TUV
| TBKOO | 63-4-74 | 19??-19?? | - |
| TELOO | F = 20 cm 1:4 Telyt | 1956-1966 | - |
| TEQOO | 100 | 19??-19?? | - |
| TFOOG | - | 19??-19?? | - |
| TFSOO | - | 19??-19?? | - |
| TGOOF | - | 19??-19?? | - |
| TGUOO | - | 19??-19?? | - |
| THMOO | 108 | 19??-19?? | - |
| THOOE | - | 19??-19?? | - |
| THWOO | - | 19??-19?? | - |
| TIOOD | - | 19??-19?? | - |
| TIYOO | - | 19??-19?? | - |
| TLCOO | F = 40 cm 1:5 Telyt II | 1956-1966 | - |
| TMEOO | 108 | 19??-19?? | - |
| TNGOO | 108 | 19??-19?? | - |
| TOODY | Thambar f= 9 cm 1:2.2 | 1935-1939 | - |
| TOOQE | 85 | 19??-19?? | - |
| TOOSF | 84 | 19??-19?? | - |
| TOOUG | 85 | 19??-19?? | - |
| TOWIN | 37 | 19??-19?? | - |
| TREPL | 80 | 19??-19?? | - |
| TROOV | 85 | 19??-19?? | - |
| TRPOO | 85 | 19??-19?? | - |
| TRPOO-M | - | 19??-19?? | - |
| TSOOV | 85 | 19??-19?? | - |
| TUSOO | 61-2 | 19??-19?? | - |
| TUVOO | Attachment for VIOOH viewfinder for 2.8 cm lenses | ? | 12-13 |
| TXBOO | 17-109 | 19??-19?? | - |
| TZFOO | - | 19??-19?? | - |
| TZOON | - | 19??-19?? | - |
| 1 | |||
| UBECD | 59 | 19??-19?? | - |
| UCEGU | Pradovit I with Dimaron 2.8/100mm | 1960 | - |
| UCFKU | Pradovit I with Colorplan 2.5/90mm | 1960 | - |
| UCHRU | Protective metal hood for Pradovit I | 1960 | - |
| UCNXU | Pradovit f with Dimaron 2.8/100mm | 1960 | - |
| UCPLU | Pradovit f with Colorplan 2.5/90mm | 1960 | - |
| UCSHU | Remote control cable 4m long | 1960 | - |
| UCWQU | 1960 | - | |
| UDCBU | Pradovit f with Dimaron 2.8/150mm | 1960 | - |
| UDIMO | 59 | 19??-19?? | - |
| UDGKU | Plywood case for projector plus accessories and 150mm lenses | 1960 | - |
| UDKQU | Second heat protection filter, including 500-watt lamp | 1960 | - |
| UDWPU | Transparent container for 2 slide magazines | 1960 | - |
| UDXRU | Transparent containers with 2 magazines | 1960 | - |
| UDLSU | 1960 | - | |
| UEOOK | 47 | 19??-19?? | - |
| UEOXU | Slide magazine for 30 slides | 1960 | - |
| UEPOO | 47 | 19??-19?? | - |
| UFBXU | 5 magazine cassette | 1960 | - |
| UFTGU | 2 slide magazines for 50 slides incl. cardboard | 1960 | - |
| UGPXU | Remote control cable 10m long | 1960 | - |
| UGQZU | Remote control cable 15m long | 1960 | - |
| UGRBU | Remote control cable 20m long | 1960 | - |
| UHPWU | Multiple connector for tape device and cable | 1960 | - |
| UKGDU | Synchronous circuit with tape | 1960 | - |
| UMHDU | Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable | 1960 | - |
| UMIQU | Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable | 1960 | - |
| UMKHU | Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable | 1960 | - |
| UMLKU | Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable | 1960 | - |
| UMNOU | Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable | 1960 | - |
| UNOOB | 58-74 | 19??-19?? | - |
| UNOOB-YSMOO | 58 | 19??-19?? | - |
| UOOND | Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW | ? | 16596 |
| UOOPE | Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb | ? | - |
| UOORE | Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M | ? | 16508 |
| UOORF | Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY | 1960 | 16508 |
| UOOST | UOOYW + UOOVH | ? | - |
| UOOVH | Lens adapter ring for the head of Hector and Elmar 135mm | ? | 16580 |
| UOOWV | Lens Adapter Ring for heads and the Elmarit 90mm Elmar | ? | 16585 |
| UOOXI | Adapter Ring Lens fü the head of the 125mm Hektor | 1958 | 16572 |
| UOOYH | 48 | 19??-19?? | - |
| UOOYW | Bellows connecting ring for I and II | ? | 16590 N |
| UOOZK | Adapter ring for the head of the Summicron 90 mm | 1960 | 16598 |
| UOSWU | Horizontal slider for Prado S and SM | ? | - |
| UPOOZ | 101 | 19??-19?? | - |
| UQMOO | - | 19??-19?? | - |
| UQOOY | - | 19??-19?? | - |
| UROOX | - | 19??-19?? | - |
| USFLA | 103 | 19??-19?? | - |
| USOAY | 103 | 19??-19?? | - |
| USOOW | 101 | 19??-19?? | - |
| USQOO | - | 19??-19?? | - |
| USSKY | 103 | 19??-19?? | - |
| UTOOV | 101 | 19??-19?? | - |
| UTSOO | - | 19??-19?? | - |
| UUOYW | Adapter ring and tube | ? | - |
| UVOOF | - | 19??-19?? | - |
| UVWOO | 71-2 | 19??-19?? | - |
| UWOOS | 67-8-9 | 19??-19?? | - |
| UWYOO | 47-8 | 19??-19?? | - |
| UXOOR | 47 | 19??-19?? | - |
| UYOOQ | Fiber case with Visoflex I, bellows and accessories | ? | - |
| UZEOO | 47 | 19??-19?? | - |
| VALOY | 67-8 | 19??-19?? | - |
| VAMAX | 68 | 19??-19?? | - |
| VARIP | 74 | 19??-19?? | - |
| VEARM | 68-74 | 19??-19?? | - |
| VEDUK | 72 | 19??-19?? | - |
| VEHAL | 68-9-74 | 19??-19?? | - |
| VEHIG | 53-74 | 19??-19?? | - |
| VEKAS | 72-4 | 19??-19?? | - |
| VEKOT | 72 | 19??-19?? | - |
| VELIF | 68-74 | 19??-19?? | - |
| VELTU | 68-74 | 19??-19?? | - |
| VELYP | 72 | 19??-19?? | - |
| VEPUT | 72 | 19??-19?? | - |
| VERAP | 74-77 | 19??-19?? | - |
| VERYK | 72 | 19??-19?? | - |
| VESTA | 68-74 | 19??-19?? | - |
| VEZUK | Curved lateral holder to support the camera when used vertically | ca.1933 | - |
| VIDEO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 10.5cm lenses | 1932-1933 | black |
| VIDOM | Universal viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image | 1933-1939 | |
| VIEFF | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
| VIEME | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 13.5cm lenses | 1932-1933 | black |
| VIFUR | Small, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1933-1936 | black or chrome |
| VIGEH | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
| VIHAK | 74 | 19??-19?? | - |
| VIHEU | Small, torpedo shaped finder for 3.5cm, 5cm lenses | 1932- | black |
| VIKAN | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VIKUL | 72 | 19??-19?? | - |
| VILLO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VIOAD | 12 | 19??-19?? | - |
| VIOOH | Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm | 1940-1964 | reaches 2.8 cm with TUVOO add-on |
| VISAX | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1932-1933 | black |
| VISET | Small, torpedo shaped finder for 3.5cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VISIL | 10 | 19??-19?? | - |
| VISOR | The first, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1931-1931 | black |
| VISSI | Small, torpedo shaped finder for 3.5cm, 9cm lenses | 1932-1933 | black |
| VITRE | Small, torpedo shaped finder for 3.5cm, 5cm, 10.5cm lenses | 1933-1936 | black or chrome |
| VIUNA | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm lenses | 1933-1936 | black or chrome |
| VIZWO | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1933-1936 | black or chrome |
| VLOOF | 95 | 19??-19?? | - |
| VMCOO | 40 | 19??-19?? | - |
| VOOLA | 104-5 | 19??-19?? | - |
| VOOQF | 67 | 19??-19?? | - |
| VORGI | 40 | 19??-19?? | - |
| VOROD | 35 | 19??-19?? | - |
| VORSA | 35 | 19??-19?? | - |
| VORSTAN | 35 | 19??-19?? | - |
| VORUF | 36 | 19??-19?? | - |
| VOSTN | 35 | 19??-19?? | - |
| VOTIV | 36 | 19??-19?? | - |
| VOTRA | 36 | 19??-19?? | - |
| VSPOO | 60 | 19??-19?? | - |
| VTOOX | 60 | 19??-19?? | - |
| VTROO | 60 | 19??-19?? | - |
| VUROO | 67 | 19??-19?? | - |
| VWOOU | 60 | 19??-19?? | - |
| VXOOT | 60 | 19??-19?? | - |
| VXZOO | 60 | 19??-19?? | - |
