TUV
Revision as of 15:21, 19 September 2009 by Admin (talk | contribs)
TBKOO Microscope to camera connector with correction lens 1939-19?? -
TELOO F = 20 cm 1:4 Telyt 1956-1966 -
TEQOO 100 19??-19?? -
TFOOG - 19??-19?? -
TFSOO - 19??-19?? -
TGOOF - 19??-19?? -
TGUOO - 19??-19?? -
THMOO 108 19??-19?? -
THOOE - 19??-19?? -
THWOO - 19??-19?? -
TIOOD - 19??-19?? -
TIYOO - 19??-19?? -
TLCOO F = 40 cm 1:5 Telyt II 1956-1966 -
TMEOO 108 19??-19?? -
TNGOO 108 19??-19?? -
TOODY Thambar f= 9 cm 1:2.2 1935-1939 -
TOOQE 85 19??-19?? -
TOOSF 84 19??-19?? -
TOOUG 85 19??-19?? -
TOWIN 37 19??-19?? -
TREPL 80 19??-19?? -
TROOV 85 19??-19?? -
TRPOO 85 19??-19?? -
TRPOO-M - 19??-19?? -
TSOOV 85 19??-19?? -
TUSOO 61-2 19??-19?? -
TUVOO Attachment for VIOOH viewfinder for 2.8 cm lenses ? 12-13
TXBOO 17-109 19??-19?? -
TZFOO - 19??-19?? -
TZOON - 19??-19?? -
1
UBECD 59 19??-19?? -
UCEGU Pradovit I with Dimaron 2.8/100mm 1960 -
UCFKU Pradovit I with Colorplan 2.5/90mm 1960 -
UCHRU Protective metal hood for Pradovit I 1960 -
UCNXU Pradovit f with Dimaron 2.8/100mm 1960 -
UCPLU Pradovit f with Colorplan 2.5/90mm 1960 -
UCSHU Remote control cable 4m long 1960 -
UCWQU 1960 -
UDCBU Pradovit f with Dimaron 2.8/150mm 1960 -
UDIMO 59 19??-19?? -
UDGKU Plywood case for projector plus accessories and 150mm lenses 1960 -
UDKQU Second heat protection filter, including 500-watt lamp 1960 -
UDWPU Transparent container for 2 slide magazines 1960 -
UDXRU Transparent containers with 2 magazines 1960 -
UDLSU 1960 -
UEOOK 47 19??-19?? -
UEOXU Slide magazine for 30 slides 1960 -
UEPOO 47 19??-19?? -
UFBXU 5 magazine cassette 1960 -
UFTGU 2 slide magazines for 50 slides incl. cardboard 1960 -
UGPXU Remote control cable 10m long 1960 -
UGQZU Remote control cable 15m long 1960 -
UGRBU Remote control cable 20m long 1960 -
UHPWU Multiple connector for tape device and cable 1960 -
UKGDU Synchronous circuit with tape 1960 -
UMHDU Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable 1960 -
UMIQU Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable 1960 -
UMKHU Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable 1960 -
UMLKU Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable 1960 -
UMNOU Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable 1960 -
UNOOB 58-74 19??-19?? -
UNOOB-YSMOO 58 19??-19?? -
UOOND Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW ? 16596
UOOPE Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb ? -
UOORE Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M ? 16508
UOORF Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY 1960 16508
UOOST UOOYW + UOOVH ? -
UOOVH Lens adapter ring for the head of Hector and Elmar 135mm ? 16580
UOOWV Lens Adapter Ring for heads and the Elmarit 90mm Elmar ? 16585
UOOXI Adapter Ring Lens fü the head of the 125mm Hektor 1958 16572
UOOYH 48 19??-19?? -
UOOYW Bellows connecting ring for I and II ? 16590 N
UOOZK Adapter ring for the head of the Summicron 90 mm 1960 16598
UOSWU Horizontal slider for Prado S and SM ? -
UPOOZ 101 19??-19?? -
UQMOO - 19??-19?? -
UQOOY - 19??-19?? -
UROOX - 19??-19?? -
USFLA 103 19??-19?? -
USOAY 103 19??-19?? -
USOOW 101 19??-19?? -
USQOO - 19??-19?? -
USSKY 103 19??-19?? -
UTOOV 101 19??-19?? -
UTSOO - 19??-19?? -
UUOYW Adapter ring and tube ? -
UVOOF - 19??-19?? -
UVWOO 71-2 19??-19?? -
UWOOS 67-8-9 19??-19?? -
UWYOO 47-8 19??-19?? -
UXOOR 47 19??-19?? -
UYOOQ Fiber case with Visoflex I, bellows and accessories ? -
UZEOO 47 19??-19?? -
VALOY 67-8 19??-19?? -
VAMAX 68 19??-19?? -
VARIP 74 19??-19?? -
VEARM 68-74 19??-19?? -
VEDUK 72 19??-19?? -
VEHAL 68-9-74 19??-19?? -
VEHIG 53-74 19??-19?? -
VEKAS 72-4 19??-19?? -
VEKOT 72 19??-19?? -
VELIF 68-74 19??-19?? -
VELTU 68-74 19??-19?? -
VELYP 72 19??-19?? -
VEPUT 72 19??-19?? -
VERAP 74-77 19??-19?? -
VERYK 72 19??-19?? -
VESTA 68-74 19??-19?? -
VEZUK Curved lateral holder to support the camera when used vertically ca.1933 -
VIDEO Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 10.5cm lenses 1932-1933 black
VIDOM Universal viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image 1933-1939
VIEFF Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm lenses 1932-1933 black
VIEME Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 13.5cm lenses 1932-1933 black
VIFUR Small, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses 1933-1936 black or chrome
VIGEH Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm lenses 1932-1933 black
VIHAK 74 19??-19?? -
VIHEU Small, torpedo shaped finder for 3.5cm, 5cm lenses 1932- black
VIKAN Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm, 13.5cm lenses 1932-1933 black
VIKUL 72 19??-19?? -
VILLO Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm, 13.5cm lenses 1932-1933 black
VIOAD 12 19??-19?? -
VIOOH Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm 1940-1964 reaches 2.8 cm with TUVOO add-on
VISAX Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses 1932-1933 black
VISET Small, torpedo shaped finder for 3.5cm, 9cm, 13.5cm lenses 1932-1933 black
VISIL 10 19??-19?? -
VISOR The first, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses 1931-1931 black
VISSI Small, torpedo shaped finder for 3.5cm, 9cm lenses 1932-1933 black
VITRE Small, torpedo shaped finder for 3.5cm, 5cm, 10.5cm lenses 1933-1936 black or chrome
VIUNA Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm lenses 1933-1936 black or chrome
VIZWO Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses 1933-1936 black or chrome
VLOOF 95 19??-19?? -
VMCOO 40 19??-19?? -
VOOLA 104-5 19??-19?? -
VOOQF 67 19??-19?? -
VORGI 40 19??-19?? -
VOROD 35 19??-19?? -
VORSA 35 19??-19?? -
VORSTAN 35 19??-19?? -
VORUF 36 19??-19?? -
VOSTN 35 19??-19?? -
VOTIV 36 19??-19?? -
VOTRA 36 19??-19?? -
VSPOO 60 19??-19?? -
VTOOX 60 19??-19?? -
VTROO 60 19??-19?? -
VUROO 67 19??-19?? -
VWOOU 60 19??-19?? -
VXOOT 60 19??-19?? -
VXZOO 60 19??-19?? -
