WXYZ
Revision as of 13:55, 20 September 2009 by Admin (talk | contribs)
WEISO Mini-telescope viewfinder for Elmar f= 3.5 cm 1:3.5; black or chrome; early with flare 1933-1950 -
WESTO "Leicameter" exposure meter Weston model 650; large, black rectangular housing with chamfered corners 1936-19?? NY item
WICAB Copy accessory lens cap with a shoe for angular finder WINKO 1936-1939 -
WICAP Copy accessory lens cap with a shoe for angular finder WINKO 1931-1935 -
WINKO Angle viewfinder for Standard Leica (model E) early versions have a larger eyecup 1929- black or chrome
WINTU Angle viewfinder for Leica II, Leica III & Leica IIIa with swing-in prism for right angle focus 1933-1948 black or chrome
WOOLD Angle viewfinder for Standard Leica (model E) with additional interior prism 1938-1950 black or chrome
WOOSU Angle viewfinder for Leica II, Leica III & Leica IIIa with swing-in prism for right angle focus with additional interior prism 1938-1948 black or chrome
WZCOO Copy accessory lens cap with a shoe for angular finder WINTU for Leica II and III's 1936-1939 -
XADEE Special stand for dental photography using XBEET connector 1939-19?? -
XBEET Sliding connector with wingnut forfitting FOCOSLIDE to pillar stands LURTE or USII 1939-19?? -
XDQII Siding arm for rotating stage using ball bearings for positioning of camera 1938-19?? -
XEMOO Xenon f= 5 cm 1:1.5 1939-1950 -
XIOOM Hood for Xenon f= 5 cm 1:1.5 chrome or black; folds flat; NY or Wetzlar 1939-19?? -
XOFLA Kodachrome type A flash filter; E41 mount ca.1949-19?? -
XOOAM Yellow no. 0 very light filter; slip-on type E ca.1938 -
XOOAY Kodachrome type A filter; E41 mount ca.1949-19?? -
XOOBZ Yellow no. 1 light filter; slip-on type E ca.1938 -
XOOCN Yellow no. 2 medium filter; slip-on type E ca.1938 -
XOODA Graduated yellow filter; slip-on type E ca.1938 -
XOOFB UVa filter; slip-on type E ca.1938 -
XOOGP Panchromatic green no. 1 filter; slip-on type E ca.1938 -
XOOHC Graduated green filter; slip-on type E ca.1938 -
XOOIM Conical, tapered hood for 50mm f/1.4 Summilux-M II black with wide chrome band 1968-1995 12586
XOOIO Infra-red no. 1 light filter; slip-on type E ca.1938 -
XOOKD Infra-red no. 2 medium filter; slip-on type E ca.1938 -
XOOLR Infra-red no. 3 dense filter; slip-on type E ca.1938 -
XOOME Orange filter; slip-on type E ca.1938 -
XOOMT Yellow no. 3 dense filter; slip-on type E ca.1938 -
XOONS Hood for Summarit f= 5 cm 1:1.5 ca.1949-1960 -
XOOOG Yellow no. 1 light filter; screw-on type E41 ca.1955 13160
XOOPT Yellow no. 0 very light filter; screw-on type E41 ca.1949 13155
XOOQG Yellow no. 1 light filter; screw-on type E41 ca.1949 13160
XOOSH Panchromatic no. 1 filter; screw-on type E41 ca.1949 13170
XOORU Yellow no. 2 medium light filter; screw-on type E41 ca.1949 -
XOOUI Infra-red no. 1 light filter; screw-on type E41 ca.1949 13190
XOOVL UVa filter; screw-on type E41 ca.1949 13205
XOOVW Infra-red no. 2 medium filter; screw-on type E41 ca.1949 -
XOOWK Infra-red no. 3 dense filter; screw-on type E41 ca.1949 13200
XOOZY Orange filter; screw-on type E41 ca.1949 13175
XOSKY Kodachrome skylight filter; E41 mount ca.1949-19?? -
XQIOO Graduated polarizing filter; screw-in E41 mount ca.1949-19?? 13360
XQOOE Blue filter; screw-on type E41 ca.1955 13172
XWTVS Focusing mount for Summar f= 5 cm 1:2 or Summitar f= 5 cm 1:2 with focus to infinity 1948-19?? NY item
YAOOOO Kodachrome type FP filter; E43 mount ca.1959-19?? -
YAROB Magnifying lens ? -
YBEOO Yellow no. 0 very light filter; screw-on type E43 ca.1959 -
YCGOO Yellow no. 1 light filter; screw-on type E43 ca.1959 13161
YELOO Panchromatic no. 1 filter; screw-on type E43 ca.1959 13171
YFLASH Kodachrome flash filter; E43 mount ca.1949-19?? -
YFOOOO Kodachrome type F filter; E43 mount ca.1949-19?? -
YFPOOO Kodachrome type FP filter; E43 mount ca.1959-19?? -
YGPOO Infra-red no. 1 light filter; screw-on type E43 ca.1959 13191
YHROO Infra-red no. 3 dense filter; screw-on type E43 ca.1959 13196
YLXOO Orange filter; screw-on type E43 ca.1959 13176
YMOOL Blue filter; screw-on type E43 ca.1959 13173
YMZOO UVa filter; screw-on type E43 ca.1959 13206
YOOQU Single exposure intermediate ring for oler models ca.1939- -
YQHOO Additional middle section for ZSLOO 1936-19?? -
YRKOO Rack and pinion connector for ROOFU arm of copy stand 1939-1950 -
YROOF Rack and pinion connector for ROOFU arm of copy stand with finer adjusment 1951-19?? -
YSKYLI Kodachrome skylight filter; E43 mount ca.1954-19?? -
YSOOE Extension foot for Albada brite-line SUOOQ or similar finder to clear camera housing 1950's -
ZIOOQ Extension accessory shoe for Leica If & Leica Ig with flash and finder SBOOI 1954-1960 15546
ZOOAN Short, chrome focusing mount for Hektor f= 13.5 cm 1:4.5 ; see also ZOOMF 1938-19?? 16495
ZOOEP Short, chrome focusing mount for the Summicron M 2/90 mm to Visoflex II / III 16462
ZOOMF 50 mm extension tube for Hektor f= 13.5 cm 1:4.5 in short mount ZOOAN 1951-19?? -
ZOONT Special focusing mount for Elmar f= 3.5 cm 1:3.5 1951-19?? -
ZOOSI-HESUM Complete focusing stage for Summar and Summitar 1951-19?? -
ZOOXY Focusing mount for Elmar f= 3.5 cm 1:3.5; 1:18-1:2 reduction; "Focomount" NY designation 1951-19?? -
ZPOOK Table clamp for VALOY II column 1955-19?? 17508
ZQGOO Helical focusing mount with screw adaptor ring no. 3 for 50 mm 1:4,5 FOCOTAR 1:2.5 to infinity 1956-19?? 16688
ZSLOO Collapsible upright with table clamp in 3 parts for traveling; see also YQHOO 1936-19?? -
ZSOOG Tri-pod extension for short ball and socket to enable wide camera support plates 1938-19?? -
ZTNOO 2 small, chrome cylindrical adaptors for converting tri-pod thread; English & metric 1938-19?? -
ZTOOF Small, chrome cylindrical adaptor for converting English tri-pod thread to metric 1938-19?? -
ZUPOO Lighting device for press photographers with 4 chrome reflectors on a vertical stem 1937-19?? -
ZVOOD Small, chrome cylindrical adaptor for converting metric tri-pod thread to English 1938-19?? -
ZWOOC Set of extension tubes ZWTOO, BOOXZ, MOOBG, MOODH & MOOGW 1936-19?? -
ZWTEL Focusing mount for Elmar (II) f= 5 cm 1:3.5 with focus to infinity 1948-19?? NY item
ZWTOO Focusing mount for Elmar f= 3.5 cm 1:3.5 1936-1950 -
ZWTOO-HESUM Focusing mount for Summar f= 5 cm 1:2 1936-1940 -
