PQR
Revision as of 21:36, 25 September 2009 by Admin (talk | contribs)
PAMOO Right angle 5x eyepiece; early version with mirror; later with prism; PAMOO + PROON = ODULO later used on Visoflex I 1940-1962
PCOOB Yellow filter no. 0 very light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PEGOO Visoflex I, 45 degree 4x eyepiece; black with rubber eyepiece 1951-1962 16487
PEOOZ Yellow filter no. 1 light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PFOOY Yellow filter no. 2 medium; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PGOOX Graduated yellow filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PGYOO Graduated green filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PHOOW UVa filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PIOOV Panchromatic filter no. 1 ; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PKOOU Infra-red filter no. 1; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PLGOO Orange filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PLOOT Mirror reflex housing with flared eyepiece and double cable release 1935-1951 -
PMOOS Infra-red filter no. 2; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PNOOR Infra-red filter no. 3; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
POFLA Kodachrome flash filter; screw-on type E48 ca.1949 NY item
POLAR Stereo transparency equipment to add to Leitz VII projector for viewing stereo projections 1938-19?? NY item
POOAH Yellow filter no. 0 very light; screw-on type E48 ca.1935 13290
POOAY Kodachrome filter type A; screw-on type E48 ca.1949 NY item
POOBV Yellow filter no. 1 light; screw-on type E48 ca.1935 13295
POOCI Yellow filter no. 2 medium; screw-on type E48 ca.1935 -
POOCQ Blue filter; screw-on type E48 ca.1955 13307
POODW Panchromatic filter no. 1; screw-on type E48 ca.1935 13305
POOEK Infra-red filter no. 2; screw-on type E48 ca.1935 -
POOEL Polarising filter; graduated, slip-on type A36 ca.1939 13350
POOFX UVa filter; screw-on type E48 ca.1935 13330
POOGL Infra-red filter no. 1; screw-on type E48 ca.1935 13315
POOHY Infra-red filter no. 3; screw-on type E48 ca.1935 13325
POOIM Chimney 5x flared eyepiece with swing-in 30x magnifier for PLOOT 1935-1951 -
POOKZ Orange filter; screw-on type E48 ca.1935 13310
POOLN Polarising filter; swing-out, slip-on type A36 with clamping screw ca.1939 -
POORE Polarising filter; graduated, screw-on type L for Summitar f= 5 cm 1:2 ca.1949 13362
POORQ Double cable release for PLOOT mirror reflex housing 1936-19?? -
POOTR Polarising filter; graduated, screw-on type E39 ca.1939 13362
POSKY Kodachrome skylight filter; screw-on type E48 ca.1949 NY item
PROON Pre Visoflex mirror reflex housing; used with PAMOO = ODULO; used with POOIM = PLOOT 1940-1950 -
QBOOE Yellow filter no. 3 dense; screw-on type H ca.1935 NY item
QCPOO Yellow filter no. 3 dense; slip-on type A36 ca.1931 NY item
RAMET Mask used with RASUK for 3.5 - 9 cm lenses 19??-19?? -14
RASAL RAMET + RASUK; chrome plated version = CHROM 19??-19?? -
RASUK Lensless viewfinder for 10.5 & 13.5 cm lenses 19??-19?? -
RDQOO Diaphragm operating lever and guide for lens on Reprovit II ROOXU 1951-19?? 16775
REDIG-BEEUL 73 19??-19?? -
REDUK-BEEUL 73 19??-19?? -
REDYX 73 19??-19?? -
REEOD 74-61 19??-19?? -
RESOO 74 19??-19?? -
RFUOO 73 19??-19?? -
RGWOO 61-2 19??-19?? -
RIFLE 46 19??-19?? -
RIOOX 78 19??-19?? -
RIOOZ 73-77 19??-19?? -
RKCOO 71-2-78 19??-19?? -
ROOAI 55-6-78 19??-19?? -
ROOAM 55 19??-19?? -
ROOFU 68-61-63-69-78 19??-19?? -
ROOKA 74-76 19??-19?? -
ROOMB 68-74 19??-19?? -
ROONP 68 19??-19?? -
ROOSE 78-9 19??-19?? -
ROOXU 78 19??-19?? -
ROOYH 59-78 19??-19?? -
ROSOL 14 19??-19?? -
ROXUM 78 19??-19?? -
RPNOO 63-4 19??-19?? -
RPOOT 63 19??-19?? -
RQPOO 101 19??-19?? -
RSTOO 63 19??-19?? -
RTSOO 63 19??-19?? -
RWBOO Deerskin pouch for RASAL 19??-19?? -
