f= 5 cm 1:3.5 | 1935-1948 | LEOOR in US Catalog |
| ADFIK | Hood with filter holder engraved for 50,90,127,135mm lenses | ? | - |
| ADR50 | Focotar enlarger 1:4.5/50 mm | ? | - |
| ADR65 | Focotar enlarger 1:3.5/65 mm | ? | - |
| ADSUM | Adapter for Summitar filter thread A 36 | ? | - |
| ADVOO | Close up set for [Leica IIIg] | 1959 | - also 16503 |
| AFLOO | Film Charger for Leica 250 | ? | - |
| AFLUN | Changed version | ? | - |
| AFOOV | Leica III (model F) black lacquer | 1933-39 | - see also ACOOS, ACHOO |
| AFOOV CHROM | Leica III (model F) chrome | 1933-35 | - see also ACOOS, ACHOO |
| AFUUV | Lower glass for AKTUU with 18x24mm opening | - | |
| AGIIU | Adjustment ring for microscopes with a diameter of 32 mm | ? | - |
| AGITA | Electric Tank / film development with DC | ? | - |
| AGOTU | Electric Tank / film development with AC | ? | - |
| AGNOO | Leica IIIa (model G) chrome | ? | LUOOB in US Catalog |
| AGNOO-SW | Leica IIIa (model G) black paint | ? | - |
| AGNUU | Slide changer with 24 x 36 mm film gate | - | |
| AGRIF | Hand film loader for cassettes | ? | - |
| AGULI | Timer for tanks | ? | - |
| AHOOT | Waist level viewfinder for 5cm use with a swivel mask for 2.8cm | ca. 1935 | |
| AIROO | Leica II (model D) body | 1934- | LYKAN before 1934 |
| AIUUS | Slider for 18x24 film strips, projector VIII | - | |
| AKGBMI | Underwater housing for Leica IIIf If up and Summicron | ? | - |
| AKGBSU | Underwater Housing for Leica If llf or lllf | - | |
| AKGRSU | Underwater housing for Leica IIIf If up and Summitar | ? | - |
| AKGRMI | Underwater Housing for Leica If, IIf or IIIf | ? | - |
| AKTOO | High-power AKTINA Lamp for Focomat II enlarger | ? | - |
| AKTUU | Film gate with semi-automatic film movement for 24x36mm Projector VIII | ? | - |
| AKUUR | Slide changer with circular opening of 43 mm. diameter for 5x5 cm | ? | - |
| ALVOO | Standard Leica (model E) black enameled, without spool chamber and without lens | 1932-1948 | - see also AROOG |
| ALVUU | Slide changer for 2x2 in glass slides | ? | - |
| AMPLIVID | Binoculars - 6 x 24 - 12 deg | 1956-1962 | - |
| AMTOM | Electric timer for bayonet cameras | ? | - |
| AMTOO | Electric timer for screw cameras | ? | - |
| ANZOO | Trimming template for Leica 250 film | 1937 | - used with ABCOO blade |
| AMUUP | 750 w projector lamp | ca. 1937 | - also AMUUP-E |
| AMXOO | - | ||
| ANIIO | - | ||
| ANUUO | - | ||
| ANZUU | - | ||
| APDOO | Self-timer | ca. 1937-46 | - |
| AQOOT | Extra long release button for screw mount cameras | ? | - |
| ARHOO | Leica I (model C) with Elmar (I) f= 5 cm 1:3.5 | 1930-1933 | - |
| ARMST | Stereo Prism Holder for Leica IIIb | ? | - |
| AROOG | Standard Leica (model E) black lacquer body, with attached horizontal rangefinder | 1932-1948 | - see also ALVOO |
| AROOG CHROM | Standard Leica (model E) chrome body, with attached horizontal rangefinder | 1934-1935 | - see also ALVOOCHROM |
| AIROO | Late version Leica II (model D) black lacquer | 1934 | - |
| AIROO CHROM | Late version Leica II (model D) chrome body | 1934 | - |
| ALVOO | Standard Leica (model E) black body | 1932-1950 | - |
| ALVOO CHROM | Standard Leica (model E) chrome body | 1938 | - |
| ASKOO | APDOO self-timer with leather case | ca. 1937 | - |
| ASPUL | Manual Hand Film Loader | ? | - |
| ASUUI | - | ||
| ATMUU | - | ||
| ATTAC | - | ||
| ATOOH | Leica IIIb chrome | 1938-41 | - |
| AUFSU | Reflecting (waist level) viewfinder for 50mm lens | ca. 1932-1945 | - |
| AUTAS | Prism for Mikas microscope | ? | - |
| AUXWI | - | ||
| AVIODIX | Binoculars - 10 x 50 | 1919-1931 | - military version 1917 |
| AVIODIXIT | Binoculars - 10 x 50 - 5 deg - CF type | 1931 | - |
| AVIOSEPT | Binoculars - 7 x 50 - 7.3 deg | 1919-1931 | - |
| AVIOSEPTIT | Binoculars - 7x50 - 7.3 deg - CF type | 1930-1931 | - |
| AVIOFORTE | Binoculars - 12 x 60 - 4.3 deg | 1919-1930 | - |
| AVIONAR | Binoculars - 15 x 60 | ? | - |
| AVOOF | - | ||
| AVQUU | - | ||
| AWOOE | - | ||
| AWSUU | - | ||
| AWUUE | Slide changer with circular opening of 50 mm. diameter for Leica diapositives 3x4cm between 5x5cm glass plates | pre 1937 | - |
| AXUOO | - | ||
| AYOOK | Reflecting (waist level) viewfinder AUFSU / AHOOT for 35 + 50mm lens | ? | - also AYOOC |
| AYUUK | Reflecting (waist level) viewfinder AYOOK with New York Engravings | ? | - |
| AYUUL | Reflecting (waist level) viewfinder AHOOT with New York Engravings | ? | - |
| AYUUN | Reflecting (waist level) viewfinder without the 2.8 cm swivel lens | ? | - |
| AYUUO | Reflecting (waist level) viewfinder for 35 mm lens | ? | - |
| AZOOB | - | ||
| AZUUB | - |
