GHIJ
| GBOOM | No. 0 very light yellow filter; screw-on type L | ca.1939 | - |
| GBWOO | No. 1 light yellow filter; screw-on type L | ca.1939 | - |
| GCHEO | Kodachrome flash filter; screw-on type L | ca.1949-1950's | NY item |
| GCHEOMI | Kodachrome flash filter; screw-on type E39 | ca.1949-1950's | NY item |
| GCOOL | No. 2 yellow filter; screw-on type L | ca.1939 | - |
| GCSKYMI | Kodachrome skylight filter; screw-on type L | ca.1949-1950's | NY item |
| GCYOD | Panchromatic no. 2 green filter; screw-on type L | ca.1939 | - |
| GCYOO | Panchromatic no. 1 green filter; screw-on type L | ca.1939 | - |
| GDOOK | Orange filter; screw-on type L | ca.1939 | - |
| GECOO | Infra-red no. 1 light filter; screw-on type L | ca.1939 | - |
| GFEOO | Infra-red no. 2 medium filter; screw-on type L | ca.1939 | - |
| GFOOH | Infra-red no. 3 dark filter; screw-on type L | ca.1939 | - |
| GHIOO | UVa filter; screw-on type L | ca.1939 | - |
| GHOOF | Graduated yellow filter; screw-on type L | ca.1939 | - |
| GIIBR | Microphotography 18 inch cable release for MIKAS with set screw mount | 1939-1950's | - |
| GIIEF | Microphotography 1/3x conical extension tube for MIKAS with screw-mount | 1939-1950's | - |
| GIIEF-M | Microphotography 1/3x conical extension tube for MIKAS with M-mount | 1939-1950's | - |
| GIIFT | Microphotography 18 inch cable release for MIKAS with screw-mount | 1939-1950's | - |
| GIIMW | Microphotography 1/2x conical extension tube for MIKAS with screw-mount | 1939-1950's | - |
| Microphotography 1/2x conical extension tube for MIKAS with M-mount | 1956-1960's | - | |
| GIINK | Microphotography 1x conical extension tube for MIKAS with screw-mount | 1939-1950's | - |
| GIIOX | Single exposure housing without shutter | 1939-1940's | NY item |
| GILOO | Graduated green filter; screw-on type L | ca.1939 | - |
| GOOEF | Leica IIIg body | 1957-1970 | - |
| GOOEL | Leica IIIg with Elmar f= 5 cm 1:2.8 (ELMOO) | 1957-1970 | - |
| GOOMI | Leica IIIg with Summicron (I) f= 5 cm 1:2 (SOOIC) | 1957-1970 | - |
| GOORM | Copy stand arm for 1 1/4 inch column with tape measure for rotating stage OORES or 250 stage GRBOO | 1938-ca.1950 | - |
| GOOSZ | Complete copy stand with GOOZQ arm for 1 1/4 inch column with tape measure for rotating stage OORES either direct or with ball and socket KAGOON head | 1938-ca.1950 | - |
| GOOZQ | Copy stand arm for 1 1/4 inch column with tape measure for rotating stage OORES either direct or with ball and socket KAGOON head | 1938-1950 | - |
| GRBOO | Sliding stage for Leica 250 (models DD, FF & GG) | 1935-ca.1950 | - |
| GROOW | Basic copy stand with spring mounted base plate | 19xx-19xx | - |
| GVKOO | 30 mm extension ring G for ZWTOO-HESUM | 19xx-19xx | - |
| HEBOO | Slow speed shutter release for 1, 1/2, 1/4, 1/8 s in nickel or later chrome | 1935-1969 | - |
| HEFAM | Hektor f= 13.5 cm 1:4.5 black M-mount | 1954-1960 | - |
| HEFAM-CHROM | Hektor f= 13.5 cm 1:4.5 chrome M-mount | 1954-1960 | - |
| HEFAM-KUP | Hektor f= 13.5 cm 1:4.5 nickel | 1933 | - |
| HEFAR | Hektor f= 13.5 cm 1:4.5 chrome | 1933-1959 | - |
| HEGRA | Hektor f= 7.3 cm 1:1.9 black lacquer & chrome | 1934-1946 | - |
| HEKON | Hektor f= 7.3 cm 1:1.9 black lacquer & nickel | 1931-1933 | - |
| HEKTO | Hektor f= 5 cm 1:2.5 nickel or chrome | 1930-1936 | - |
| HEPET | Close-up supplementary front lens no. 3 for Hektor 5 cm | 1928-1950's | - |
| HEPIK | Close-up supplementary front lens no. 2 for Hektor 5 cm | 1928-1950's | - |
| HEPRO | Close-up supplementary front lens no. 1 for Hektor 5 cm | 1928-1950's | - |
| HFOOK | Short-base clip-on rangefinder for Leica models A, B & C | 1920's-ca.1936 | - |
| HGOOI | Rear cover for 125 mm Hektor | 1930's-1960's | 14053 |
| HIIBE | Stand for photographing small objects; with adjusment by rack and pinion; with rotation and tilt | 1939-1940's | - |
| HIKOU | ?Hector 2.5/12.5cm? | 19xx-19xx | - |
| HKMOO | ? | 19xx-19xx | - |
| HMOOD | ? | 19xx-19xx | - |
| HOOAR | Yellow no. 0 very light filter; screw-on type E39 | ca.1955 | 13081 |
| HOOBE | Yellow no. 1 light filter; screw-on type E39 | ca.1955 | 13086 |
| HOOCS | Infra-red no. 1 light filter; screw-on type E39 | ca.1955 | - |
| HOODF | Infra-red no. 2 medium filter; screw-on type E39 | ca.1955 | - |
| HOOET | Infra-red no. 3 dark filter; screw-on type E39 | ca.1955 | - |
| HOOFG | Panchromatic filter; screw-on type E39 | ca.1955 | - |
| HOOGU | Orange filter; screw-on type E39 | ca.1955 | - |
| HOOIV | UVa filter; screw-on type E39 | ca.1955 | - |
| HOOKI | Blue filter; screw-on type E39 | ca.1955 | 13098 |
| HOOPY | Hektor f= 2.8 cm 1:6.3 nickel | 1935-1936 | - |
| HOOPY-CHROM | Hektor f= 2.8 cm 1:6.3 chrome | 1936-1955 | - |
| IASUU | ? | 19xx-19xx | - |
| IBSOR | ? | 19xx-19xx | - |
| IDCOO | M3 leather ready case | 19xx-19xx | - |
| IFLEX | ? | 19xx-19xx | - |
| IFSTA | ? | 19xx-19xx | - |
| IGEMO | M3 body | 19xx-19xx | - |
| ILNOO | Elmar (II) f= 9 cm 1:4 collapsible | 19xx-19xx | - |
| ILNOO-M | 90mm f/4 Elmar collapsible M-mount | 1954-1968 | - |
| ILLUM | ? | 19xx-19xx | - |
| ILNUU | ? | 19xx-19xx | - |
| IMARO | M3 with F = 5 cm 1:3.5 Elmar | 19xx-19xx | - |
| IMFIN | ? | 19xx-19xx | - |
| IMPUU | ? | 19xx-19xx | - |
| IMPUU-IZOUU | ? | 19xx-19xx | - |
| IROOA | ? | 19xx-19xx | - |
| IRZOO | ? | 19xx-19xx | - |
| IRZUU | ? | 19xx-19xx | - |
| ISAIO | M3 with F = 5 cm 1:1.5 Summarit | 19xx-19xx | - |
| ISBOO | ? | 19xx-19xx | - |
| ISBUU | ? | 19xx-19xx | - |
| ISOOZ | ? | 19xx-19xx | - |
| ISUMO | M3 with F = 5 cm 1:2 Summicron II | 19xx-19xx | - |
| ITDOO | ? | 19xx-19xx | - |
| ITOOY | ? | 19xx-19xx | - |
| IUFOO | ? | 19xx-19xx | - |
| IUOOP | MP and MP2 | 1956-1959 | - |
| IVZOO | ? | 19xx-19xx | - |
| IWKOO | ? | 19xx-19xx | - |
| IXMOO | ? | 19xx-19xx | - |
| IZQOO | ? | 19xx-19xx | - |
