GHIJ
Revision as of 14:25, 22 October 2009 by Admin (talk | contribs)
GBOOM No. 0 very light yellow filter; screw-on type L ca.1939 -
GBWOO No. 1 light yellow filter; screw-on type L ca.1939 -
GCHEO Kodachrome flash filter; screw-on type L ca.1949-19?? NY item
GCHEOMI Kodachrome flash filter; screw-on type E39 ca.1949-19?? NY item
GCOOL No. 2 yellow filter; screw-on type L ca.1939 -
GCSKYMI Kodachrome skylight filter; screw-on type L ca.1949-1950's NY item
GCYOD Panchromatic no. 2 green filter; screw-on type L ca.1939 -
GCYOO Panchromatic no. 1 green filter; screw-on type L ca.1939 -
GDOOK Orange filter; screw-on type L ca.1939 -
GECOO Infra-red no. 1 light filter; screw-on type L ca.1939 -
GFEOO Infra-red no. 2 medium filter; screw-on type L ca.1939 -
GFOOH Infra-red no. 3 dark filter; screw-on type L ca.1939 -
GHIOO UVa filter; screw-on type L ca.1939 -
GHOOF Graduated yellow filter; screw-on type L ca.1939 -
GIIBR Microphotography 18 inch cable release for MIKAS with set screw mount 1939-19?? -
GIIEF Microphotography 1/3x conical extension tube for MIKAS with screw-mount 1939-19?? -
GIIEF-M Microphotography 1/3x conical extension tube for MIKAS with M-mount 1939-19?? -
GIIFT Microphotography 18 inch cable release for MIKAS with screw-mount 1939-19?? -
GIIMW Microphotography 1/2x conical extension tube for MIKAS with screw-mount 1939-19?? -
GIIMW-M Microphotography 1/2x conical extension tube for MIKAS with M-mount 1956-19?? -
GIINK Microphotography 1x conical extension tube for MIKAS with screw-mount 1939-19?? -
GIIOX Single exposure housing without shutter 1939-1940's NY item
GILOO Graduated green filter; screw-on type L ca.1939 -
GMOOA Leica IIIg with Summarit f= 5 cm 1:1.5 1957-1970 -
GOOEF Leica IIIg body 1957-1970 -
GOOEL Leica IIIg with Elmar f= 5 cm 1:2.8 (ELMOO) 1957-1970 -
GOOMI Leica IIIg with Summicron (I) f= 5 cm 1:2 (SOOIC) 1957-1970 -
GOORM Copy stand arm for 1 1/4 inch column with tape measure for rotating stage OORES or 250 stage GRBOO 1938-ca.1950 -
GOOSZ Complete copy stand with GOOZQ arm for 1 1/4 inch column with tape measure for rotating stage OORES either direct or with ball and socket KAGOON head 1938-ca.1950 -
GOOZQ Copy stand arm for 1 1/4 inch column with tape measure for rotating stage OORES either direct or with ball and socket KAGOON head 1938-1950 -
GRBOO Sliding stage for Leica 250 (models DD, FF & GG) 1935-ca.1950 -
GROOW Basic copy stand with spring mounted base plate 19??-19?? -
GVKOO 30 mm extension ring G for ZWTOO-HESUM 19??-19?? -
HAKOSYN Flash synchronization attachment for an unmodified M3 19??-19?? -
HEBOO Slow speed shutter release for 1, 1/2, 1/4, 1/8 s in nickel or later chrome 1935-1969 -
HEFAM Hektor f= 13.5 cm 1:4.5 black M-mount 1954-1960 HEFAR-M
HEFAM-CHROM Hektor f= 13.5 cm 1:4.5 chrome M-mount 1954-1960 -
HEFAM-KUP Hektor f= 13.5 cm 1:4.5 nickel 1933 -
HEFAR Hektor f= 13.5 cm 1:4.5 chrome 1933-1959 -
HEGRA Hektor f= 7.3 cm 1:1.9 black lacquer & chrome 1934-1946 -
HEKON Hektor f= 7.3 cm 1:1.9 black lacquer & nickel 1931-1933 -
HEKTO Hektor f= 5 cm 1:2.5 nickel or chrome 1930-1936 -
HEPET Close-up supplementary front lens no. 3 for Hektor 5 cm 1928-1950's -
HEPIK Close-up supplementary front lens no. 2 for Hektor 5 cm 1928-1950's -
HEPRO Close-up supplementary front lens no. 1 for Hektor 5 cm 1928-1950's -
HFOOK Short-base clip-on rangefinder for Leica models A, B & C 1920's-ca.1936 -
HGOOI Rear cover for 125 mm Hektor 1930's-1960's 14053
HIIBE Stand for photographing small objects; with adjusment by rack and pinion; with rotation and tilt 1939-19?? -
HIKOO f = 12.5 cm 1:2.5 Hektor Visoflex lens 1954-1963 -
HKMOO With front cap ORPNO and rear cap HGOOI was a container for f = 12.5 cm 1:2.5 Hektor 1954-1963 12532
HMOOD Hood for 90 mm Summicron 1957-19?? -
HOOAR Yellow no. 0 very light filter; screw-on type E39 ca.1955 13081
HOOBE Yellow no. 1 light filter; screw-on type E39 ca.1955 13086
HOOCS Infra-red no. 1 light filter; screw-on type E39 ca.1955 -
HOODF Infra-red no. 2 medium filter; screw-on type E39 ca.1955 -
HOOET Infra-red no. 3 dark filter; screw-on type E39 ca.1955 -
HOOFG Panchromatic filter; screw-on type E39 ca.1955 -
HOOGU Orange filter; screw-on type E39 ca.1955 -
HOOIV UVa filter; screw-on type E39 ca.1955 -
HOOKI Blue filter; screw-on type E39 ca.1955 13098
HOOPY Hektor f= 2.8 cm 1:6.3 nickel 1935-1936 -
HOOPY-CHROM Hektor f= 2.8 cm 1:6.3 chrome 1936-1955 -
IASUU Stereo polarizing spectacles in a plastic frame 19??-19?? -
IBSOR Single exposure shutter used with OLEYO and OLIGO housings 1939-19?? NY item
IDCOO M3 leather ready case 19??-19?? -
IFLEX Micro version of Visoflex I with rotating film holder in screw and bayonet versions 1953-19?? -
IFSTA Adjustable filter stand copy accessory 1939-19?? -
IGEMO M3 body 1954-1968 -
ILNOO Elmar (II) f= 9 cm 1:4 collapsible 19??-19?? -
ILNOO-M 90mm f/4 Elmar collapsible M-mount 1954-1968 -
ILLUM Copy stand 2 pair lamp attachment for 2" diameter column 19??-19?? NY item
ILNUU Stereo projection attachment for twin 85 mm Hektor lenses used with PRADO projectors 19??-19?? -
IMARO M3 with F = 5 cm 1:3.5 Elmar 1954-1968 -
IMFIN Universal viewfinder knon as "Imarect" ca.1942-19xx NY item
IMOOP MP and MP2 body 1956-1959 -
IMPUU Stereo projection attachment for twin 50 mm Elmar lenses used with PRADO projectors 19??-19?? -
IMPUU-IZOUU Stereo projection attachment for twin 50 mm Elmar lenses used with PRADO 250 and 500 projectors 19??-19?? -
IROOA Hood for 35 & 50 mm lenses with E39 mount; black with wide chrome band; earliest engraved "Summicron-" without code word; later versions had "IROOA"; last with catalog number 1959-19?? 12571
IRZOO M-mount adapter for using 35 & 50 mm Leica screw-thread on M-cameras 1956-19?? 14097
IRZUU Stereo projection attachment for twin 100 mm Hektor lenses used with PRADO projectors 19??-19?? -
ISAIO M3 with F = 5 cm 1:1.5 Summarit 1954-1968 -
ISBOO M-mount adapter for using 90 mm Leica screw-thread on M-cameras 1956-19?? 14098
ISBUU Stereo projection attachment for twin 120 mm Hektor lenses used with PRADO projectors 19??-19?? -
ISOOZ M-mount adapter for using 135 mm Leica screw-thread on M-cameras 1956-19?? 14099
ISUMO M3 with F = 5 cm 1:2 Summicron II 1954-1968 -
ITDOO Hood for 3.5 cm Summaron and 5 cm Summicron with narrow chrome band and velvet lining for reverse positioning 1956-19?? -
ITOOY Hood for 3 cm Elmar with E39 front flange; early version engraved "Elmar-"; late version with wide chrome band 1956-19?? 12580
IUFOO Hood for 9 cm Elmar and 135 Hektor; black with narrow chrome band at lens; wider chrome band; all black last version 1956-19?? 12575
IVZOO Cap that screws into M-mount body 19??-19?? 14056
IWKOO Hood for Super-Angulon f= 2.1 cm 1:4 with double trigger fastening 1960-19?? 12502
IXMOO Reloadable metal cassette with chrome tab; new version 1966-19?? 14006
IZQOO Rear dust cover for M-thread lens 19??-19?? 14051
