TUV
| TBKOO | Microscope to camera connector with correction lens | 1939-19?? | - |
| TELOO | F = 20 cm 1:4 Telyt | 1956-1966 | - |
| TEQOO | Infra-red light no. 1 filter; screw-on type E85 | ca.1938 | 13326 |
| TFOOG | Yellow very light no. 0 filter; screw-on type E85 | ca.1938 | 13291 |
| TFSOO | Yellow light no. 1 filter; screw-on type E85 | ca.1938 | 13296 |
| TGOOF | Yellow medium no. 2 filter; screw-on type E85 | ca.1938 | - |
| TGUOO | Infra-red light no. 1 filter; screw-on type E85 | ca.1938 | 13316 |
| THMOO | Replacemant hood for F = 40 cm 1:5 Telyt I | 1951-1955 | see also TMEOO |
| THOOE | Infra-red medium no. 2 filter; screw-on type E85 | ca.1938 | 13316 |
| THWOO | Infra-red dark no. 3 filter; screw-on type E85 | ca.1938 | 13326 |
| TIOOD | UVa filter; screw-on type E85 | ca.1938 | 13331 |
| TIYOO | Panchromatic green filter; screw-on type E85 | ca.1938 | 13306 |
| TLCOO | F = 40 cm 1:5 Telyt II | 1956-1966 | - |
| TMEOO | Replacemant hood for F = 40 cm 1:5 Telyt II | 1954-1966 | see also THMOO |
| TNGOO | Replacemant hood for f = 20 cm 1:4 Telyt | 1954-19?? | see also THMOO |
| TOODY | Thambar f= 9 cm 1:2.2 | 1935-1939 | - |
| TOOQE | Small, table top tripod complete with FOOMI ball and socket | 1952-19?? | - |
| TOOSF | 84 | 19??-19?? | - |
| TOOUG | Small, table top tripod complete with FOOMI ball and socket; black crackle enamel; later gray enamel | 1952-19?? | 14100 |
| TOWIN | 37 | 19??-19?? | - |
| TREPL | Complete photomicrography outfit with microscope, mirror reflex housing and copy stand | 1938-19?? | - |
| TROOV | Leather wrist strap with threaded connector | 1938-19?? | - |
| TRPOO | Neck strap with patent hooks | 1951-19?? | - |
| TRPOO-M | Neck strap with patent hooks for Leica-M | 1956-19?? | - |
| TSOOV | Neck strap with split rings for atachment to camera side lugs; later version has non-slip shoulder pad | 1960-19?? | 14092 |
| TUSOO | Steel tape measure for ROOFU arm | 1951-19?? | - |
| TUVOO | Chrome attachment for VIOOH viewfinder for 2.8 cm lenses | ? | - |
| TXBOO | Extension tube for TEYLT's on M-cameras | 19??-19?? | 14024 |
| TZFOO | Extension tube for TEYLT's on screw cameras | 19??-19?? | - |
| TZOON | Extension tube for TEYLT's on screw cameras, early version | 19??-19?? | 14023 |
| 1 | |||
| UBECD | 22 mm extension tube for Focoslide and also for UDIMO enlarger using 5 cm Elmar | 1936-1940 | NY item |
| UCEGU | Pradovit I with Dimaron 2.8/100mm | 1960 | - |
| UCFKU | Pradovit I with Colorplan 2.5/90mm | 1960 | - |
| UCHRU | Protective metal hood for Pradovit I | 1960 | - |
| UCNXU | Pradovit f with Dimaron 2.8/100mm | 1960 | - |
| UCPLU | Pradovit f with Colorplan 2.5/90mm | 1960 | - |
| UCSHU | Remote control cable 4m long | 1960 | - |
| UCWQU | 1960 | - | |
| UDCBU | Pradovit f with Dimaron 2.8/150mm | 1960 | - |
| UDIMO | Enlarger | 19??-19?? | - |
| UDGKU | Plywood case for projector plus accessories and 150mm lenses | 1960 | - |
| UDKQU | Second heat protection filter, including 500-watt lamp | 1960 | - |
| UDWPU | Transparent container for 2 slide magazines | 1960 | - |
| UDXRU | Transparent containers with 2 magazines | 1960 | - |
| UDLSU | 1960 | - | |
| UEOOK | Adaptor ring for UZEOO 36 mm front lens mount | 19??-19?? | 16568 |
| UEOXU | Slide magazine for 30 slides | 1960 | - |
| UEPOO | Adaptor ring for UZEOO 42 mm front lens mount | 19??-19?? | 16566 |
| UFBXU | 5 magazine cassette | 1960 | - |
| UFTGU | 2 slide magazines for 50 slides incl. cardboard | 1960 | - |
| UGPXU | Remote control cable 10m long | 1960 | - |
| UGQZU | Remote control cable 15m long | 1960 | - |
| UGRBU | Remote control cable 20m long | 1960 | - |
| UHPWU | Multiple connector for tape device and cable | 1960 | - |
| UKGDU | Synchronous circuit with tape | 1960 | - |
| UMHDU | Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable | 1960 | - |
| UMIQU | Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable | 1960 | - |
| UMKHU | Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable | 1960 | - |
| UMLKU | Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable | 1960 | - |
| UMNOU | Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable | 1960 | - |
| UNOOB | Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Elmar f= 5 cm 1:3.5 | 1934-19?? | - |
| UNOOB-YSMOO | Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for [[Summar f= 5 cm 1:2 | 1937-19?? | - |
| UOOND | Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW | 1956-19?? | 16596 |
| UOOPE | Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb | ? | - |
| UOORE | Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M | ? | 16508 |
| UOORF | Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY | 1960 | 16508 |
| UOOST | UOOYW + UOOVH | ? | - |
| UOOVH | Lens adapter ring for the head of Hector and Elmar 135mm | ? | 16580 |
| UOOWV | Lens Adapter Ring for heads and the Elmarit 90mm Elmar | ? | 16585 |
| UOOXI | Adapter Ring Lens fü the head of the 125mm Hektor | 1958 | 16572 |
| UOOYW | Bellows connecting ring for I and II | ? | 16590 N |
| UOOZK | Adapter ring for the head of the Summicron 90 mm | 1960 | 16598 |
| UOSWU | Horizontal slider for Prado S and SM | ? | - |
| UPOOZ | Yellow very light no. 0 filter; screw-on type E58 | ca.1951 | 13235 |
| UQMOO | Yellow light no. 1 filter; screw-on type E58 | ca.1951 | 13235 |
| UQOOY | Yellow medium no. 2 filter; screw-on type E58 | ca.1951 | - |
| UROOX | Panchromatic green filter; screw-on type E58 | ca.1951 | 13245 |
| USFLA | Kodachrome flash filter; type E58 | 1949-19?? | NY item |
| USOAY | Kodachrome type A filter; type E58 | 1949-19?? | NY item |
| USOOW | Orange filter; screw-on type E58 | ca.1951 | 13250 |
| USQOO | Infra-red light no. 1 filter; screw-on type E58 | ca.1951 | 13255 |
| USSKY | Kodachrome skylight filter; type E58 | 1954-19?? | NY item |
| UTOOV | Infra-red medium no. 2 filter; screw-on type E58 | ca.1951 | - |
| UTSOO | Infra-red dark no. 3 filter; screw-on type E58 | ca.1951 | 13265 |
| UUOYW | Adapter ring used to mount screw-mount lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used for mounting extension tube or copy device like Focoslide for close-up work. The M-mount version is UUOND | 1956-19?? | - |
| UVOOF | UVa filter; screw-on type E58 | ca.1951 | 13270 |
| UVWOO | 4-way lamp socket with cable and plug | 1951-19?? | 16760 |
| UWOOS | Arm connector for copy stand Focoslide | 19??-19?? | 16601 |
| UWYOO | Adaptor plate for using focusing bellows on carrying arms ROONP and ROOFU | 1951-19?? | 16600 |
| UXOOR | Universal focusing bellows; early version had smaller diameter thread for the lens mount and was supplied with an adaptor ring UOOYW and tube UOOVH for Hektor f- 13.5 cm 1:6.3; later version has thread for universal focusing bellows II with interchangable adaptor rings | 1951-19?? | 16555 |
| UYOOQ | Fiber case with Visoflex I, bellows and accessories | ? | - |
| UZEOO | Large extending bellows lens hood with changeover mask frame for upright and horizontal shots for 36 mm front lens mount | 1951-19?? | 16565 |
| UZEOO-M | Bellows lens hood for 42 mm front lens mount | 1960-19?? | 16567 |
| VALOY | Complete copy stand type I and II OKYNO | 19??-19?? | - |
| VAMAX | X-ray enlarger used with VEHAL and 48" VESTA arm | 1933-19?? | - |
| VARIP | Large copying device with VELTU base and column, and VEARM arm and STAFO lighting, VEHIG and STAMA | 1933-19?? | - |
| VEARM | Large copying device with 40" VELTO base and column, front lenses 1, 2 & 3 and VALFA or FILYT enlarger | 1933-19?? | - |
| VEDUK | Cable with plug and switch for VEKAS | 1931-19?? | - |
| VEHAL | Bent camera arm with wingnut; used with VERAP | 1931-19?? | - |
| VEHIG | Fixed focusing stage with ground glass housing complete with 5x magnifier and protecting lid for camera body opening | 1933-19?? | - |
| VEKAS | 16 x 20 inch lightbox with 6 lights, VEDUK cable and various glass covers to hold film flat; on base of VERAP | 1931-19?? | - |
| VEKOT | 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and VERYK glass covers to hold film flat | 1931-19?? | - |
| VELIF | Arm for VIHAK small copy stand | 1933-19?? | - |
| VELTU | Base and column part of VARIP or ROOKA large copy stand | 1933-1936 | - |
| VELYP | 16 x 12 inch glass covers to hold film flat | 1933-19?? | - |
| VEPUT | 16 x 12 inch lightbox with 4 lights, VEDUK cable and various glass covers, VELYP to hold film flat | 1932-19?? | - |
| VERAP | X-ray reproduction device with VESTA base and column, VEHAL arm and VEKAS light box with VEHIG and 12 feet of cable with switch | 1931-19?? | - |
| VERYK | 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and various glass covers, VEYRK to hold film flat; on base of VERAP | 1932-19?? | - |
| VESTA | Base and column; used with VERAP | 1931-19?? | - |
| VEZUK | Curved lateral holder to support the camera when used vertically | ca.1933 | - |
| VIDEO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 10.5cm lenses | 1932-1933 | black |
| VIDOM | Universal viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image | 1933-1939 | |
| VIEFF | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
| VIEME | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 13.5cm lenses | 1932-1933 | black |
| VIFUR | Small, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1933-1936 | black or chrome |
| VIGEH | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
| VIHAK | 74 | 19??-19?? | - |
| VIHEU | Small, torpedo shaped finder for 3.5cm, 5cm lenses | 1932- | black |
| VIKAN | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VIKUL | 9 1/2 x 12 inch lightbox with 3 lights and various glass covers, VIRUP to hold film flat | 1933-19?? | - |
| VILLO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VIOAD | 12 | 19??-19?? | - |
| VIOOH | Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm | 1940-1964 | reaches 2.8 cm with TUVOO add-on |
| VISAX | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1932-1933 | black |
| VISET | Small, torpedo shaped finder for 3.5cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VISIL | 10 | 19??-19?? | - |
| VISOR | The first, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1931-1931 | black |
| VISSI | Small, torpedo shaped finder for 3.5cm, 9cm lenses | 1932-1933 | black |
| VITRE | Small, torpedo shaped finder for 3.5cm, 5cm, 10.5cm lenses | 1933-1936 | black or chrome |
| VIUNA | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm lenses | 1933-1936 | black or chrome |
| VIZWO | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1933-1936 | black or chrome |
| VLOOF | Spare, folding reflector for CEYOO, CEYAL or CAVOO | 1951-1953 | 15532 |
| VMCOO | Intermediate ring for use of Elmar front lenses on 5 cm Summar | 19??-19?? | - |
| VOOLA | Thin metal diaphram setting ring to adjust aperature of 5 cm Elmar when slip-on filter is in place | 1955-19?? | 16621 |
| VOOQF | 32 inch copy stAND column with guide rail like Valoy II OVURO | ca.1955 | 17552 |
| VORGI | Intermediate ring for use of Hektor front lenses on 5 cm Summar | 19??-19?? | - |
| VOROD | Sereoly system for Leica II, III and IIIa | 1932 | NY item |
| VORSA | Early Sereoly system for non-rangefinder cameras and later for Leica II, III and IIIa | 1931-1939 | - |
| VORSTAN | Sereoly system for non-rangefinder cameras | 1933-1934 | - |
| VORUF | Stereoly arm to mount prisum on Leica II, III and IIIa | ca.1939 | - |
| VOSTN | Sereoly system for non-rangefinder cameras and later for Leica II, III and IIIa | 1935-1939 | - |
| VOTIV | Stand for VOTRA stereo transparency viewer; nickel plated | 1931-19?? | - |
| VOTRA | Stereo transparency viewer; nickel plated | 1931-19?? | - |
| VSPOO | Focusing mount for Focoslide OOBAZ or OTGOO using F = 5 cm 1:2 Summicron II | 1956-1968 | 16608 |
| VTOOX | Aperature setting ring for 50mm f/2.8 Elmar-M | 1958-19?? | 16622 |
| VTROO | Aperature setting ring for 60 mm f/2.2 Summicron-M | 1956-19?? | 16686 |
| VUROO | Valloy II copy stand with 25 1/2 inch column including UWOOS bracket to take FOCOSLIDE | 1960-19?? | 16702 16704-3/8" bush |
| VWOOU | Repro N extension tub 26mm fitted between Focoslide OOBAZ or OTGOO | 1956-19?? | 16689 |
| VXOOT | Focusing mount for Focoslide OOBAZ using F = 5 cm 1:3.5 Elmar and VALOO aperature setting ring | 1958-19?? | 16622 |
| VXZOO | Focusing mount for Focoslide OOBAZ or OTGOO using 50mm f/2.8 Elmar-M | 1958-19?? | 16608 |
